Mitchell Holman wrote
begin 644 B52 b.jpg OK Mitchell....where's the video of this event? ![]() Bob Moore |
Robert Moore wrote in
. 15.205: Mitchell Holman wrote begin 644 B52 b.jpg OK Mitchell....where's the video of this event? ![]() Bob Moore Good question. If one exists I don't want to see it. Too sad to see so much work end up as splintered balsa... |
Robert Moore wrote:
Mitchell Holman wrote begin 644 B52 b.jpg OK Mitchell....where's the video of this event? ![]() Bob Moore http://www.youtube.com/watch?v=dxp4qYC9ZtU |
Sometimes I just can't help but smile.
RK |
The video of this crash was eerily like the crash of the B-52 at Fairchild
AFB a few years back. Rob "Mitchell Holman" wrote in message ... |
![]() "Scubabix" wrote in message ... The video of this crash was eerily like the crash of the B-52 at Fairchild AFB a few years back. That is because the cause for each of the crashes was somewhat the same. The Buff did not use regular ailerons, as you would normally think of them. The flexibility of the wing would twist when a normal aileron input was applied, and would actually give the opposite roll reaction that was expected. The aileron was acting like a boost tab, in sorts. The solution was to control roll by having a spoiler instead of an aileron, so that if you wanted to roll right, the right spoiler went up, that side lost some lift, and the aircraft rolls. It was also good to prevent adverse yaw. The only problem with that type of control roll, was that if a critical bank angle was exceeded, the roll was unrecoverable. Your were going to crash, period. The full sized crash was being piloted by a senior pilot who was known as a cowboy, and exceeded various flight parameters, frequently. Some crew would not fly with him. He pulled his steep bank trick one too many times, and did not get away with it. The RC model might have gotten too steep, in a normal flight pattern, but I think what happened was that the overcast sky messed up the pilot's orientation clues, and he banked steeper, rather that flattening it out. I've done it, and about anyone who flies RC has also done it, and gotten it back into control. With the model Buff, getting that steep put you into an unrecoverable area of the flight envelope. Boom, was the final result. -- Jim in NC |
I think what happened was that the overcast sky messed up the pilot's orientation clues, and he banked steeper, rather that flattening it out. I've done it, and about anyone who flies RC has also done it, and gotten it back into control. With the model Buff, getting that steep put you into an unrecoverable area of the flight envelope. Boom, was the final result. -- Jim in NC Sorry to jump in here. But as I recall the discussion at the time of the RC crash it was due to the "dreaded downwind turn" that plagues some RC pilots at times. But no matter the real reason the outcome is the same. Les |
![]() "ABLE_1" wrote But as I recall the discussion at the time of the RC crash it was due to the "dreaded downwind turn" that plagues some RC pilots at times. But no matter the real reason the outcome is the same. Oh no! The dreaded downwind turn!!! Of course, this is a subject that has been possible the most discussed of any subject. I tend to go with the aerodynamicist that says that a downwind turn problem is impossible to be a problem. I can believe there will be a problem if the pilot does not correctly keep his speed up when he turns downwind, but if a plane was flying when it started the turn, and the same airspeed is maintained, there will not be a crash. -- Jim in NC |
"Morgans" wrote in
: "ABLE_1" wrote But as I recall the discussion at the time of the RC crash it was due to the "dreaded downwind turn" that plagues some RC pilots at times. But no matter the real reason the outcome is the same. Oh no! The dreaded downwind turn!!! Of course, this is a subject that has been possible the most discussed of any subject. I tend to go with the aerodynamicist that says that a downwind turn problem is impossible to be a problem. I can believe there will be a problem if the pilot does not correctly keep his speed up when he turns downwind, but if a plane was flying when it started the turn, and the same airspeed is maintained, there will not be a crash. Indeed, the plane's frame of reference is the atmosphere, not the ground. Unless it runs into some hellacious shear, the airspeed will not change in the turn any more than it would in a pefectly static air mass. Kind of like the plane taking off from a conveyor belt myth that was so solidly busted on 'Mythbusters'... Bob ^,,^ |
Last ever flying Jaguar not flying anymore.... - _07Oct19-36.jpg (0/1) | Martin J Hooper | Aviation Photos | 7 | January 15th 08 06:08 PM |
Last ever flying Jaguar not flying anymore.... - _07Oct19-36.jpg (1/1) | Martin J Hooper | Aviation Photos | 0 | January 7th 08 01:59 PM |
Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | Aviation Marketplace | 9 | January 4th 04 02:24 AM |
Flying Magazine's Instrument Flying 1973 | Steven P. McNicoll | General Aviation | 9 | January 4th 04 02:24 AM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
