Transponder Praise
Old July 5th 08, 06:34 PM posted to rec.aviation.soaring
jcarlyle
Default Transponder Praise
On July 2 (a day with blue skies, a few scattered CUs and typical east
coast haze) a friend and I were thermalling our ASW-20 and ASW-19
sailplanes at 6,000 feet 3 miles SE of Blairstown, NJ (a clearly
marked glider port some 40 miles from Newark Airport and Teterboro
Airport). My Zaon MRX alerted us to traffic at our altitude 5 miles
away, which then rapidly closed on us. Despite our best efforts over
the next 30 seconds, neither my friend nor I saw anything approaching.
Then suddenly we saw a business jet in a 45-50 degree bank less than a
mile away. Apparently my transponder caused a TA on his TCAS, he
looked outside and saw our wings flashing, and he turned away from the
impending collision.
I realize not everyone flies in a high traffic area like that around
NY and PHL. But especially for my soaring friends who fly the
Governor’s Cup course, I strongly recommend you put a transponder in
your ship. They cost less than a glide computer, and while they won’t
tell you where you are, a transponder might just get you home someday…
-John
Old July 5th 08, 07:21 PM posted to rec.aviation.soaring
BT
Transponders are a good thing.. when the other guy has TCAS or TIS
capability.
I would venture a guess it's 50-50 he never saw you and simply reacted to
the TA commands.
The small GA aircraft without a TIS display will still never see you.
BT
"jcarlyle" wrote in message
-John
Old July 5th 08, 07:56 PM posted to rec.aviation.soaring
Darryl Ramm
capability.
the TA commands.
BT
-John
I hope the real point is that without a transponder you are really are
quite invisible in the system. The GA aircraft has a lot less chance
of avoiding you if you don't have a transponder at all. More and more
GA aircraft are flying with "something", but certainly not TCAS. I
wish numbers were available but look around the airport, certainly the
high performance singles crowd and above seem to have traffic
avoidance toys, including PCAS (e.g Zaon MRX) or more advanced TAS
systems from vendors like Avidyne, or they may have TIS, but that's
getting less interesting nowdays. Or GA aircraft may just be under the
control of ATC or under flight following and get a traffic advisory.
And to counter recent concerns about what ATC does with VFR traffic -
I've had excellent advisories of VFR to VFR traffic when in a
sailplane under flight following (and hear them advisign traffic of
me) - including to unknown VFR (i.e. traffic squawking 1200) and heard
traffic advisories about me to airline traffic when not under flight
following (including Reno approach, before the mid-air).
Darryl
Old July 6th 08, 04:35 AM posted to rec.aviation.soaring
BT
Agree to all Darryl..
Sadly my club LS4 is without a transponder
But I have listened to ATC and heard them calling traffic, "altitude unknown
appears to be a glider", so they know we are there.
The problem lies with the smaller GA aircraft ducking in under the edge of
Class B so as to not have to talk to approach control while they zip into
one of the satellite airports.
BT
Old July 5th 08, 08:38 PM posted to rec.aviation.soaring
Hellman
capability.
the TA commands.
BT
Which is why it's good to fly with both a transponder and a PCAS like
the Zaon MRX. I fly near both SFO and RNO airspace, and while these
aids must be regarded as aids - not substitutes - I find them
invaluable for helping "see and be seen." I know there's a cost
involved, but in the grand scheme of the cost of soaring, it is not a
huge increase when amortized over the life of the units.
As I noted in a PASCO Safety Seminar talk last Fall, one way to reduce
fatalities is to treat serious but non-fatal accidents with the same
respect as if there had been loss of life. Along those lines, what our
reaction (and the FAA's!) would have been if the Minden glider-bizjet
midair two years ago had been with an airliner and if there had been
significant loss of life on the airliner. I suspect our use of
transponders and PCAS would go way up, voluntarily at first and then
mandatorily as the FAA got into the act and took away many of our
privileges. Let's not wait for something of that magnitude - which
could kill soaring as we know it along with hundreds of people - to
take action.
I wrote up that talk "Complacency: What Me Worry?" and have posted it
at
http://www-ee.stanford.edu/~hellman/...2007_talk.html
Martin
Old July 6th 08, 05:56 AM posted to rec.aviation.soaring
5Z
Last Tuesday, I received a package with my transponder in it. Of
course, the soaring weather looked good on Friday and Saturday,
perhaps Sunday, so the installation would have to wait another week.
Today, as I prepare to take off, my MRX fails to turn on. I launch
anyway.
Our airport is located half way between Colorado Springs and Denver.
Lots of airliners, etc. flying overhead at 9-13K MSL (2-5K AGL).
About 45 minutes after launch, I watch a TED 737 cruise less than 1/4
mile abeam my thermal. Later, as I'm getting the last bit of altitude
about 5 E of COS, a Southwest 737 drives right through the center of
my thermal and 500' below. I think all the virga and OD around were
squeezing gliders and airliners into a fairly small area. After the
Southwest jet flew under me, I called COS approach and stayed in
contact for the next 15 miles. They NEVER saw my primary target
(ASH-26E) even though I was able to provide a very accurate position.
What's interesting is that in both cases, I was thermalling, so
providing about the best possible "target" for a visual observation.
Guess what I'll be doing tomorrow!
-Tom
PS Our club just bought 3 MRX units to put in the club ships in order
to provide more info to the pilots. And yes, we are in contact with
both DEN and COS approach regarding the traffic issues.
Old July 7th 08, 04:20 AM posted to rec.aviation.soaring
Andy[_1_]
capability.
the TA commands.
TCAS never commands an aircraft to turn to avoid a conflict. TCAS is
only capable of providing vertical commands. If the aircraft turned
it's reasonable to assume the pilots had visual contact.
Andy
Old July 7th 08, 04:57 AM posted to rec.aviation.soaring
BT
True.. the most basic levels of TCAS do not give commands..
those aboard most airliners do
BT
"Andy" wrote in message
capability.
the TA commands.
Andy
Old July 7th 08, 05:33 AM posted to rec.aviation.soaring
Darryl Ramm
BT
capability.
the TA commands.
only capable of providing vertical commands. *If the aircraft turned
Andy
No! Andy was exactly correct, even TCAS-II resolution advisories (RA)
are vertical only. You need a time machine and TCAS IV for lateral
advisories. And strictly going back to earlier comments the traffic
advisory (TA) does not issue a resolution, that is the RA.
Still TCAS, if they were so equipped, could have indicated to the
pilot(s) the presence of the transponder equipped gliders which was
the initial point. But who knows, maybe ATC issues a traffic advisory?
Darryl
Old July 6th 08, 08:27 AM posted to rec.aviation.soaring
Soarin Again[_2_]
efforts over the next 30 seconds, neither my friend nor
bank less than a mile away. Apparently my transponder
caused a TA on his TCAS, he looked outside and saw our
wings flashing, and he turned away from the impending collision.
Assuming that you are talking nautical miles. If you are alerted
to the aircraft at 5 miles and within 30 seconds he is at 1 mile
then is apparently doing 480 knots (well above the 250 kt limit
below 10,000 msl).
If you don't see him and you know he is at your altitude and
closing at that high of a rate, why not just pull full spoilers and
dive to vacate that altitude as quickly as possible?
Is there a better option available?
Which Transponder? Danl Johnson Soaring 10 October 29th 04 06:54 PM
WTB; Transponder Jerome & Gerri Bush Aviation Marketplace 5 September 2nd 04 10:14 PM
WTB Transponder Roy Bourgeois Soaring 0 July 2nd 04 07:44 PM
Which Transponder? Ian Forbes Soaring 16 September 25th 03 04:32 AM
Praise for Bose Mike Granby Piloting 4 July 25th 03 04:18 PM
