Lancair Engine
Old July 6th 08, 07:47 PM posted to rec.aviation.homebuilt
Default Lancair Engine
I am looking to buy Lancair 360. They seem to come with two different
engines, the A1A at 200hp and the B1B at 180hp. Is the only
difference
seems to be the compression ratio, can you upgrade to the 200hp
easily, and
can I expect a difference in performance (rate of climb/speed/useful
load)?
Greg
Old July 6th 08, 09:08 PM posted to rec.aviation.homebuilt
John Kunkel
difference
easily, and
load)?
I think you'll find that the only 200 hp Lycoming 360 is the fuel injected
IO series.
The O-360 A1A is 180 hp and the B1B has slightly less due to the lower
compression.
http://www.prime-mover.org/Engines/L...Cert_list.html
Old July 6th 08, 10:04 PM posted to rec.aviation.homebuilt
Ted Leon
As you've probabley heard...
Buy all the power you can afford!
Ted
"John Kunkel" wrote in message
news
difference
easily, and
load)?
IO series.
compression.
Old July 6th 08, 11:23 PM posted to rec.aviation.homebuilt
greatav8or
On Jul 6, 2:47*pm, wrote:
I am looking to buy Lancair 360. *They seem to come with two different
engines, the A1A at 200hp and the B1B at 180hp. *Is the only
difference
seems to be *the compression ratio, can you upgrade to the 200hp
easily, and
load)?
Greg
i think you are referring to the narrow deck and the wide deck O360
engines. the fuel injection can be had on either, such as the 180 hp
piper arrow or the 200 hp arrow.
Lancair IV Dico Reyers Owning 6 October 19th 04 11:47 PM
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! David Ross Aviation Marketplace 0 August 24th 04 07:13 PM
Lancair 320 ram air? ROBIN FLY Home Built 17 January 7th 04 11:54 PM
Lancair 320/360 kit wanted!!! Erik W Aviation Marketplace 0 October 3rd 03 10:16 PM
Lancair IVP Peter Gottlieb Home Built 2 August 22nd 03 03:51 AM
