superfil used before or during fiberglass layup?
Old July 6th 08, 11:32 PM posted to rec.aviation.homebuilt
Default superfil used before or during fiberglass layup?
I have a few foam gaps to fill. I can apply superfil early on and let
it cure...or I can wait and apply while i am laying up with fiberglass
skin (w/vacuum, etc.) . which is better?
Old July 7th 08, 08:38 PM posted to rec.aviation.homebuilt
On Jul 6, 3:32*pm, "
I have a few foam gaps to fill. *I can apply superfil early on and let
I suspect normal "cell" filling is done concurrent with fiberglassing,
but filling significant voids is done standalone (allowed to cure/then
sanded, prior to fiberglass)
Old July 8th 08, 07:08 PM posted to rec.aviation.homebuilt
BobR
On Jul 7, 2:38*pm, "
Let me put it this way...the better the surface before application of
the glass the better the results are going to be. In those cases
where I have used foam as the base for a part I have always filled and
sanded before applying glass. This would be even more important if
you plan to use a vacuum cure. The glass is either going to follow
the contour of the surface of leave a air bubble underneath. Trying
to apply the superfil and glass together is going to lead to some
undesired results since the epoxy will absorb into the superfil and it
will not hold the shape you desire.
Fiberglass vs. Fabric Lou Home Built 35 July 6th 06 05:08 PM
Aluminized fiberglass Dan, U.S. Air Force, retired Home Built 2 May 3rd 05 08:35 AM
In Contemplation While Doing a Wet Layup on a Plastic Homebuilt Airplane jls Home Built 3 August 17th 04 09:38 PM
Carbon Fiber Layup - Conformal Peel Ply? RKT Home Built 4 February 29th 04 02:33 PM
question: differences between epoxy layup and plaster Morgans Home Built 3 August 6th 03 04:46 AM
