HID landing light
Old July 9th 08, 02:44 AM posted to rec.aviation.homebuilt
Default HID landing light
Maybe somebody already brought this up. But I finally found a decent
priced HID light kit and converted my halogen (H3) landing light. Got
a motorcycle conversion kit from eBay for $63 incl/shipping. For more
info see my page http://www.abri.net/sq2000/21.html
Old July 9th 08, 02:56 PM posted to rec.aviation.homebuilt
john smith
In article
info see my page
I am surprised to see that you mounted the light on the top of the
fuselage instead of the bottom.
If you raise the nose, the light will not illuminate the ground ahead of
you.
If you are in any fog/haze, the reflected light will totally kill your
night vision.
Old July 10th 08, 02:50 AM posted to rec.aviation.homebuilt
you.
Canards land more flat and they don't flare with nose up like
conventional aircraft . The light points the required angle downward.
If you are in any fog/haze, the reflected light will "totally kill your night vision".
Thats an exaggerated alarmist comparison to mounting it just 6" lower.
Other canards mount the light in wing leading edge (behind pilot)
which should have the same "disastrous" effect - but nobody in all
these years has mentioned such a problem.
HID Landing Light Kyle Boatright Home Built 23 February 18th 07 09:19 AM
Landing light tony roberts Owning 30 October 25th 05 03:23 PM
Landing Light CB Hankal Owning 25 August 25th 04 02:22 AM
Landing light? Hankal Owning 6 July 19th 04 05:16 PM
Landing light Hankal Aviation Marketplace 0 July 14th 04 01:23 AM
