Has anyone set-up a Colibri feeding NMEA to a Dynon? Specifically have you
worked out what combination of NMEA sentences are required to get the Dynon (D10A) HSI to display in full? I'm getting the GPS positional information, but not information relating to next waypoint in a task. |
At 22:12 09 July 2008, Paul Smith wrote:
Has anyone set-up a Colibri feeding NMEA to a Dynon? Specifically have you worked out what combination of NMEA sentences are required to get the Dynon (D10A) HSI to display in full? I'm getting the GPS positional information, but not information relating to next waypoint in a task. Havent done any real life investigation but did investigate when I was thnking of buying a dynon. You need $GPRMC = (position, velocity, time) $GPRMB = Route Info $GPGGA = essential fix data which provide 3D location and accuracy data and one of $GPBOD = Bearing - Origin to Destination shows the bearing angle of the line, calculated at the origin waypoint, extending to the destination waypoint from the origin waypoint for the active navigation leg of the journey or $GPAPB =Autopilot format B I know that the LX outputs neither of the last two and am fairly sure that neither does the colibri. Turning on RMB may just help rgds Stephen |
Thanks Stephen.
Does anyone have any recommendations regarding an alternate IGC logger or nav device that does work with the HSI view in the Dynon? I'd be interested to know of the configuration of any gliders fitter with a dynon where this is working. thanks again, Paul. |
On Jul 10, 6:27*am, Paul Smith wrote:
Thanks Stephen. Does anyone have any recommendations regarding an alternate IGC logger or nav device that does work with the HSI view in the Dynon? *I'd be interested to know of the configuration of any gliders fitter with a dynon where this is working. thanks again, Paul. The Garmin aviation series (x96) output the necessary sentences. You can get a 196 for less than $500, or you can get fancy with a 396 or 496 and add XM weather. I just purchased a Dynon D10A and am installing it in my play toy. Charlie |
Dynon D10a Artificial Horizon | stevehaley | Soaring | 0 | July 27th 07 10:40 PM |
FS Colibri | Ed Hollestelle | Soaring | 1 | December 20th 06 03:00 AM |
Which would draw more juice? A glass display Dynon Efis-D100 or regular style "Steam Gauges" that are electric. | [email protected] | Home Built | 3 | September 30th 06 08:36 PM |
Dynon EFIS-D10 Any Pireps or Opinion? | Gig Giacona | Home Built | 7 | May 22nd 05 02:58 AM |
Dynon EFIS D-10 Magnetic heading | Paul Lee | Home Built | 3 | November 15th 04 08:41 PM |
