Glider Winch Manufacturers or Plans to make???
Old July 13th 08, 01:43 AM posted to rec.aviation.soaring
Ted[_2_]
Default Glider Winch Manufacturers or Plans to make???
Does anyone out there in this world make glider launch winches or are there
plans available?? THANKS!! Ted
Old July 13th 08, 02:34 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Yes. There are two Yahoo groups that can provide you with much more
information:
http://groups.yahoo.com/group/winchdesign/
http://groups.yahoo.com/group/winchengineer/
Marc
Old July 13th 08, 08:26 AM posted to rec.aviation.soaring
Tony Clark
At 00:43 13 July 2008, Ted wrote :-
Does anyone out there in this world make glider launch winches . . . .
Well you did say "Does anyone out there in this world make glider launch
winches . . . . " ?
Out of interest try looking at :-
http://www.skylaunchuk.com/index.htm
You sould feel at home, as the one I drive, the Skylanch 8200 is powered
by a Chevy 8.2 litre V8 (Run on LPG)
Old July 13th 08, 10:07 AM posted to rec.aviation.soaring
Ted[_2_]
Hi Mark & Tony,
THANK YOU SO MUCH for your replies!! You guys are GREAT!!
Cheers, Ted
"Tony Clark" wrote in message
winches . . . . " ?
Old July 13th 08, 02:33 PM posted to rec.aviation.soaring
Bill Daniels
The skylaunch is a cosmetic update of the 1960's US Gerhlein winches and
suffers from the same major shortcomings. If you still like it, save $50k -
$75k by spending a couple of thousand for an old Gerhlein and fix it up.
If you'd like a modern, state of the art winch, take a look at these from US
winch buiders:
http://www.romansdesign.com/
and
http://www.hydrowinch.com
Bill Daniels
"Ted" TBBlakeley@comcastDOTnet wrote in message
Hi Mark & Tony,
Cheers, Ted
winches . . . . " ?
Old July 13th 08, 07:01 PM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Here you can see why Yahoo has two winch groups, rather than one 8^)
My advice is that you study what people have to say on both groups
carefully, take those with an obvious bone to pick with a grain of salt,
assess the finances and available expertise, and make the most
appropriate choice for your club or soaring operation. Also, take a
careful look at retrieve winches, they allow you to start off with a
single or double drum winch, and provide a straightforward upgrade path
to higher launch rates when justified, at only a slight cost in launch
height.
And, I've gone out of my way to spend some time sitting in, poking
around, and getting launched by updated Gehrlein, Tost, Supacat, and
Skylaunch winches. Skylaunch has a proven design, and gives you the
option of buying individual components, kits, or completely built
winches. Yes, the basic configuration of a Skylaunch is similar to a
Gehrlein (though most Gehrleins have one drum). With an
engine/transmission swap, upgraded drum, changes to the cable rollers
and guillotine, and some amount of tinkering, a Gehrlein can be made
quite usable. A Skylaunch simply gets you there quicker and in more
comfort, though of course, at higher cost.
Roman of Roman's Design is a mechanical genius, he has helped upgrade a
number of the old Gehrleins in Southern California, and his new winch is
an automated marvel which has started test launching. It costs a bit
more than a Skylaunch, and may well end up being a viable alternative.
Roman also recognizes that finances are an issue for a lot of clubs, so
he is currently designing a simpler lower cost single drum model which
may be a better fit for many.
As for Hydrowinch, well, I'd like to have an Antares, but I'll likely
never be able to afford to buy or maintain one...
Marc
winch buiders:
and
Bill Daniels
Old July 13th 08, 07:06 PM posted to rec.aviation.soaring
Ian
Could you expand on that a bit? I know a few clubs here which use 'em
and think very highly of them.
Ian
Old July 13th 08, 07:41 PM posted to rec.aviation.soaring
Z Goudie[_2_]
At 18:06 13 July 2008, Ian wrote:
and
Now you've done it!
Old July 13th 08, 07:56 PM posted to rec.aviation.soaring
Tony Clark
At 13:33 13 July 2008, Bill Daniels wrote :-
The Skylaunch is a cosmetic update of the 1960's US
Gerhlein winches and suffers from the same major shortcomings. If you
still like it, save $50k-$75k by
fix it up. If you'd like a modern, state of the art
winch, take a look at these from US winch buiders:
http://www.romansdesign.com/ and
Bill Daniels
Hi Bill,
I'm not particularly promoting Skylaunch! It's just that Bill asked if
anybody had information on professionally built, and self build winches,
and we as readers and contributors to these forums, are surely doing what
he asks for if we throw him all the information and links etc. we can, so
he can study the situation for himself. I look on comments like yours as a
positive aid to Bill's information gathering, so long as they are unbiased
and accurate!
With this in mind I would be pleased if you could explain in more specific
detail about what you personally found are the "shortcomings" of the
'Skylaunch' winch - rather than just just leave it at a vague reference
to mysterious "shortcomings.
I found this staccato comment perplexing because I have been driving
winches since 1972 and the Skylaunch 8200 since 2001, launched thousands
of gliders with the Skylaunch and trained many new winch drivers. Yet,
after all these launches, I have yet to find these mysterious
"shortcomings" that you speak of!
If you have had a lot experience of driving Skylaunch winches, but have
specific problems with launching or the winch, I for one would take much
interest if you could explain them. There may be a reason for your
problems and something as simple as a different method of operation might
be all that is needed to solve them! Maybe you need a little guidance on
setting-up, driving, or maintenance, etc.
On the other hand, if you are making a statement regarding certain
"shortcomings" (that I have not personally found) without actually
having had experience of these winches, and your opinion is actually only
based on secondhand comments, it is not paticularly fair to the
manufacturer, or to Bill, who is trying to gather what accurate
information there is available.
Tony Clark
Old July 13th 08, 09:16 PM posted to rec.aviation.soaring
On 13 Jul, 19:56, Tony Clark wrote:
* *At 13:33 13 July 2008, Bill Daniels wrote :-
Gerhlein winches and suffers from the same major shortcomings. *If you
fix it up. *If you'd like a modern, state of the art
http://www.romansdesign.com/*and
Bill Daniels
Hi Bill,
and accurate!
Tony Clark
I'm getting confused about the Bills and Teds but I am anticipating an
excellent adventure!
Biggest Glider Ever Launched via Winch? [email protected] Soaring 25 November 22nd 06 10:17 PM
Bigger Battery holders from glider manufacturers Gary Emerson Soaring 5 May 31st 06 07:53 AM
Gehrlein Winch plans needed Sam Discusflyer Soaring 1 January 22nd 06 10:25 PM
Gehrlein Winch plans needed Sam Discusflyer Soaring 0 January 22nd 06 10:21 PM
Winch for hanging glider underneath hangar roof. Karl Soaring 8 April 9th 05 11:56 AM
