Questions to ASH26E or ASH25 MI owners
Old July 18th 08, 04:47 PM posted to rec.aviation.soaring
Ludovic Launer[_2_]
Default Questions to ASH26E or ASH25 MI owners
Hi,
A few questions, on behalf of a friend, to the ASH26E owners.
On the Wankel Mid-West AE50R engine:
- Has anyone ever had any leaks problems in the cooling system ? There's
quite a fair amount of cooling liquid being lost at every run. Further
inspections did not show any leaks in the pipes, which would indicate a
problem on the pump itself. Gaskets somewhere ?
The engine is now also leaking fluid when cold.
- On the same matter: does anyone have a drawing of the engine ? It would
help identify the source of the leakage.
- Has anyone ever used the NGK spark plugs ? to what result ?
Concerning the ASH26E itself:
- Does anyone have the 3000 hours inspection program available in eletronic
format ? or a copy on paper...
Is there an ASH26E specific forum somewhere ? could not locate any using
google...
Help and answers can be sent by email to : yves.sargentini (at)
mountain-soaring.net
Regards,
Ludovic
Old July 18th 08, 04:54 PM posted to rec.aviation.soaring
Darryl Ramm
On Jul 18, 8:47*am, "Ludovic Launer" ludovic.launer(at) free.fr
Hi,
[snip]
google...
[snip]
Regards,
Ludovic
There is an active owners group at http://groups.google.com/group/ASH-26E,
your friend can probably get all these questions answered there.
Darryl
Old July 18th 08, 05:18 PM posted to rec.aviation.soaring
Frank Beythien
On Fri, 18 Jul 2008 15:47:19 UTC "Ludovic Launer" ludovic.launer(at)
free.fr wrote:
Hi,
You can try http://www.alexander-schleicher.de/index_e.htm
CU/2
Frank Beythien fBeythien AT gmx.de
Old July 18th 08, 08:20 PM posted to rec.aviation.soaring
Ludovic Launer[_2_]
Nowhere to be found on schleicher's website.
Anyone has a copy ?
Regards,
Ludovic
Questions for Bonanza owners [email protected] Owning 0 January 14th 05 01:57 AM
For Sale: ASH26E with winglets Ludovic Launer Soaring 0 September 5th 04 09:18 PM
ASW22 ASH25 or Nimbus 4 sharply needed for rent to Poland on EGC Pociunai Lenti Soaring 0 March 20th 04 08:59 AM
Spark plugs for ASH26E Ludovic Launer Soaring 4 February 3rd 04 07:56 PM
Ventus 2CT or 2CM or DG 808b or ASH26E or LS8t John Mason Soaring 8 October 7th 03 11:18 PM
