Ratcheting tie-downs vs come-alongs?
Old July 20th 08, 03:40 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Ratcheting tie-downs vs come-alongs?
I'm trying to use a ratcheting tie-down as a comealong to move an
aircompressor to a trailer.
I'm finding that as the webbing builds up on the ratcheting barrel, it
will eventually interfer with the prawling mechanism. This limits the
distance the tie-down can pull to about 3 feet. Useless.
I've taken up as much excess as I can at the load end, but the barrel
still fills too quickly.
Any suggestions or am I using the wrong tool for the job? - MIke
Old July 20th 08, 04:32 PM posted to rec.aviation.homebuilt
John Ammeter
Definately the wrong tool... If you don't have a comealong you can use
a length of chain. Simply tension the chain and then pull sideways on
the chain (or jump on it). Granted, you won't move it very far for each
"pull" but it's another way to move objects.
BTW, how about moving the trailer to the aircompressor?? It's got
wheels, right?? ....grin....
John
Old July 20th 08, 04:52 PM posted to rec.aviation.homebuilt
Michael Horowitz
They are in close proximity; in fact they are seperated by auto ramps;
problem is getting the compressor up those ramps and onto the bed of
the trailer - Mike
On Sun, 20 Jul 2008 08:32:17 -0700, John Ammeter
John
Old July 26th 08, 03:31 AM posted to rec.aviation.homebuilt
Charlie[_2_]
'Wrong' tool, but:
If it's all you've got, you can probably find a way. If you have at
least 2 tie-downs, max out the 1st as you have already done, hook up the
2nd one, tighten & remove the 1st. Max out the 2nd, re-set & hook up
the 1st; repeat as needed.
Charlie
tie downs in the bush tom pettit Piloting 12 August 23rd 05 09:02 PM
titanium ti-downs [email protected] Home Built 0 July 15th 05 11:46 PM
FBO Insurance requirement for tie-downs Chris Owning 25 May 18th 04 07:24 PM
San Jose, CA area tie downs/ Rose Goetsch General Aviation 3 September 15th 03 04:51 AM
