Does ATC report to the FSDO landings when reported vis below min?
Old July 23rd 08, 02:18 AM posted to rec.aviation.piloting
Robert M. Gary
Default Does ATC report to the FSDO landings when reported vis below min?
This is from my FIRC study guide....
"It is still true, however, that ATC is required to report to an FAA
district office as an incident, any landing that is made when the
visibility is being reported as less than one- half mile, or the RVR
is less than the published minimums. And the pilot may be asked to
explain to the FAA the circumstances of the landing."
Sounds wrong to me.
-Robert
Old July 23rd 08, 02:31 AM posted to rec.aviation.piloting
john smith
In article
Sounds wrong to me.
I was taught that it is the pilot's visibility that matters.
Old July 23rd 08, 02:36 AM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
Sounds wrong to me.
It should. It's wrong.
Old July 23rd 08, 03:04 AM posted to rec.aviation.piloting
BT
This has been discussed during various IFR courses and refreshers.. I'm
running on old memory here.
For a Part 91 operation it is not enforceable. The tower has no way of
knowing what the pilots in-flight visibility is at the approach end of the
runway.
I have seen pure VFR on one end for 2,000ft of a 10,000 ft runway.. with the
other parts of the airport the fog so thick you could not see the lines to
taxi.
For Part 135 and other operations, the pilot cannot even begin the approach
for a "look see" if the visibility and ceiling are reported as less than
that required for the approach.
Now whether ATC reports it or not?
BT
Sounds wrong to me.
-Robert
Old July 23rd 08, 03:19 AM posted to rec.aviation.piloting
Robert M. Gary
runway.
taaxi.
Me too. Althought I believe if RVR is reported, that is enforceable.
Otherwise, my understanding is the same as yours. Only those in the
cockpit know flight vis.
Yes, but if the reported wx degrades after crossing the FAF they can
continue the approach. So perhaps if they land with reported vis below
mins they could be busted? That doesn't sound right either.
-Robert
Old July 23rd 08, 04:20 AM posted to rec.aviation.piloting
Mike[_22_]
runway.
to
taaxi.
Not even then, really. RVR vis data is not archived for one thing so all
you really have to go on is a controller's memory to begin with. For
another, if it's a Cat I RVR, there's only one sensor located at center
field. That means it could be as far away as a mile or more on a long
runway.
approach
One thing you have to understand is there are a few controllers who enjoy
busting pilots, but they are in the minority. The vast majority will give
the pilot the benefit of the doubt to the extent they are able. However
this discretion is being slowly removed at many facilities due to a
nationwide crackdown.
Old July 23rd 08, 06:11 AM posted to rec.aviation.piloting
BT
-Robert
Yes.. once the approach has passed the FAF and the weather degrades, they
can continue to MDA or MAP. If it goes down, it could come back up before
they get to the MDA/MAP/
As stated by another.. not all RVR readings on an airport are at the
approach end.
BT
Old July 23rd 08, 01:50 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
I'm running on old memory here.
of knowing what the pilots in-flight visibility is at the approach
end of th
e
runway.
with
lines t
o
taaxi.
approa
ch
than that required for the approach.
It isn't. If we continue in that scenario and see what we need at DH we
can land.
I doubt the FAA would or even could prosecute for the first circustance,
but if it were an obvious fouting of th erues they might have a go at
careless or reckless operation...
Bertie
FSDO followups on equipment probkems reported to ATC? Andrew Gideon Piloting 14 August 1st 06 02:30 AM
Honeywell Cited by FSDO in Pilot Administrative Action! Larry Dighera Piloting 3 November 5th 03 03:04 PM
Breath of Fresh Air from the FSDO Roger Long Piloting 12 October 22nd 03 12:31 AM
Reported by CNN this morning!!!!! Capt. Doug Home Built 48 July 22nd 03 03:26 AM
Reported by CNN this morning!!!!! Someguy Owning 0 July 19th 03 07:22 PM
