Yikes, that's some heavy rain. Thanks for posting it. I remember one time
departing FLL with a heavy shower off the departure end. The C-172 (and some other single Cessnas) have the air filter in the front cowl under the prop. When we got into the heavy rain it saturated the air filter and we lost some power. After a second I guessed what was happening and aplied carb heat, to take advantage of the indirect air flow bypassing the air filter, and power came back, minus the small carb heat penalty. The CFII beside me, not an A&P like me, closed the carb heat because it robs power and the engine once again started breathign through the soaked filter. I re-applied the carb heat and kept my hand on the the knob while telling the CFI "soaked air filter, leave on the carb heat." A minute later we had cleared the shower and went back to normal ops. It's the only time I've had any engine trouble and it sure gets your attention. Oh yeah, make sure you don't use a paper air filter in single Cessnas. I think an AD prevents using paper filters any more. The single Pipers don;t have this problem because of the configuration for induction airflow. -- Scott What Barack Obama learned from the Communist Party http://tinyurl.com/5bgbpu Democrats to America's drivers: "Let them ride bikes." http://tinyurl.com/5z5vg7 wrote in message ... at least by this pilot anyway :-) http://www.youtube.com/watch?v=VZTfTT-EiF8 |
On Aug 3, 3:28*pm, "tscottme" wrote:
CFI "soaked air filter, leave on the carb heat." *A minute later we had cleared the shower and went back to normal ops. *It's the only time I've had any engine trouble and it sure gets your attention. Anytime the engine hiccups while airborne will raise that pucker factor :-)) Another thing to be aware of when flying in heavy rain is to put your pitot tube heat on. Only so much room to ingest fluids and drain it out and this happened to me while I was IMC. My airspeed was dropping, yet everything indication wise with AI, RPMs, VSI all checked out straight and level. It was 58 degrees so icing wasn't a factor. My instructor told me to put on pitot heat and sure enough after a few minutes, the airspeed came up to normal indications. He had that happen to him so he recognized the problem waaaay sooner then me at that time. Sooo, anytime I am in precip in IMC, pitot heat goes on and stays on. |
"tscottme" writes:
wrote at least by this pilot anyway :-) http://www.youtube.com/watch?v=VZTfTT-EiF8 Yikes, that's some heavy rain. Thanks for posting it. I remember one time departing FLL with a heavy shower off the departure end. The C-172 (and some other single Cessnas) have the air filter in the front cowl under the prop. When we got into the heavy rain it saturated the air filter and we lost some power. After a second I guessed what was happening and aplied carb heat, to take advantage of the indirect air flow bypassing the air filter, and power came back, minus the small carb heat penalty. The CFII beside me, not an A&P like me, closed the carb heat because it robs power and the engine once again started breathign through the soaked filter. I re-applied the carb heat and kept my hand on the the knob while telling the CFI "soaked air filter, leave on the carb heat." A minute later we had cleared the shower and went back to normal ops. It's the only time I've had any engine trouble and it sure gets your attention. Oh yeah, make sure you don't use a paper air filter in single Cessnas. I think an AD prevents using paper filters any more. The single Pipers don't have this problem because of the configuration for induction airflow. Mooney Super 21's have an air filter bypass that's supposed to give a slight power boost at altitude. However, using the bypass in certain meteorlogical conditions can result in injector icing and has led to fatalities. |
Yup. This could have killed me in April of 1989.
Everett M. Greene wrote, Mooney Super 21's have an air filter bypass that's supposed to give a slight power boost at altitude. However, using the bypass in certain meteorlogical conditions can result in injector icing and has led to fatalities. |
Anyone flown atn LPV yet? | Sam Spade | Instrument Flight Rules | 40 | January 13th 07 10:28 AM |
Warm Weather Pilots, Cold Weather Ops | john smith | Piloting | 3 | December 2nd 04 04:00 PM |
has anyone flown with these ? | Damian John Paul Brown | Rotorcraft | 4 | April 16th 04 09:48 PM |
has anyone flown with these ? | Damian John Paul Brown | Aviation Marketplace | 0 | April 15th 04 04:25 AM |
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... | Roy | Piloting | 4 | July 12th 03 04:03 PM |
