Wing tie-down kit
Old August 3rd 08, 09:42 PM posted to rec.aviation.soaring
JJ Sinclair
Default Wing tie-down kit
Padded aluminum cusp that slips over trailing edge with web strap that
goes over leading edge then down to cable or stake with hooks and
ratchet for tightning. Can be easily carried in ship. E-mail me for
picture.........see Williams Soaring, set of two for $125 + shipping.
JJ
Old August 4th 08, 02:48 AM posted to rec.aviation.soaring
Rex
See this in detail at WSC online store
http://store.williamssoaring.com/Mer...tegory_Code=SP
Great device produced by JJ.
Regards,
Rex Mayes
Williams Soaring Center
Old August 4th 08, 01:10 PM posted to rec.aviation.soaring
Pete Smith
Regards,
Rex Mayes
or make it yourself for 20 bucks
Old August 4th 08, 02:02 PM posted to rec.aviation.soaring
JJ Sinclair
Yep, the materials did cost about $20 bucks, 2024-T3 (.062) + 2 hinges
& 2 cargo tie-downs and don't forget the padding and contact cement,
now find someone with a sheet metal shears and brake. Then cut, bend,
trim, rivet, glue, box and ship.....................man are we making
a killing on this?
I have used these for years and some local pilots finally got me to
make up a run, with travel time down to use the shears I have a good
15 hours into making 8 sets for a whopping $42 bucks an hour + gas (my
shop rate is $65/hr)................won't make that mistake again!
JJ
Old August 4th 08, 03:58 PM posted to rec.aviation.soaring
bumper
JJ,
I have a good
JJ
JJ,
You have infringed on the business model I have in place for the Quiet Vent
(sells for $6) and the MKII yaw string - $10. Since you did not contact me
seeking permission to license my copyrighted business model, you will either
have to raise your prices immediately or suffer the wrath of my team of
attorneys.
BTW, I also have patent pending on "Buy High Sell Low" and "Dare to be
different . . . circle in sink."
You have been warned!
bumper
Old August 4th 08, 11:33 PM posted to rec.aviation.soaring
Uncle Fuzzy
On Aug 4, 7:58*am, "bumper" wrote:
JJ,
I have a good
JJ
JJ,
attorneys.
bumper
JJ,
I wouldn't worry too much about Bumper's threats of legal action.
He also claims to have patent rights for the "Mark II Thermal
Dissaptor" and the "Mark 1 Cumulus Destroyer" which I have been
developing independently for some time. He hasn't gone through with
his threats yet, but maybe he's taking it easy on me because I
purchased a QV and MKII yaw string from him. ;-P
My non-patented Mk II yaw string monitor is still under development,
but shows promise.
Uncle "Flies with Sheep" Fuzzy
Old August 5th 08, 01:38 AM posted to rec.aviation.soaring
So who is this "Pete Smith"? Just want ya'll to know it ain't me. My
dog's not in this hunt.
Old August 6th 08, 03:29 AM posted to rec.aviation.soaring
raulb
JJ
I bought 2 back belts with velcro closing (but without the shoulder
straps) and a couple of textile motorcycle tiedown loops (not the
ratchet straps, but what you put on the bike to protect it from the
metal hooks) and had 2 excellent tiedown cuffs for less than $25
lot. For the nervous, they can be stitched.
Old August 6th 08, 02:20 PM posted to rec.aviation.soaring
JJ Sinclair
metal hooks) and had *2 excellent tiedown cuffs for less than $25
lot. *For the nervous, they can be stitched.
In the 35 years I have been in this sport I have seen 3 ships upside
down on the ramp................so when I leave the ship tied out I
make sure its adequately secured. The trailing edge cusp distributes
the load and prevents cauging flaps or ailerons. The force is all
forward and then down over the leading edge and ratchet'd down against
wing stands. I also chock both wheels.
JJ
Old August 6th 08, 06:25 PM posted to rec.aviation.soaring
raulb
I am sorry JJ. I mis-read the posts. I didn't realize you were
selling these things until after I posted. I thought I was thumbing
my nose at someone else.
Low wing landing, high wing taking off...oops [email protected] Piloting 1 May 16th 08 09:41 PM
Soft field landings - low wing vs high wing aircraft Justin Gombos Piloting 19 May 23rd 07 05:21 AM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 03:23 AM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
