exhaust manifold steel
Old August 4th 08, 07:14 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
Default exhaust manifold steel
"Stealth Pilot" wrote
I presume that you are asking about exhausts since stainless is not
used in most of GA aircraft at all.
Correct me if I'm wrong, but are many firewalls not made of stainless, or
layers of stainless and other heat resistant fibers?
Old August 5th 08, 01:22 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Stealth Pilot[_2_]
On Mon, 4 Aug 2008 14:14:26 -0400, "Morgans"
both statements are correct Jim.
most of GA aircraft are built commercially and most dont use stainless
in the firewalls.
most homebuilders though seem to favour stainless in the firewalls.
what I missed of course was his subject line.
inconel is what he wanted to know though.
Stealth Pilot
Old August 5th 08, 07:04 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
Duh! Me too!
Old August 6th 08, 06:01 PM posted to rec.aviation.homebuilt,rec.aviation.owning
*Correct me if I'm wrong, but are many firewalls not made of stainless, or
Most are stainless, as are the exhaust systems. Stainless is iron
with lots of chromium and nickel. Inconel, IIRC, is chromium and
copper, and Monel is chromium and nickel, no iron in either. That's
from memory, which is often unreliable now. Plain carbon steel mighht
be found in homebuilt exhaust systems, like mine, but their lives are
much shorter.
Dan
Old August 6th 08, 06:54 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Bob Kuykendall
On Aug 6, 10:01*am, wrote:
...Stainless is iron
copper, and Monel is chromium and nickel, no iron in either...
Actually, I think that Monel is an alloy of nickel and copper, with
trace amounts of other stuff including iron.
Thanks, Bob K.
Old August 7th 08, 04:21 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Peter Dohm
"Bob Kuykendall" wrote in message
Thanks, Bob K.
----------new post-----------
I just "googled" and found that there about a zillion Inconel alloys, but
that the primary constituents are Nickel and Chromiun with some others
including Iron and is primarily for high temperature applications.
Monel is promarily Nickel and Copper plus additional constituents and is
primarily for corrosion resistance.
Both were developments of the same company.
Peter
Old August 7th 08, 01:01 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Stealth Pilot[_2_]
On Wed, 6 Aug 2008 23:21:26 -0400, "Peter Dohm"
Thanks, Bob K.
Peter
inconel being particularly suited to aircraft exhausts because it is
more resistant to erosion of the metal by the hot exhaust gasses.
if you arent going to use inconel at least use 316 stainless for its
non magnetic qualities.
aircraft compasses are actually useful at times.
Stealth Pilot
Old August 11th 08, 09:40 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Bruce A. Frank
Actually though the 3xx series stainless can develop magnetic response,
sometimes very strong, 302, 303 and 304 grades in particular, from cold
working they can be annealed at about 800 degrees C which eliminates the
response. 310 and 316 remain virtually response free from cold working.
321 is extremely heat resistant and therefore can be used in thinner
sections to save weight. In the fully annealed condition it is free of
any magnetic response. Unless the engine is some wildly modified racing
setup dumping three foot flames out of the exhaust stacks, very thin 321
will likely make it through the TBO of the engine. 316 will also, but
would need to be just a bit thicker walled tube to begin with.
The more exotic alloys monel, inconel, hastaloy and so on, are not
necessary for normal installations. Ceramic coated mild steel headers
are some of the smoothest flowing and will also last to most engine's
TBO.
As for headers made of materials that are magnetically responsive, I
have ridden in a lot of homebuilts with exhaust headers made of muffler
shop steel...heck, many of the engines had cast iron and steel blocks,
and there was never a compass problem once standard compensation methods
were made when the compass was installed. TIG welded steel tube
fuselages present more of a compass deviation problem than the exhaust
stacks located a couple of feet away. Even with a certified type
aviation engine, if the mag compass deviation were a problem, there is
still a pretty good size chunk of iron in the crank and rods to attract
that needle. Hasn't been a problem about which I've heard a lot of
complaint.
Thanks, Bob K.
Peter
Stealth Pilot
exhaust manifold steel Dave Home Built 12 September 3rd 08 09:30 AM
Stainless steel exhaust headwind Home Built 5 February 14th 07 03:30 AM
Manifold Pressure at Rest Andrew Gideon Piloting 23 August 20th 04 05:23 PM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
O/T Carb and Manifold for sale someone Home Built 2 December 31st 03 06:33 PM
