Battery cable selection
Old August 4th 08, 08:21 PM posted to rec.aviation.homebuilt
Default Battery cable selection
I am putting two 12V batteries together
http://www.batterymart.com/p-hawker-...t-battery.html
to make a 24V battery.
What size cable should I use to make the serial connection?
http://shop.genuinedealz.com/Marine%...ttery%20Cable/
Karl
Old August 4th 08, 08:31 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Same size as the main battery cable. It will see the same amperage.
Old August 4th 08, 09:13 PM posted to rec.aviation.homebuilt
Philippe[_2_]
Longer the cable, bigger the cable...
connect two batteries with a 1"cable: a 6AWG cable will work
flat copper bar will be better (less losses):
http://www.aircraftspruce.com/catalo...ges/busbar.php
by
Volem rien foutre al païs!
Philippe Vessaire Ò¿Ó¬
** Posted from http://www.teranews.com **
Old August 4th 08, 09:36 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
no, it will see half the amperage at same wattage
"Morgans" schrieb im Newsbeitrag
Old August 4th 08, 10:08 PM posted to rec.aviation.homebuilt
Vaughn Simon
"oilsardine" wrote in message ...
Huh? You are joking...right?
Vaughn
Capt. Geoffrey Thorpe
No Jim was correct. The amperage is the same.
It is a series circuit - the amperage is the same throughout.
If you were wiring two batteries in parallel (and getting 12 volts from the
pair), then each battery would deliver 1/2 the amps (approx.)
Geoff
Old August 4th 08, 11:45 PM posted to rec.aviation.homebuilt
RST Engineering
Kirchoff is rolling over in his grave.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
Old August 5th 08, 12:40 AM posted to rec.aviation.homebuilt
Dale Scroggins[_2_]
"Philippe" wrote in message
news:1770438.ul5SB0L1ai@GastonCoute...
by
A copper bar would indeed work much better than a short cable. If you plan
to join two standard aircraft batteries sharing the same battery box, a
well-fitted copper bar is easier to install than a cable.
You can make a bar by flattening a short section of 1/2" thick-wall copper
tubing (as used for refrigeration lines) in a vise and drilling two 5/16"
holes the correct distance apart (about two inches I think, but you should
measure). Coat it with grease each time it's installed or it will corrode
rapidly.
Beech Barons use a similar copper bar, tin-plated as I recall. You could
buy one.
Old August 5th 08, 12:54 AM posted to rec.aviation.homebuilt
Peter Dohm
"RST Engineering" wrote in message
m...
He obviously needs the exercise.... ;-)
Peter
Node theory sux!
Old August 5th 08, 06:44 AM posted to rec.aviation.homebuilt
Dan[_12_]
by
plan to join two standard aircraft batteries sharing the same battery
box, a well-fitted copper bar is easier to install than a cable.
copper tubing (as used for refrigeration lines) in a vise and drilling
two 5/16" holes the correct distance apart (about two inches I think,
but you should measure). Coat it with grease each time it's installed
or it will corrode rapidly.
could buy one.
The truly energetic could tin the bar with solder or, wait for it, tin.
Dan, U.S. Air Force, retired
Battery Cable Connectors Paul Remde Soaring 0 September 15th 06 05:33 AM
France from the air : selection Benoit Piloting 1 December 19th 04 05:42 PM
Engine selection Omri Kalinsky Home Built 1 November 18th 04 10:06 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
