" On July 07, 2008, at 1755 eastern daylight time, an experimental,
Douglas A. Pohl, amateur built, Lancair IV-P, N488SD, crashed after a loss of engine power at the North Perry Airport (HWO), Hollywood, Florida. The pilot was killed and the airplane was destroyed. The flight was operated by a private individual, under the provisions of 14 Code of Federal Regulations Part 91 as a personal flight. Visual meteorological conditions prevailed and no flight plan was filed. Witnesses stated to the responding Federal Aviation Administration inspector that they observed the airplane depart from runway 9R. When the airplane was at an estimated altitude of 150 feet above the ground, the engine lost power; one witness stated, it sounded like an 18 wheeler down shifting, another stated, it lost power completely. Immediately following the loss of power, the airplane was observed to make a left turn. It continued the turn increasing the bank angle. The airplane stalled when it reached about 80 degrees of bank. It impacted the ground nose first. The airplane came to rest on a 20 foot tall tennis court fence. A fire ensued moments later, which consumed most of the airplane. " http://www.ntsb.gov/ntsb/brief.asp?e...19X01077&key=1 With all the houses at the end of the runway he probably couldn't think what else to do but such a steep turn is a bad mistake. Development within the takeoff/landing fans close to airports should be limited to golf courses and parks IMO. Cheers |
More_Flaps wrote:
" On July 07, 2008, at 1755 eastern daylight time, an experimental, Douglas A. Pohl, amateur built, Lancair IV-P, N488SD, crashed after a loss of engine power at the North Perry Airport (HWO), Hollywood, Florida. The pilot was killed and the airplane was destroyed. The flight was operated by a private individual, under the provisions of 14 Code of Federal Regulations Part 91 as a personal flight. Visual meteorological conditions prevailed and no flight plan was filed. Witnesses stated to the responding Federal Aviation Administration inspector that they observed the airplane depart from runway 9R. When the airplane was at an estimated altitude of 150 feet above the ground, the engine lost power; one witness stated, it sounded like an 18 wheeler down shifting, another stated, it lost power completely. Immediately following the loss of power, the airplane was observed to make a left turn. It continued the turn increasing the bank angle. The airplane stalled when it reached about 80 degrees of bank. It impacted the ground nose first. The airplane came to rest on a 20 foot tall tennis court fence. A fire ensued moments later, which consumed most of the airplane. " http://www.ntsb.gov/ntsb/brief.asp?e...19X01077&key=1 With all the houses at the end of the runway he probably couldn't think what else to do but such a steep turn is a bad mistake. Development within the takeoff/landing fans close to airports should be limited to golf courses and parks IMO. Cheers If the Paul J Maxwell Park wasn't on the airport grounds he probably could have made the turn North and landed it. Either that or go for SW 13th St. http://maps.google.com/maps?ie=UTF8&...,0.009613&z=17 |
On Aug 6, 3:53*pm, Gig 601Xl Builder
wrote: More_Flaps wrote: " On July 07, 2008, at 1755 eastern daylight time, an experimental, Douglas A. Pohl, amateur built, Lancair IV-P, N488SD, crashed after a loss of engine power at the North Perry Airport (HWO), Hollywood, Florida. The pilot was killed and the airplane was destroyed. The flight was operated by a private individual, under the provisions of 14 Code of Federal Regulations Part 91 as a personal flight. Visual meteorological conditions prevailed and no flight plan was filed. Witnesses stated to the responding Federal Aviation Administration inspector that they observed the airplane depart from runway 9R. When the airplane was at an estimated altitude of 150 feet above the ground, the engine lost power; one witness stated, it sounded like an 18 wheeler down shifting, another stated, it lost power completely. Immediately following the loss of power, the airplane was observed to make a left turn. It continued the turn increasing the bank angle. The airplane stalled when it reached about 80 degrees of bank. It impacted the ground nose first. The airplane came to rest on a 20 foot tall tennis court fence. A fire ensued moments later, which consumed most of the airplane. " http://www.ntsb.gov/ntsb/brief.asp?e...19X01077&key=1 With all the houses at the end of the runway he probably couldn't think what else to do but such a steep turn is a bad mistake. Development within the takeoff/landing fans close to airports should be limited to golf courses and parks IMO. Cheers If the Paul J Maxwell Park wasn't on the airport grounds he probably could have made the turn North and landed it. Either that or go for SW 13th St. http://maps.google.com/maps?ie=UTF8&...WO),&near....- Hide quoted text - - Show quoted text - Looks like he had two good choices, SW13 and SW14 streets. I'd go for the one with the fewest parked cars. |
... On Aug 6, 3:53 pm, Gig 601Xl Builder wrote: More_Flaps wrote: " On July 07, 2008, at 1755 eastern daylight time, an experimental, Douglas A. Pohl, amateur built, Lancair IV-P, N488SD, crashed after a loss of engine power at the North Perry Airport (HWO), Hollywood, Florida. The pilot was killed and the airplane was destroyed. The flight was operated by a private individual, under the provisions of 14 Code of Federal Regulations Part 91 as a personal flight. Visual meteorological conditions prevailed and no flight plan was filed. Witnesses stated to the responding Federal Aviation Administration inspector that they observed the airplane depart from runway 9R. When the airplane was at an estimated altitude of 150 feet above the ground, the engine lost power; one witness stated, it sounded like an 18 wheeler down shifting, another stated, it lost power completely. Immediately following the loss of power, the airplane was observed to make a left turn. It continued the turn increasing the bank angle. The airplane stalled when it reached about 80 degrees of bank. It impacted the ground nose first. The airplane came to rest on a 20 foot tall tennis court fence. A fire ensued moments later, which consumed most of the airplane. " http://www.ntsb.gov/ntsb/brief.asp?e...19X01077&key=1 With all the houses at the end of the runway he probably couldn't think what else to do but such a steep turn is a bad mistake. Development within the takeoff/landing fans close to airports should be limited to golf courses and parks IMO. Cheers If the Paul J Maxwell Park wasn't on the airport grounds he probably could have made the turn North and landed it. Either that or go for SW 13th St. http://maps.google.com/maps?ie=UTF8&...HWO),&near...- Hide quoted text - - Show quoted text - Looks like he had two good choices, SW13 and SW14 streets. I'd go for the one with the fewest parked cars. ---------new post--------- Given the combination of torque and wing loading, and the probable climb angle, there could be much more in play than the "impossible turn" scenario. Given the past reliability of publicly available eye witnesses, I think that I might wait for a little more information from known sources before I add my own pet hypothesis. Peter |
"Peter Dohm" wrote in message
... wrote in message ... On Aug 6, 3:53 pm, Gig 601Xl Builder wrote: More_Flaps wrote: " On July 07, 2008, at 1755 eastern daylight time, an experimental, Douglas A. Pohl, amateur built, Lancair IV-P, N488SD, crashed after a loss of engine power at the North Perry Airport (HWO), Hollywood, Florida. The pilot was killed and the airplane was destroyed. The flight was operated by a private individual, under the provisions of 14 Code of Federal Regulations Part 91 as a personal flight. Visual meteorological conditions prevailed and no flight plan was filed. Witnesses stated to the responding Federal Aviation Administration inspector that they observed the airplane depart from runway 9R. When the airplane was at an estimated altitude of 150 feet above the ground, the engine lost power; one witness stated, it sounded like an 18 wheeler down shifting, another stated, it lost power completely. Immediately following the loss of power, the airplane was observed to make a left turn. It continued the turn increasing the bank angle. The airplane stalled when it reached about 80 degrees of bank. It impacted the ground nose first. The airplane came to rest on a 20 foot tall tennis court fence. A fire ensued moments later, which consumed most of the airplane. " http://www.ntsb.gov/ntsb/brief.asp?e...19X01077&key=1 With all the houses at the end of the runway he probably couldn't think what else to do but such a steep turn is a bad mistake. Development within the takeoff/landing fans close to airports should be limited to golf courses and parks IMO. Cheers If the Paul J Maxwell Park wasn't on the airport grounds he probably could have made the turn North and landed it. Either that or go for SW 13th St. http://maps.google.com/maps?ie=UTF8&...HWO),&near...- Hide quoted text - - Show quoted text - Looks like he had two good choices, SW13 and SW14 streets. I'd go for the one with the fewest parked cars. ---------new post--------- Given the combination of torque and wing loading, and the probable climb angle, there could be much more in play than the "impossible turn" scenario. Given the past reliability of publicly available eye witnesses, I think that I might wait for a little more information from known sources before I add my own pet hypothesis. Peter My local source stated that the aircraft had a reduction drive, which failed catastrophically, and left the engine still turning. Sorry about the long delay, and no other usefull information available. Peter |
| Thread Tools | |
| Display Modes | |
| "Imagine the impossible and do it." Dr. Paul MacCready Dies In His Sleep August 28, 2007 | Larry Dighera | Piloting | 1 | August 31st 07 08:54 PM |
| Myth: 1 G barrel rolls are impossible. | Jim Logajan | Piloting | 244 | June 22nd 07 05:33 AM |
| Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 12th 04 12:45 AM |
| bush: impossible to be AWOL /check TEXAS MILITARY CODE! | Bob | Military Aviation | 9 | September 21st 04 09:48 PM |
| bush: impossible to be AWOL (do vets give a sh!t) | B2431 | Military Aviation | 7 | September 8th 04 05:20 PM |
