Abrupt Controller
Old August 7th 08, 02:27 PM posted to rec.aviation.ifr
Kobra
Default Abrupt Controller
Flyers,
I'll run this scenario past the group and see what you all think and is if
Mr. McNicoll can shed some light as well.
First, some quick background. At my airport if you are IFR and are heading,
say, southwest (as I was) it's too bad...you're clearance is to send you 22
miles north to a fix and then 15 mile east to another fix and then they will
turn you on course. Usually, if asked, you can get direct on course shortly
after take-off. If traffic permits they will clear you to go direct to your
first filed fix on course.
Ok so...I took-off on an IFR flight plan and I had just leveled off at 4000'
north bound for their fix. Next they gave me a vector of 090. After a
minute or so I asked the controller, "McGuire Approach, Cardinal 07G, any
chance direct Smyrna (ENO)?" The response I got was, "07G direct Smyrna
unable." Ok...that would be fine if that was what my busy brain heard, but
I did not hear it that way...my brain heard, "07G direct Smyrna 'when
able'." Shortly after I turned direct for ENO I got a VERY large lecture
with unneeded and unnecessary attitude. "07G I TOLD YOU STAY 090. CAN'T
YOU LISTEN OR UNDERSTAND ATC INSTRUCTIONS? WHEN I GIVE YOU A VECTOR YOU ARE
TO FOLLOW IT EXACTLY AND CAREFULLY!!"
When I explained to him that I heard him say, "...direct ENO when able." he
became even more belligerent. "I DID *NOT* SAY THAT!! YOU NEED TO LISTEN
TO ATC INSTRUCTION MORE CAREFULLY AND FOLLOW MY INSTRUCTION EXACTLY."
Whoa! Like I needed to know any of that and like anyone needs to be yelled
at over the airwaves with an attitude. This controller was a young military
male for what any of that is worth.
Granted I heard him wrong and I made a mistake. But I think the controller
needs to take some responsibility for using confusing verbiage and surely it
was unprofessional to lay me out like that. This reminds me of how a
mid-air occurred in LA because a new controller took time to admonish a GA
pilot for a couple minutes while a commercial plane and a Piper collided
right in front of him on his screen.
So my question to Steve McNicoll is...is that standard verbiage to say,
"...direct Smyrna 'unable'??. 'cause I'm here to tell ya that, that can be
EASILY confused with 'direct Smyrna 'when able'. What's your thoughts on
this and did he use proper language or did he just use poor phraseology?
Kobra
Old August 7th 08, 02:53 PM posted to rec.aviation.ifr
Sam Spade
I'll leave the comments about your handling to others, but your
characterization of that 1986 tragedy over Cerritos, CA is grossly
misleading.
The NTSB found no fault with the controller working those aircraft. In
fact, he is a highly regarded airspace manager today.
The Piper pilot was illegally within the TCA (Class B airspace).
Old August 7th 08, 04:08 PM posted to rec.aviation.ifr
Kobra
"Sam Spade" wrote in message
GA pilot for a couple minutes while a commercial plane and a Piper
collided right in front of him on his screen.
misleading.
Hello Sam,
I did not mean to be misleading and of course I don't have all the facts.
Using only the information I do have, I feel it a fact that he spent
needless time lecturing a GA pilot who was also illegally in the TCA. It
would not be a stretch to infer that this distracted him from his scope. No
one can say that it's not *possible* or even likely that if he didn't give
his lecture that he may have seen the conflict and warned the airliner about
the VFR target's position and direction of flight with the typical "altitude
known".
Hey, who knows, but I am surprised yet happy that this person came back to
the FAA and ATC. The show *Air Emergency* (which is how I learned about
this) made it appear that once he came back to work, he immediately decided
that ATC was not for him and he never worked for ATC again. I'm happy
everything worked out for him. I felt really bad for him when I saw the
show.
Kobra
Old August 7th 08, 04:59 PM posted to rec.aviation.ifr
Mxsmanic
Kobra writes:
known".
show.
If this is the one, I see no mention of ATC distraction:
NTSB Identification: DCA86AA041A.
The docket is stored on NTSB microfiche number 31249.
Scheduled 14 CFR Part 129: Foreign AERONAVES DE MEXICO, S.A.
Accident occurred Sunday, August 31, 1986 in CERRITOS, CA
Probable Cause Approval Date: 3/7/1988
Aircraft: McDonnell Douglas DC-9-32, registration: XAJED
Injuries: 82 Fatal, 8 Minor.
The Safety Board's full report on this investigation is provided as Aviation
Accident Report number AAR-87/07. To obtain a copy of this report, or to view
the executive summary online, please see the Web site at
http://www.ntsb.gov/publictn/publictn.htm
AT APRX 1140 PDT, A PIPER PA-28, N4891F, DEPARTED TORRANCE, CA ON A VFR FLT TO
BIG BEAR, CA. AFTER TAKEOFF, THE PLT TURNED EASTBOUND TWD THE PARADISE VORTAC
WITH HIS X-PONDER SQUAWKING 1200. AT THAT TIME, AEROMEXICO FLT 498 (DC-8, MEX
REGISTRY XA-JED) WAS ON ARRIVAL, RCVG NORTHBOUND VECTORS FM LAX APCH CTL (AR-1
CTLR) FOR AN ILS APCH TO THE LAX INTL ARPT. AT 1151:04, THE CTLR ASKED FLT 498
TO RDC SPD TO 190 KTS & DSCND FM 7000' TO 6000'. DRG THIS TIME, THE CTLR WAS
CTLG OTR TRAFFIC & PROVIDING RADAR ADVISORIES, BUT DIDN'T SEE A DISPLAY FOR
N4891F ON HIS SCOPE. AT 1152:09, N4891F & FLT 498 CONVERGED & COLLIDED AT APRX
6560', THEN FELL TO THE GND. AN INV REVEALED N4891F HAD INADVERTENTLY ENTERED
THE LAX TERMINAL CONTROL AREA (TCA) & WASN'T IN RADIO CONTACT WITH ATC. LAX
TRACON WASN'T EQUIPPED WITH AN AUTO CONFLICT ALERT SYS & THE ANALOG BEACON
RESPONSE FM N4891F'S X-PONDER WASN'T DISPLAYED DUE TO EQUIP CONFIGURATION.
N4891F'S PSN WAS DISPLAYED BY AN ALPHANUMERIC TRIANGLE, BUT THE PRIMARY TARGET
WASN'T DISPLAYED DUE TO AN ATMOSPHERIC INVERSION.
The National Transportation Safety Board determines the probable cause(s) of
this accident as follows:
RADAR,APPROACH/DEPARTURE..INADEQUATE
PROCEDURE INADEQUATE..FAA(OTHER/ORGANIZATION)
Contributing Factors
IDENTIFICATION OF AIRCRAFT ON RADAR..NOT ATTAINED
PROCEDURES/DIRECTIVES..NOT FOLLOWED..PILOT OF OTHER AIRCRAFT
UNSAFE/HAZARDOUS CONDITION..INADVERTENT..PILOT OF OTHER AIRCRAFT
VISUAL LOOKOUT..INADEQUATE..PILOT OF OTHER AIRCRAFT
VISUAL LOOKOUT..INADEQUATE..PILOT IN COMMAND
Old August 8th 08, 01:18 AM posted to rec.aviation.ifr
Buster Hymen
Mxsmanic wrote in
Kobra writes:
facts. Using only the information I do have, I feel it a fact that he
spent needless time lecturing a GA pilot who was also illegally in
the TCA. It would not be a stretch to infer that this distracted him
from his scope. No one can say that it's not *possible* or even
likely that if he didn't give his lecture that he may have seen the
conflict and warned the airliner about the VFR target's position and
direction of flight with the typical "altitude known".
back to the FAA and ATC. The show *Air Emergency* (which is how I
learned about this) made it appear that once he came back to work, he
immediately decided that ATC was not for him and he never worked for
ATC again. I'm happy everything worked out for him. I felt really
bad for him when I saw the show.
Aviation Accident Report number AAR-87/07. To obtain a copy of this
report, or to view the executive summary online, please see the Web
site at http://www.ntsb.gov/publictn/publictn.htm
VFR FLT TO BIG BEAR, CA. AFTER TAKEOFF, THE PLT TURNED EASTBOUND TWD
THE PARADISE VORTAC WITH HIS X-PONDER SQUAWKING 1200. AT THAT TIME,
AEROMEXICO FLT 498 (DC-8, MEX REGISTRY XA-JED) WAS ON ARRIVAL, RCVG
NORTHBOUND VECTORS FM LAX APCH CTL (AR-1 CTLR) FOR AN ILS APCH TO THE
LAX INTL ARPT. AT 1151:04, THE CTLR ASKED FLT 498 TO RDC SPD TO 190
KTS & DSCND FM 7000' TO 6000'. DRG THIS TIME, THE CTLR WAS CTLG OTR
AT APRX 6560', THEN FELL TO THE GND. AN INV REVEALED N4891F HAD
INADVERTENTLY ENTERED THE LAX TERMINAL CONTROL AREA (TCA) & WASN'T IN
RADIO CONTACT WITH ATC. LAX TRACON WASN'T EQUIPPED WITH AN AUTO
CONFLICT ALERT SYS & THE ANALOG BEACON RESPONSE FM N4891F'S X-PONDER
WASN'T DISPLAYED DUE TO EQUIP CONFIGURATION. N4891F'S PSN WAS
DISPLAYED BY AN ALPHANUMERIC TRIANGLE, BUT THE PRIMARY TARGET WASN'T
cause(s) of this accident as follows:
Nobody cares what you see, you moron.
Old August 7th 08, 05:19 PM posted to rec.aviation.ifr
Sam Spade
misleading.
Hello Sam,
known".
show.
Kobra
You should read the full NTSB report. I found it on-line this morning
with a Google search:
http://amelia.db.erau.edu/reports/ntsb/aar/AAR87-07.pdf
The Piper's primary target didn't show because of a weather inversion.
Because he was sqawking 1200 his beacon return was rudimentary (which
the NTSB did find fault with).
The other aircraft that violated the TCA was being worked by the
controller. When he determined (no mandatory Mode C at the time) that
the aircraft was inside the TCA without a clearance the controller made
it clear that he was inside the airspace and that he needed to use his
TCA chart more dilgently. It was an appropriate response to the
intrustion; not a tirade.
Traffic was light for LAX airspace, and there were two controllers on
this position. Had they both had their eyes glued on the DC-9 they
still couldn't have detected a potential mid-air in the making. The
technology at the time was just too crappy.
Old August 7th 08, 04:54 PM posted to rec.aviation.ifr
Mxsmanic
Kobra writes:
Where was your readback?
Had you read back the instructions, the chances of any confusion would have
been greatly reduced. You should always read things back.
When was this?
If you read back "when able" after he says "unable," he'll probably catch it
and correct you. If you don't read anything back, you never know.
Old August 7th 08, 05:51 PM posted to rec.aviation.ifr
Viperdoc
Anthony, where do you get off telling a real IFR rated pilot about how he
should read back instructions, when you have never been at the controls of
anything other than a computer game? Do you even remotely think that talking
with play controllers in any way mimics the real IFR environment?
Get a clue- you don't know anything about flying IFR or in IMC.
Old August 7th 08, 08:07 PM posted to rec.aviation.ifr
Kobra
I read it back and just like me he heard what his brain expected to hear:
'unable' when I actually said 'when able' . I wish I thought of that while
I was being reprimanded. I was just too busy flying, being embarrassed and
head scratching trying to figure out how this whole misunderstanding took
place.
But as I said before, the big issue with me was the way he snapped. I just
think he was a young man, given a little authority, probably a junior
trainee controller sitting with him, I'm in charge and fear me attitude and
probably having a bad day.
Kobra
Old August 7th 08, 09:23 PM posted to rec.aviation.ifr
Peter Clark
place.
I seem to recall that ATC isn't responsible for not correcting
mis-heard readbacks so don't count on that, ever. Now, were it me:
1) File an ASRS form, now.
2) WRT the instruction, I would have thought the prefered method would
have been "aircraft, unable Smyrna." As you mention, "Smyrna
unable" is confusing. In fact, if I read the 7110.65 right, he wasn't
in compliance with the approved terminology in 2-1-18(c):
2-1-18: Operational requests
c. State the word “UNABLE” and, time permitting,
a reason.
PHRASEOLOGY-
UNABLE (requested operation).
and when necessary,
(reason and/or additional instructions.)
3) Never get into an on-air discussion. Just shush and go on to the
next sector. It's not worth the airtime, regardless of what the guy
on the ground is doing. You have better things to be doing, like
flying the aircraft. If you want to get into it later after you
landed, ask for the controller's initials, note the time, and then
call his facility and ask for the supervisor or QA guy. They'll take
the information and pull the tapes.
Controller screwed up? Paul Tomblin Piloting 51 September 14th 07 09:59 PM
Helpful controller Ridge Piloting 3 July 12th 07 11:57 PM
Anyone ever hear this from a controller Kobra Instrument Flight Rules 17 April 27th 07 07:04 PM
What was controller implying?? Bill J Instrument Flight Rules 65 September 28th 04 12:32 AM
Controller Forum Greg Esres Instrument Flight Rules 3 August 2nd 03 03:53 AM
