OK, these are trivial, but nonetheless been bugging me and the guys at
the airport don't have a satisfying answer; 1. Why do wing tip vortices sink? They're not made out of lead. 2. 747 overflies at FL 310 (or whatever). Is the weight of the airplane ultimately supported by the earth's crust? How? FWIW, my opinions on these: #1: because of a general downwards movement of air in the wake, induced by lift. I've also heard that the turbulence causes locally increased pressure and thus density, but I s'pose it was also create locally reduced pressure -- so I don't believe that factor. #2: Yes, the wake of a overflying aircraft will cause a downward acceleration of the air, which reacts with the surface of the ground creating a locally higher pressure when it decelerates. Of course the effect at FL310 is spread over such a large area that the effect at any point is incredibly small, but it is spread over such a large area that it in effect is supporting the weight of the A/C. Ground effect at FL310 anyone? T |
| Thread Tools | |
| Display Modes | |
| Just wondering..... | [email protected] | Soaring | 7 | April 4th 06 04:13 AM |
| Wake vortices... a sterile danger? | Ramapriya | Piloting | 20 | December 20th 05 06:36 PM |
| Just wondering... | Fritz | Piloting | 7 | June 19th 05 06:03 AM |
| Wondering about the F-102... | Bill McClain | Military Aviation | 49 | February 22nd 04 04:54 PM |
| I was wondering | Badwater Bill | Home Built | 2 | August 6th 03 05:38 AM |
