B-1B gets Sniper targeting pods
Old August 19th 08, 07:43 AM posted to rec.aviation.military.naval,rec.aviation.military
Tiger
Default B-1B gets Sniper targeting pods
http://www.strategypage.com/htmw/hta.../20080815.aspx
B-1B Gets A Legal Sniper
August 15, 2008: On August 4th, a U.S. B-1B heavy bomber used a Sniper
targeting pod in combat for the first time. These pods enable the
aircraft crew to see, in great detail, what's happening on the ground,
even when the aircraft is flying at 20,000 feet altitude. For example,
the pod users can tell if someone down there is dressed as a man or a
woman, or is carrying a weapon.
It was five years ago that the U.S. first experimented with putting a
Litening targeting pod on B-52s. Three years later, Sniper XR targeting
pods were installed on some B-1B bombers. It proved legally and
technically difficult to get the pods working on the B-1B. The legal
issue had to do with nuclear disarmament treaties (that reclassified
B-1Bs as non-nuclear bombers, but required negotiation to change the
equipment mounted on the outside of the aircraft.) The technical issues
had to do with installing the pod and associated electronics in an
aircraft that was not designed for such gear.
B-52s used these pods for finding and attacking targets during the 2003
invasion of Iraq. Currently, B-52s are using the pods for finding and
targeting ships at sea, then using their targeting pods to hit moving
ships with laser guided bombs. But the pods can also be used for
intelligence collection, as remarkably detailed photos and videos can be
made from high altitudes.
The latest generation of these pods contain FLIR (video quality night
vision infrared radar) and TV cameras that enable pilots flying at
20,000 feet to clearly make out what is going on down there. The pods
also contain laser designators for laser guided bombs, and laser range
finders that enable pilots to get coordinates for JDAM (GPS guided)
bombs. Safely outside the range of most anti-aircraft fire (five
kilometers up, and up to fifty kilometers away), pilots can literally
see the progress of ground fighting, and have even been acting as aerial
observers for ground forces. These new capabilities also enable pilots
to more easily find targets themselves, and hit them with highly
accurate laser guided or JDAM bombs. While bombers still get target
information from ground controllers for close (to friendly troops) air
support, they can now go searching on their own, in areas where there
are no friendly ground troops.
The air force would rather use similar targeting capabilities on UAVs
(like Predator or Reaper) for this kind of intelligence work. But one
B-1B can cover most of the smart bomb needs for Iraq or Afghanistan. So
it makes sense to have these aircraft equipped with a targeting pod, to
help with finding and identifying targets, as well as checking on the
damage later.
Eighteen years ago, the first targeting pods (the U.S. two pod LANTIRN
system) were nearly ready for service. These electronic pods, that
looked like a thin bomb, were hung under the wings of fighters, and
contained laser designators and night vision equipment. The LANTIRN got
a workout in the 1991 Gulf War, even though the system was still
undergoing testing.
Israel soon followed with a cheaper (each LANTIRN cost two million
dollars), more reliable and more capable Litening system. American
manufacturers then brought out the Sniper XR pod. All this competition
has made the pods (one pod is all that is needed now) more capable,
easier to use, more reliable and cheaper.
Old August 19th 08, 02:33 PM posted to rec.aviation.military.naval,rec.aviation.military
a425couple
"Tiger" wrote ...
Interesting and informative, Thank you.
Sniper Job Richard Oh! Naval Aviation 0 February 13th 07 10:03 AM
Predator w/Sniper Rifle 2 Dav1936531 Military Aviation 7 May 22nd 04 09:25 PM
Predator w/ Sniper Rifle Dav1936531 Military Aviation 31 May 17th 04 10:00 PM
TV Stations Targeting GA Security to Boost Ratings Dan Hoehn General Aviation 0 May 14th 04 08:09 PM
AAM targeting... Lynn in StLou Naval Aviation 11 March 21st 04 05:04 AM
