Interesting balance job. New Safari and initial balance run. Blades rough
tracked at 300 rpm and a balance run made skids on concrete. Added some washers using the "Add Opposite" rule but not much change and phase angle stayed pretty much the same. For an interest, put the helicopter up on rubber to cancel out any reflected vibrations. What do you think? The same ips but 180 degree change in phase. Did the skids on concrete create a reflection that gave the balancer a 180 phase shift? Got a good set of vibration absorbing rubber pads with 3/4" plywood tops. Will repeat the test. One thing about helicopters, I don't get bored. Sti |
![]() "Stuart & Kathryn Fields" wrote in message .. . Interesting balance job. New Safari and initial balance run. Blades rough tracked at 300 rpm and a balance run made skids on concrete. Added some washers using the "Add Opposite" rule but not much change and phase angle stayed pretty much the same. For an interest, put the helicopter up on rubber to cancel out any reflected vibrations. What do you think? The same ips but 180 degree change in phase. Did the skids on concrete create a reflection that gave the balancer a 180 phase shift? Got a good set of vibration absorbing rubber pads with 3/4" plywood tops. Will repeat the test. One thing about helicopters, I don't get bored. Sti Repeated the previous balance runs with helicopter setting on vibration pads with 3/4" plywood tops. Results: Balancing @ 300 main rotor rpm got balance down to 0.04ips. The best I've ever seen on a Safari main rotor. Tail rotor, @1600rpm, is always a problem when running on concrete, was balanced down to 0.1ips. Remains to final tune main to 500rpm and tail to 2750. Some 180 phase flippining was noted on the DSS MicroVib balancer. While this phase change can be a nuisance, if you know that it can happen, it usually only costs a run or two. |
L23 weight and balance | Tony Verhulst | Soaring | 5 | December 31st 05 01:54 AM |
Weight and Balance | JP | Piloting | 2 | January 13th 04 10:54 AM |
Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 02:57 AM |
Interested in Rotor Track and Balance? Go here... | Glenn | Rotorcraft | 1 | August 15th 03 06:29 PM |
Looking for out of service main rotor blades for testing new rotor | Wright1902Glider | Home Built | 9 | July 28th 03 06:06 AM |
