Removing factory scale from tubing?
Old August 31st 08, 09:57 PM posted to rec.aviation.homebuilt
mhorowit
Default Removing factory scale from tubing?
Besides abrasive blasting, or sanding, how do you remove the black
scale from factory/Spruce fresh tubing? - Mike
Old September 1st 08, 04:49 AM posted to rec.aviation.homebuilt
Ernest Christley
I've been told that you don't, and I didn't. Just give it a rough
sanding to improve paint adhesion and paint it.
Old September 1st 08, 12:26 PM posted to rec.aviation.homebuilt
Michael Horowitz
On Sun, 31 Aug 2008 23:49:43 -0400, Ernest Christley
I like that - Mike
Old September 2nd 08, 01:40 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Mon, 01 Sep 2008 07:26:35 -0400, Michael Horowitz
I like that - Mike
michael you should never abrasive blast aircraft parts.
you bead blast them. the difference is that "beads" are round and
produce a compressed surface which is resistant to fatigue failure.
grit blasting uses sharp edged particles that can leave millions of
sharp stress raising dents which may reduce the fatigue life.
Stealth Pilot
Gauge of tubing??? Michael Horowitz Home Built 7 June 6th 06 01:32 PM
4130 steel tubing? TJ400 Home Built 2 May 30th 06 09:21 PM
how do I weld aircraft tubing [email protected] Aviation Marketplace 1 May 10th 06 08:39 AM
The Definitive Chord & Scale Bible - Literally EVERY chord and scale! Kind of Blue298 Home Built 0 February 8th 05 05:51 PM
Tubing strength Ernest Christley Home Built 0 January 16th 04 11:43 PM
