mode c intermittent
Old September 4th 08, 02:32 AM
skyav8r skyav8r is offline
Junior Member
First recorded activity by AviationBanter: Sep 2008
Default mode c intermittent
Howdy,
I have an Aeromech 8140B20 encoding altimeter with a KT76 transponder. Mode C is intermittent with ATC. Is it more than likely this is an altimeter problem or transponder problem? Sometimes when it is not reporting, i cycle the transponder off then back on and it starts reporting again. That works about 30 percent of the time, if that much. Thanks in advance,
Brian
Also, sould an aeromech and aerosonic encoding altimeter interchange as far as the connections are concerned?
mode c intermittent skyav8r Owning 0 September 4th 08 02:32 AM
Intermittent failures all weekend Ron Natalie Piloting 5 March 25th 07 06:25 PM
Air Force investigating intermittent engine failure on aircraft. SPLASH-TWO Aviation Photos 25 November 23rd 06 07:34 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 08:40 AM
C182 - Intermittent Alternator WinstonCup Owning 9 November 12th 04 01:22 AM
