Carb heat: my new policy. Any comments
Old September 6th 08, 05:58 PM posted to rec.aviation.piloting
Tman
Default Carb heat: my new policy. Any comments
Flying a lot of 152s and 172s with carb heat lately. When inbound, I've
been taught to pull the carb heat "on" downwind, hey actually use it as
a power control to slow the plane just a bit mid-field, and then more
importantly, just leave the thing on till clear of the runway and
cleaning up. No matter what the temp, humidity. And to have it on at
all times when the RPM is less than the green band. Kind of a preventative.
A few times I have been coming in on short final and needed a burst of
power due to a sudden downdraft, or needed to pour on a little juice
cause my approach was coming up just a bit short. Moving the throttle
forward 1/4 to 1/2 inch, i.e. giving it a little juice but certainly not
a go around type of thing, often times I would get a stumble, hicuup,
drop in RPM'S for 2-3 seconds before the horses responded.
Lot of convective turb lately and that power really comes in handy at
times on mid to short final. Kind of a shocker when the engine doesn't
respond quite nicely.
This has happened on a few birds, especially on hot days. I think
what's happening is the engine is just too rich, hey I've got the
mixture all the way in, it's hot (air less dense), and it's (way) hotter
with the carb heat on ( air much less dense), all enriching the mixture,
and when I put on a little power the accelerator pump in the carb
over-enriches the engine for just a little bit; causing the stumble.
Other pilots and the A&P just tell me to pour on the power a little slower.
I think I'm going to follow a new SOP. Turn the carb heat off on
mid-final. Reasoning: no carb, esp a warm one is going to ice up in 30
seconds, sets me up better for a go-around, and will prevent this
stumble business (I did test it out at altitude, and it prevents or at
least seriously mitigates the stumble).
thoughts?
T
Old September 6th 08, 07:33 PM posted to rec.aviation.piloting
Lonnie[_3_]
"Tman" x@x wrote in message
been taught to pull the carb heat "on" downwind, hey actually use it as a
importantly, just leave the thing on till clear of the runway and cleaning
up. No matter what the temp, humidity. And to have it on at all times
power due to a sudden downdraft, or needed to pour on a little juice cause
my approach was coming up just a bit short. Moving the throttle forward
1/4 to 1/2 inch, i.e. giving it a little juice but certainly not a go
around type of thing, often times I would get a stumble, hicuup, drop in
This has happened on a few birds, especially on hot days. I think what's
happening is the engine is just too rich, hey I've got the mixture all the
way in, it's hot (air less dense), and it's (way) hotter with the carb
heat on ( air much less dense), all enriching the mixture, and when I put
on a little power the accelerator pump in the carb over-enriches the
slower.
seconds, sets me up better for a go-around, and will prevent this stumble
business (I did test it out at altitude, and it prevents or at least
thoughts?
T
Shouldn't be a problem, but sometimes it happens.
Apply power a little slower.
or
Carry just a tiny bit of power on final. Sounds like you might be
approaching at cut off.
or
Bump a little power every 15 to 20 seconds to keep the engine clear.
Personally I wouldn't cut the carb heat.
Old September 6th 08, 07:40 PM posted to rec.aviation.piloting
a[_3_]
On Sep 6, 12:58*pm, Tman x@x wrote:
Flying a lot of 152s and 172s with carb heat lately. *When inbound, I've
cleaning up. *No matter what the temp, humidity. *And to have it on at
all times when the RPM is less than the green band. *Kind of a preventative.
cause my approach was coming up just a bit short. *Moving the throttle
times on mid to short final. *Kind of a shocker when the engine doesn't
This has happened on a few birds, especially on hot days. *I think
Old September 6th 08, 07:45 PM posted to rec.aviation.piloting
John Smith
cleaning up.
Never heard of this before.
mid-final.
Tha't what I've always been taught. Actually, I do it on short final.
There will come the day when you need full power for the go-around. Too
silly if you then have the carb heat on.
Old September 6th 08, 08:03 PM posted to rec.aviation.piloting
Jon Woellhaf
I was taught to push in the carb heat with my thumb while advancing the
throttle for a go-around.
"John Smith" wrote in message
cleaning up.
mid-final.
Mike[_22_]
"Lonnie" @_#~#@.^net wrote in message
preventative.
the way in, it's hot (air less dense), and it's (way) hotter with the
carb heat on ( air much less dense), all enriching the mixture, and when
I put on a little power the accelerator pump in the carb over-enriches
slower.
thoughts?
T
or
or
Neither of which would do anything to prevent potential problems.
Because flight sim doesn't care either way.
Old September 6th 08, 08:19 PM posted to rec.aviation.piloting
Mike[_22_]
slower.
thoughts?
T
What's going to happen if you actually do have carb ice which hasn't burned
off by the time you turn carb heat off? I'd much rather attempt a go around
with the carb heat initially on than attempt a go around with the lingering
effects of carb ice.
I have no idea what DA you're talking about, but what you're describing is
trying to correct a problem with the mixture by controlling it with the carb
heat. If you're landing at a high DA airport, you shouldn't have the
mixture full rich. Setting the mixture on downwind is the solution to the
problem. On a 152 or 172 you can also have your hand on the throttle with
your thumb on the carb heat. It should be a natural reaction to push both
in together or push the carb heat in first on a go around.
Old September 6th 08, 09:11 PM posted to rec.aviation.piloting
terry
Old September 6th 08, 09:21 PM posted to rec.aviation.piloting
Lonnie[_3_]
"Jon Woellhaf" wrote in message
cleaning up.
mid-final.
Yeah, same here.
Old September 7th 08, 04:54 AM posted to rec.aviation.piloting
Robert M. Gary
On Sep 6, 9:58*am, Tman x@x wrote:
I think I'm going to follow a new SOP. *Turn the carb heat off on
mid-final. *Reasoning: no carb, esp a warm one is going to ice up in 30
Don't put any money on that bet. I've had carbs freeze up on me during
stop-n-goes from the time it takes to kick off the heat to the time it
takes to pour on the coals. The carb can freeze in seconds.
-Robert, CFII
Carb Heat [email protected] Rotorcraft 11 April 30th 07 06:34 PM
Carb Heat vlado Piloting 9 January 22nd 07 03:08 PM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 07:26 PM
Carb heat specs? Rich S. Home Built 2 November 13th 04 04:39 PM
Cherokee Carb Heat. Greg Esres Piloting 15 July 29th 03 02:25 PM
