Narco MK 12 D+
Old September 8th 08, 05:43 PM posted to rec.aviation.owning
Tri-Pacer
Default Narco MK 12 D+
I have a Narco MK-12D+ that has an intermittent connection in the display
assembly. At times the display will go dim---it never goes completely
out-----. Pressing lightly anywhere on the front panel returns it to normal
brilliance.
This pretty well isolates the problem to either the display itself or the
dimmer circuit.
My question is this. Is anyone familiar with the inner workings of the
MK-12D+. Is the display hard soldered in or is it on a subassembly that is
in some way socketed.
I have seen the innards of some of the older Narco stuff where they used a
lot of plugs, ribbon cable and sockets to connect subassemblies together.
If this is the case with the MK-12, I might luck out and just have a
connection problem. If it's all surface mount stuff then I guess I'm gonna
have to cough up some AMU's .
Cheers:
Paul
N1431A
KSDM
Narco AT-150 vs. AT-155 [email protected] Owning 1 November 14th 07 07:55 PM
FA Narco MK-12 Tri-Pacer Aviation Marketplace 0 March 11th 06 09:38 PM
Narco DME zatatime Aviation Marketplace 1 February 28th 05 12:07 PM
Narco DME zatatime General Aviation 0 October 14th 04 09:29 PM
Narco DGO-10 Michael Instrument Flight Rules 2 June 9th 04 11:41 PM
