I'm deligthted to see I'm managing to get some arguments and
discussion going. And if you notice, No Profanity? I challenge my students to learn to taxi without brakes. and I come down hard if they beat up the airplane with unecessary braking instead of staying ahead of the airplane. (sometimes even with profanity! Can you imagine that?) How about you? If you had to pay for the brakes, tires, and maintenance, would YOU beat up the airplane? Ol S&B |
On Sep 15, 2:44*pm, "Ol Shy & Bashful" wrote:
I'm deligthted to see I'm managing to get some arguments and discussion going. And if you notice, No Profanity? I challenge my students to learn to taxi without brakes. and I come down hard if they beat up the airplane with unecessary braking instead of staying ahead of the airplane. (sometimes even with profanity! Can you imagine that?) How about you? If you had to pay for the brakes, tires, and maintenance, would YOU beat up the airplane? Ol S&B Let's talk about the other part of flying. I consider a landing 'good' if I make the planned turnoff without use of breaks or additional throttle. The numbers on most runways for us GA types just identify the runway, they should not be the touchdown target. |
Ol Shy & Bashful wrote:
I'm deligthted to see I'm managing to get some arguments and discussion going. And if you notice, No Profanity? I challenge my students to learn to taxi without brakes. and I come down hard if they beat up the airplane with unecessary braking instead of staying ahead of the airplane. (sometimes even with profanity! Can you imagine that?) How about you? If you had to pay for the brakes, tires, and maintenance, would YOU beat up the airplane? Ol S&B I fly a Tiger. Got any suggestions on how to turn without brakes? Back when I was flying 172's I never found it necessary to use the brakes unless I had to make a REALLY tight turn, so I see your point. -- Jim Pennino Remove .spam.sux to reply. |
news ![]() I fly a Tiger. Got any suggestions on how to turn without brakes? I fly a Cherokee without toe brakes. Got any suggestions on how to turn WITH brakes? g |
a wrote:
I consider a landing 'good' if I make the planned turnoff without use of breaks or additional throttle. "Breaks"? May be prevented by using the brakes. Sorry, couldn't resist :-) |
"Steve Foley" wrote:
wrote in message news ![]() I fly a Tiger. Got any suggestions on how to turn without brakes? I fly a Cherokee without toe brakes. Got any suggestions on how to turn WITH brakes? g So far all I've ever flown is a Schweizer SGS 2-33. Not only can't I turn it with the brake, I can't reach the brake during taxi anyway since I'm outside the cockpit during those times. ;-) |
I'm deligthted to see I'm managing to get some arguments and discussion going. And if you notice, No Profanity? I challenge my students to learn to taxi without brakes. and I come down hard if they beat up the airplane with unecessary braking instead of staying ahead of the airplane. (sometimes even with profanity! Can you imagine that?) How about you? If you had to pay for the brakes, tires, and maintenance, would YOU beat up the airplane? Ol S&B I agree completely, (and without cussing :-) I see you are naturally getting replies from the Grumman and Cherokee folks :-) But your point is well made. The way I would present this issue is to simply say that brakes are put on the airplane to hold it for the run up check and for use ONLY when your pre-planned use of aerodynamic forces available to you, or your steering capabilities won't make the necessary change in direction. In other words, you shouldn't be using them on takeoff, landing, and even while taxiing if your planning is adequate for the situation. I like the general rule that dictates that brakes on an airplane should be used as little as possible. Dudley Henriques |
I've been in a couple of planes where without the brakes the thing
accelerates too much. The F-16 comes to mind, where without intermittent braking it picks up too much speed, and braking on landing is pretty much SOP. My Baron needs occasional braking on taxi, otherwise below around 1000rpm the oil pressure drops too low. My friend's turbine Bonanza needs to use beta during taxi or the brakes to keep from picking up too much speed. "Dudley Henriques" wrote in message ... On Sep 15, 2:44 pm, "Ol Shy & Bashful" wrote: I'm deligthted to see I'm managing to get some arguments and discussion going. And if you notice, No Profanity? I challenge my students to learn to taxi without brakes. and I come down hard if they beat up the airplane with unecessary braking instead of staying ahead of the airplane. (sometimes even with profanity! Can you imagine that?) How about you? If you had to pay for the brakes, tires, and maintenance, would YOU beat up the airplane? Ol S&B I agree completely, (and without cussing :-) I see you are naturally getting replies from the Grumman and Cherokee folks :-) But your point is well made. The way I would present this issue is to simply say that brakes are put on the airplane to hold it for the run up check and for use ONLY when your pre-planned use of aerodynamic forces available to you, or your steering capabilities won't make the necessary change in direction. In other words, you shouldn't be using them on takeoff, landing, and even while taxiing if your planning is adequate for the situation. I like the general rule that dictates that brakes on an airplane should be used as little as possible. Dudley Henriques |
How about you? If you had to pay for the brakes, tires, and maintenance, would YOU beat up the airplane? Haha - I have to admit that I didn't give it much consideration when I was a renter. Coupled with the fact the flight school was near the approach end of the usual runway I likely abused them to make the early turnoff. Funny how buying a plane and having to pay for them yourself changes your perspective on things - now I try not to use them at all if I can help it. Although, I would challenge you to taxi to my hangar without using brakes - taxiway E at AGC goes down a pretty substantial hill so I don't see that I have much choice. Also, once when flying with an instructor and landing somewhere with a shorter runway, I rolled down to the end with the yoke full back but still had to brake a bit to make the last turnoff. The instructor pointed out it's probably a good idea to find out if your brakes work sometime before you roll down the embankment at the end... So now I make it a point to at least give them a tap while I still have time to do something about it if they don't work. |
On Sep 15, 4:47*pm, "Viperdoc" wrote:
I've been in a couple of planes where without the brakes the thing accelerates too much. The F-16 comes to mind, where without intermittent braking it picks up too much speed, and braking on landing is pretty much SOP. My Baron needs occasional braking on taxi, otherwise below around 1000rpm the oil pressure drops too low. My friend's turbine Bonanza *needs to use beta during taxi or the brakes to keep from picking up too much speed. "Dudley Henriques" wrote in message ... On Sep 15, 2:44 pm, "Ol Shy & Bashful" wrote: I'm deligthted to see I'm managing to get some arguments and discussion going. And if you notice, No Profanity? I challenge my students to learn to taxi without brakes. and I come down hard if they beat up the airplane with unecessary braking instead of staying ahead of the airplane. (sometimes even with profanity! Can you imagine that?) How about you? If you had to pay for the brakes, tires, and maintenance, would YOU beat up the airplane? Ol S&B I agree completely, (and without cussing :-) I see you are naturally getting replies from the Grumman and Cherokee folks :-) But your point is well made. The way I would present this issue is to simply say that brakes are put on the airplane to hold it for the run up check and for use ONLY when your pre-planned use of aerodynamic forces available to you, or your steering capabilities won't make the necessary change in direction. In other words, you shouldn't be using them on takeoff, landing, and even while taxiing if your planning is adequate for the situation. I like the general rule that dictates that brakes on an airplane should be used as little as possible. Dudley Henriques Had the chance to fly the Viper a few times. Didn't notice any excessive increase in taxi speed that very light braking couldn't handle. Did use them a bit being late with throttle reduction after a start from a standing position until I got used to the response :-) Landing the Viper for me anyway was a conglomeration of a lot of things happening at once. Assuming no drag chute deployment, keeping the nose up to 13 degrees AOA gave good aerodynamic braking down to about 80kts. At 80 kts you could fly the nosewheel down to the runway with good control. If I remember right, the speedbrake was restricted to around 43 degrees with the airplane dirty and this was in play through touchdown and until the nose was on the runway, then hitting the SB slider again extended the boards out to full at 60 degrees. I didn't notice anything that required excessive brake use through roll out. In fact, I never flew the Viper with heavy externals but the word was that landing hot and using the brakes could get you sent over to the hot brake area to sit and sweat your butt off over there in the sun :-)) DH |
| Thread Tools | |
| Display Modes | |
| Brakes? | WingFlaps | Piloting | 69 | March 4th 08 07:27 AM |
| Good news for scratch builders of metal airplanes - Home Depot rents bending brakes | flybynightkarmarepair | Home Built | 7 | January 6th 07 05:22 PM |
| Carbon brakes | [email protected] | Piloting | 3 | August 19th 06 08:01 AM |
| Trailer brakes | Bert Willing | Soaring | 1 | October 31st 03 08:55 AM |
| Cobratrailer&brakes | Greg Arnold | Soaring | 5 | October 6th 03 04:14 PM |
