Video: When Aerial Refueling Goes Bad
Old September 17th 08, 09:21 AM posted to rec.aviation.military,rec.aviation.military.naval
Yeff
Default Video: When Aerial Refueling Goes Bad
http://www.youtube.com/watch?v=pGS8dwQSWzI
-Jeff B.
"Excuse me.
I don't mean to impose,
but I am the Ocean."
~ The Salton Sea
Old September 17th 08, 11:20 AM posted to rec.aviation.military,rec.aviation.military.naval
George Z. Bush
How embarrassing!! I wouldn't put too much money on how good that pilot
was wielding his weapon in the sack, either!
(^v^))))))))
George Z.
Old September 17th 08, 11:51 AM posted to rec.aviation.military,rec.aviation.military.naval
Dave Kearton
"George Z. Bush" wrote in message
(^v^))))))))
George Z.
Aaah yes, the fur-lined refuelliung basket, at least a little movement
there is welcome.
Cheers
Dave Kearton
Old September 17th 08, 07:36 PM posted to rec.aviation.military,rec.aviation.military.naval
Mike Kanze
....Proving once again that it's not as easy as it looks. Bow wave from the tankee's nose and burble from the tanker aircraft are constants that the pilot must factor for a successful basket plug.
Note that the hose failed to retract into the tanker as it should have once the second (successful) plug was made and the basket was shoved forward.
Those of you laughing have likely never tried this in a low fuel state / night situation, with a pitching deck awaiting your recovery. Not anyone's idea of happy fun.
Mike Kanze
"I prefer my tragedy and despair in limited doses."
- Sherman the shark
"That's what golf is for."
- Hawthorne the hermit crab
Sherman's Lagoon, 4/5/08
"Yeff" wrote in message ...
-Jeff B.
"Excuse me.
~ The Salton Sea
Old September 17th 08, 08:53 PM posted to rec.aviation.military,rec.aviation.military.naval
frank
Mike Kanze
- Sherman the shark
* "Yeff" wrote in .. .
* http://www.youtube.com/watch?v=pGS8dwQSWzI
* -Jeff B.
* "Excuse me.
* *I don't mean to impose,
* *but I am the Ocean."
* * * * ~ The Salton Sea
'Tis true. but afterwards when you land, that's another story.
Had a B-1 once, refuel went wrong during flight test. boom scraped
along right seat, tapped the window. Comment that pilot had for weeks
was, ''Did you see God??"
There is a reason there are marks on the top of airplanes for
refueling recepticle.
But, with the loose recepticle on the end of reel like that one, its
difficult to connect, could be turbulence, anything . As conditions
get worse and the need for gas more extreme, pretty dicey up there.
I've heard some stories of what it was like to refuel from KC-97 from
a B-47 or B-52, tanker is going full bore, receiver is trying not to
stall. Not fun. Way safer now.
Old September 18th 08, 02:40 AM posted to rec.aviation.military,rec.aviation.military.naval
JR Weiss
"frank" wrote...
I've heard some stories of what it was like to refuel from KC-97 from a B-47
or B-52, tanker is going full bore, receiver is trying not to stall. Not fun.
Way safer now.
Kinda like refueling an A-6 from a KC-130... Marginal when the A-6 is light;
need at least some slats down when heavy. There were a few ways to get partial
flaps and/or slats down (that weren't in any book) that were useful when high &
hot or heavy...
Old September 18th 08, 03:13 PM posted to rec.aviation.military,rec.aviation.military.naval
Bob Liberty
Refueling from a KC-97 was frequently done in a decent to get enough speed.
It would do only about 215 knots ias in level flight heavy at 15,000. Not
unusual that a receiver wanted at least 225k . That airplane probably came
closer to getting me killed then an AC130 in SEA
ole nav
"JR Weiss" wrote in message
"frank" wrote...
B-47 or B-52, tanker is going full bore, receiver is trying not to stall.
light; need at least some slats down when heavy. There were a few ways to
get partial flaps and/or slats down (that weren't in any book) that were
useful when high & hot or heavy...
Old September 18th 08, 03:58 PM posted to rec.aviation.military,rec.aviation.military.naval
Eunometic
It would appear to me that the probe and drogue system is now far more
basic than it needs to be to be and is therefore less effective and
reliable than it should be.
One reason the boom method works is that the boom is that the actively
flown into the recepitcal.
It should be possible to place sensors and controls (flappers, fins or
a basket that can twist to direct itselt) that stabilizes the drogue
and allows it to fly further from the aircraft. Ideally it should
'home' itself towards the probe slightly to help the pilot. A simple
LED lamp with a specific flashing frequency can serve as a homming
point.
Old September 18th 08, 07:45 PM posted to rec.aviation.military,rec.aviation.military.naval
JR Weiss
"Eunometic" wrote:
It would appear to me that the probe and drogue system is now far more basic
than it needs to be to be and is therefore less effective and reliable than it
should be.
Not really...
First, the pilot in that video was obviously new to air refueling, and didn't
adhere to the concept of looking THROUGH the drogue, not AT the drogue. He was
obviously chasing the drogue on the first attempt, and tried to "stab" it with a
big burst of throttle the next time. That got him excess, uncontrolled closure
that the reel response system could not handle.
Reminds me of some of the Omanis who tried it in Jaguars behind our KA-6s back
in the 80s...
One reason the boom method works is that the boom is that the actively flown
However, it still takes a stable receiver airplane...
It should be possible to place sensors and controls (flappers, fins or a
basket that can twist to direct itselt) that stabilizes the drogue and allows
it to fly further from the aircraft. Ideally it should 'home' itself towards
the probe slightly to help the pilot. A simple LED lamp with a specific
point.
Nope. The receiver pilot can usually figure out the drogue's movement cycle if
the tanker is stable. If unpredictable, extraneous control inputs are made in
the tanker, they upset the rhythm.
An analogous concept has been demonstrated MANY times before, with far more
negative than positive results: On a KC-135 equipped with the drogue adapter,
the "boomer" will sometimes attempt to "help" the receiver by trying to fly or
"tweak" the drogue to the probe. Since the receiver pilot cannot anticipate
what the probe will do, more often than not it results in a worse miss than if
the drogue is allowed to fly naturally.
Old September 18th 08, 08:01 PM posted to rec.aviation.military,rec.aviation.military.naval
Eunometic
On Sep 19, 3:45*am, "JR Weiss"
should be.
Not really...
adhere to the concept of looking THROUGH the drogue, not AT the drogue. *He was
big burst of throttle the next time. *That got him excess, uncontrolled closure
in the 80s...
it to fly further from the aircraft. *Ideally it should 'home' itself towards
the probe slightly to help the pilot. *A simple LED lamp with a specific
flashing frequency can serve as a homming point.
Nope. *The receiver pilot can usually figure out the drogue's movement cycle if
the tanker is stable. *If unpredictable, extraneous control inputs are made in
negative than positive results: *On a KC-135 equipped with the drogue adapter,
"tweak" the drogue to the probe. *Since the receiver pilot cannot anticipate
If one accepts your point that autonomous probe movement will upset
the pilots ability to mate with the probe there is then still scope to
'stabilize' the probe or rather to smooth its behavior when there are
gusts around.
What about shifting the paradigm a little. The aircraft automatically
or manually formates at an appropriate spot behind and below the
tanker and then remains stationary while the probe flies itself to the
drogue.
Modernizing the Aerial Refueling Fleet. Mike Naval Aviation 1 October 20th 06 02:35 AM
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue Mike Naval Aviation 26 July 12th 06 12:38 AM
Aerial Photographs/Aerial Patrols [email protected] Piloting 10 December 15th 04 02:43 PM
Defense Science Board Aerial Refueling Requirements study Guy Alcala Military Aviation 1 June 2nd 04 01:55 AM
CH53 refueling video John Rotorcraft 2 December 6th 03 12:54 AM
