Hydraulic track ramp conversion,
Old September 17th 08, 08:53 PM posted to rec.aviation.soaring
Udo Rumpf[_2_]
Default Hydraulic track ramp conversion,
has anyone done it?
If so could you send me some details.
Also buying same as a retro fit would be of interest to me.
Udo
Old September 17th 08, 10:39 PM posted to rec.aviation.soaring
JJ Sinclair
On Sep 17, 11:53*am, Udo Rumpf wrote:
has anyone done it?
Udo
Williams Soaring has the conversion, $628. A must for old backs. I set
the fuselage height a tad low and then jack with one foot as I observe
the holes come into alignment, slip in my broom handle to pull both
wings together and slide in the first pin. Then raise or lower as
required for the second pin.........slick!
JJ
Old September 18th 08, 02:02 PM posted to rec.aviation.soaring
ContestID67
http://store.williamssoaring.com/Mer...egory_Code=TPA
Help identifying a hydraulic fitting larry Rotorcraft 0 May 10th 06 08:55 PM
Help identifying a hydraulic fitting larry Restoration 0 May 10th 06 08:55 PM
Help identifying a hydraulic fitting larry Aviation Marketplace 0 May 10th 06 08:55 PM
Hydraulic Pump [email protected] Aviation Marketplace 2 March 28th 06 05:16 PM
Hydraulic Pump [email protected] General Aviation 2 March 28th 06 06:09 AM
