B40 replacement speaker?
Old September 22nd 08, 10:33 PM posted to rec.aviation.soaring
Frank[_1_]
Default B40 replacement speaker?
I think My B40 speaker is getting kind of weak. Even at full volume
it is just barely audible, and I'm wondering what to do for a
replacement speaker.
Any suggestions?
TIA,
Frank (TA)
Old September 22nd 08, 11:05 PM posted to rec.aviation.soaring
Tim Mara
with B40 you can use almost any speaker....they are not special
tim
Please visit the Wings & Wheels website at www.wingsandwheels.com
"Frank" wrote in message
Any suggestions?
TIA,
Frank (TA)
Old September 23rd 08, 01:44 PM posted to rec.aviation.soaring
JJ Sinclair
Check the speaker wire connections at the rear of the B-40, I solved
my speaker problems when I tightened up a speaker wire!
JJ
Any suggestions?
TIA,
Frank (TA)
Old September 23rd 08, 02:29 PM posted to rec.aviation.soaring
Mike the Strike
JJ
Possibly - but speaker failures on the Borgelt varios are legend. The
manufacturer-supplied speaker is tiny and crap, as I discovered some
years ago. As Tim says, almost any replacement will work.
Frank wrote:
I think My B40 speaker is getting kind of weak. *Even at full volume
Any suggestions?
TIA,
Frank (TA)
Old September 23rd 08, 03:36 PM posted to rec.aviation.soaring
Bill Daniels
This brings up a thought that's been bouncing around in my head for awhile.
I have several things that generate audio, each with their own crappy little
speaker. That seems kinds wasteful and redundant.
A quick search with Google for portable audio mixers turned up a class of
devices used with DV camcorders to mix microphone inputs. A couple accepted
line level inputs and provided amplified output. There was even one built
into a sub-mini D-25 connector specifically made for aircraft. Add to that
a pair of quality lightweight MP3 speakers and you have a one pound audio
system with several inputs, each with level controls.
"Mike the Strike" wrote in message
JJ
Any suggestions?
TIA,
Frank (TA)
Old September 23rd 08, 04:26 PM posted to rec.aviation.soaring
"Mike the Strike" wrote in ...
JJ
Any suggestions?
TIA,
Frank (TA)
That sounds like exactly what I need in the back of our Blanik L13.
All the audio controls
are in the front seat, and the speakers are up there, too, so I can
never quite hear what's
going on with the audio vario or radio from the back, and I never can
get my passengers
(or some of my students for that matter!) to figure out how to adjust
things.
-- Matt
Oshkosh Speaker Invitation RST Engineering Piloting 21 May 22nd 08 12:46 AM
SSA Speaker Presentations Available ContestID67 Soaring 15 March 12th 07 03:11 AM
Air force gives in to Ms Speaker Wilman Aviation Photos 25 February 20th 07 12:14 AM
Replacement Cabin Speaker for Cessna? John Clonts Owning 19 October 12th 05 08:30 PM
Jim Stephenson guest speaker gilan Piloting 0 January 29th 05 01:26 AM
