mounting a PCAS on the glareshield
Old October 1st 08, 04:49 PM posted to rec.aviation.owning
Mike Noel
Default mounting a PCAS on the glareshield
Geoff, thanks. Nice idea.
Ez
Step 1) get a chunk of 1/8 lexan from the local hardware store - have them
cut it to, oh, about 6 inches by10 inches or so.
Step 2) send the wife to visit her mom for the afternoon (important - do
this before step 3)
Step 3) put the lexan in the oven for a couple hours at about 180 F. to
drive off the water - then raise the temp. to about 250 or 300 wait for it
to get rubbery
Step 4) wrap the lexan around a chunk of 1x6.
You will now have a platform that is about 6 inches by about 5 3/4 inches
wide with two "feet" that will straddle the hump on the glare shield. If it
has a strong compound curve, you will have to cut away the middle of each
side to make 4 individual feet (or make adjustments with a heat gun).
Stick the lexan to the PCAS with double side tape and put the velcro on the
feet.
A custom mount with no muss, no fuss (unless your wife catches you putting
the lexan in her oven)...
Geoff
Best Regards,
Mike.
http://flickr.com/photos/mikenoel/
http://photoshow.comcast.net/mikenoel
mounting a PCAS on the glareshield Mike Noel Owning 2 September 29th 08 11:08 PM
PA-28 Glareshield Replacement Marco Leon[_4_] Owning 8 January 11th 08 08:33 PM
Glareshield Overhaul? Mike Spera Owning 7 March 23rd 07 11:34 PM
ASW20A Glareshield needed Tim Mara Soaring 0 April 19th 04 04:17 AM
Glareshield renewal and TSA Roger Long Owning 9 February 27th 04 12:39 PM
