CAV 11 Audio Vario/no Audio ideas? (Cambridge)
Old October 12th 08, 04:36 PM posted to rec.aviation.soaring
Gregg Leslie[_2_]
Default CAV 11 Audio Vario/no Audio ideas? (Cambridge)
Guys,
I have a Cambridge CAV 11 audio vario, the vario works great but I have no
audio. When I open the case there is a speaker connected to the pc board
via a small harness. above that connection there is a 3 prong jumper. Does
this have anything to do with shutting the audio off?
I could use a manual, Cambridge has one online but does not address the
jumper nor does it have a schematic.
GL
Old October 13th 08, 06:24 PM posted to rec.aviation.soaring
On Oct 12, 10:36*am, Gregg Leslie wrote:
Guys,
jumper *nor does it have a schematic.
GL
I'd bet the speaker is bad. Have seen this before.
UH
Old October 13th 08, 07:38 PM posted to rec.aviation.soaring
Guys,
GL
UH
If so, you can use an ohm meter to see if the coil is "open".
Disconnect it first.
Anyone have a Piep Audio Vario? [email protected] Soaring 9 December 2nd 15 03:37 AM
Anyone have a Piep Audio Vario? Steve Leonard Soaring 2 November 9th 15 05:17 PM
Cambridge vario audio control Solo Soaring 4 October 23rd 06 02:03 AM
L-Nav audio vario problem Roy Clark, B6 Soaring 5 September 8th 05 05:58 AM
L-13 + TE + Audio Vario Ray Lovinggood Soaring 4 January 12th 05 04:21 AM
