Mitchell Holman rudely blurted out
: begin 644 XB-70 07.jpg Attachment decoded: XB-70 07.jpg ` end Would someone care to explain this picture? I seem to recall that NA built 2 and lost one. This picture, assuming it is the one that survived looks in pretty bad shape for just being parked in a desert graveyard before being stuck in a museum. TIA |
In article 7,
"Mean ol' Lee" wrote: = Mitchell Holman rudely blurted out = : = = = |
This is indeed the survivor, which was the first of the two built.
You can tell the second one by the dark chin under its nose. The second one was significantly more capable, making its loss all the more damaging to the test program. Hi! What do you mean: "the second one was significantly more capable?" Did it have different engines or something? I don't know very much about this aircraft other than it never made it to production and that the second one was lost in a staged publicity shoot where a mid-air collision caused it to crash. Take care, Nick |
"Canuck" wrote: = This is indeed the survivor, which was the first of the two built. = You can tell the second one by the dark chin under its nose. = = The second one was significantly more capable, making its loss all = the more damaging to the test program. = = Hi! What do you mean: "the second one was significantly more capable?" Did = it have different engines or something? I don't know very much about this = aircraft other than it never made it to production and that the second one = was lost in a staged publicity shoot where a mid-air collision caused it to = crash. The construction of the Valkyrie necessitated the development of new metalworking technologies in both stainless steel and titanium. Most of the skin of the aircraft was made from a honeycomb structure of stainless steel with thin sheets bonded to both sides. Manufacture of such sections was developed pretty much from scratch, and the use of titanium was also in its infancy. The first XB-70 (AV/1) turned out to have a number of structural defects, mainly in the lamination of the honeycomb stainless steel sections. After tests into the high mach regimes these sections started to fail in various ways, and AV/1 was limited to a maximum speed of mach 2.5 for all subsequent testing. The construction of AV/2 incorporated lessons learned, and did not suffer from these structural defects. In addition, a large number of problematic areas such as hydraulic systems and fuel management systems, to name but two, were very significantly revised for the better. Cooling of the aircraft structure included a very complex circulation of fuel to transfer heat, and the fuel tanks used a pressurized nitrogen mechanism to ensure that there was little or no (hot) fuel vapour in the emptying tanks. All of this was innovative back at the beginning of the sixties. There were also structural and aerodynamic modifications in such items as the placement of the wing folds - the outer wing sections cranked down in high speed flight to provide increased longitudinal stability and to reduce some wing trailing edge effects. All of these changes made AV/2 a significantly more capable aircraft than AV/1, as it conclusively demonstrated before its tragic and unnecessary loss. AV/2 demonstrated the ability to cruise above mach 3 for extended periods, meaning several hours at a time, which was lost with the aircraft, because of the restriction of AV/1 to mach 2.5 flight. Bear in mind both the timeframe of development and the unprecedented size of this aircraft. Every flight of both aircraft was an adventure, and some of them were hairy in the extreme. The survivor is still an awesome sight, if you visit it at the US Air Force museum. It is so large that it cannot be seen in its entirety from any point, and it looms unbelievably above you as you walk under it. The only thing I have ever heard louder on take-off is the space shuttle, but, as someone else has said, the climb out and acceleration of the Valkyrie was awesome in a way that is somehow much more memorable than the almost stately vertical departure of the shuttle. For the conspiracy buffs, there is a persistent rumour that incomplete AV/3 (intended to be the first YB-70A article) was not broken up but quietly completed as a reconnaissance platform and mother ship for a drone of some kind. Alas, I can't imagine keeping such a huge beast secret, any more than I can imagine the crackling thunder of one of its departures not being noticed by someone. It also produced a heavy, heavy sonic footprint when it was in a hurry, even when up high at above 60,000 feet. The six side-by-side engines also produced a unique contrail, although the SR-71, of similar vintage, had an excellent record of avoiding making contrails when necessary, so dreamers can dream that the XB-70 could avoid leaving a trail too. Sorry, must be getting old to wax so nostalgic. OIV -- Orlando Quattro -- oquattro at magma dot ca The Starving Artist's Garratt |
![]() "Orlando Quattro" wrote in message news ![]() The construction of the Valkyrie necessitated the development of new metalworking technologies in both stainless steel and titanium. Most of the skin of the aircraft was made from a honeycomb structure of stainless steel with thin sheets bonded to both sides. Manufacture of such sections was developed pretty much from scratch, and the use of titanium was also in its infancy. The first XB-70 (AV/1) turned out to have a number of structural defects, mainly in the lamination of the honeycomb stainless steel sections. After tests into the high mach regimes these sections started to fail in various ways, and AV/1 was limited to a maximum speed of mach 2.5 for all subsequent testing. The construction of AV/2 incorporated lessons learned, and did not suffer from these structural defects. In addition, a large number of problematic areas such as hydraulic systems and fuel management systems, to name but two, were very significantly revised for the better. Cooling of the aircraft structure included a very complex circulation of fuel to transfer heat, and the fuel tanks used a pressurized nitrogen mechanism to ensure that there was little or no (hot) fuel vapour in the emptying tanks. All of this was innovative back at the beginning of the sixties. There were also structural and aerodynamic modifications in such items as the placement of the wing folds - the outer wing sections cranked down in high speed flight to provide increased longitudinal stability and to reduce some wing trailing edge effects. All of these changes made AV/2 a significantly more capable aircraft than AV/1, as it conclusively demonstrated before its tragic and unnecessary loss. AV/2 demonstrated the ability to cruise above mach 3 for extended periods, meaning several hours at a time, which was lost with the aircraft, because of the restriction of AV/1 to mach 2.5 flight. Bear in mind both the timeframe of development and the unprecedented size of this aircraft. Every flight of both aircraft was an adventure, and some of them were hairy in the extreme. The survivor is still an awesome sight, if you visit it at the US Air Force museum. It is so large that it cannot be seen in its entirety from any point, and it looms unbelievably above you as you walk under it. The only thing I have ever heard louder on take-off is the space shuttle, but, as someone else has said, the climb out and acceleration of the Valkyrie was awesome in a way that is somehow much more memorable than the almost stately vertical departure of the shuttle. For the conspiracy buffs, there is a persistent rumour that incomplete AV/3 (intended to be the first YB-70A article) was not broken up but quietly completed as a reconnaissance platform and mother ship for a drone of some kind. Alas, I can't imagine keeping such a huge beast secret, any more than I can imagine the crackling thunder of one of its departures not being noticed by someone. It also produced a heavy, heavy sonic footprint when it was in a hurry, even when up high at above 60,000 feet. The six side-by-side engines also produced a unique contrail, although the SR-71, of similar vintage, had an excellent record of avoiding making contrails when necessary, so dreamers can dream that the XB-70 could avoid leaving a trail too. Sorry, must be getting old to wax so nostalgic. OIV Don't apologize! This is great info. How did you come to know so much about this aircraft? Were you struck by its beauty/performance and became interested in it or did you actually have some connection to the project? Take care, Nick |
![]() "Mean ol' Lee" wrote in message 36.97... Mitchell Holman rudely blurted out : begin 644 XB-70 07.jpg Attachment decoded: XB-70 07.jpg ` end Would someone care to explain this picture? I seem to recall that NA built 2 and lost one. This picture, assuming it is the one that survived looks in pretty bad shape for just being parked in a desert graveyard before being stuck in a museum. TIA The picture is what the XB-70 looked like after a flight. The flexing and high speeds would cause the paint to pop off in flight. I went to hangar 42 in 1964 while stationed with VX-5. They had the aircraft getting ready to be painted before the next flight. It looked a lot like the picture that was posted. |
Interesting camouflage ;-)
-- Mike Mackenzie (AVCOM Services) Brisbane, AUSTRALIA Remove "XYZ" from the "Reply to" address when responding by email. |
Flight Of The Valkyries - XB-70 06.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | October 14th 08 01:13 PM |
Flight Of The Valkyries - XB-70 04.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | October 14th 08 01:13 PM |
Flight Of The Valkyries - XB-70 03.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | October 14th 08 01:13 PM |
Flight Of The Valkyries - XB-70 02.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | October 14th 08 01:13 PM |
Flight Of The Valkyries - XB-70 01.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | October 14th 08 01:13 PM |
