Variable geometry intakes
Old April 10th 04, 01:12 AM
Boomer
Default Variable geometry intakes
are variable geometry intakes on fighter aircraft primarily there to reduce
ram drag or to manipulate the shock wave in the nacelle?
Curiosity killed the cat, and I'm gonna find out why!
Old April 10th 04, 02:44 AM
Orval Fairbairn
Both -- The most efficient inlet geometry has the shock wave impinging
on the inlet lip; if it impinges inside, the inlet "swallows the shock,"
which leads to compressor stall.
Old April 10th 04, 01:47 PM
John Carrier
It isn't necessary that all shocks be external to the inlet, only that
stable subsonic air reach the compressor face. Some inlets are designed to
create several oblique shocks within the inlet prior to reaching a point
where an expansion of cross-sectional area (diffuser) creates a final normal
shock to decelerate the air.
R / John
Old April 10th 04, 02:47 PM
Kurt R. Todoroff
R / John
Amplifying on John's well written technical description, engine thrust is
directly proportional to air pressure at the engine face. The primary
objective of a variable geometry engine inlet is to effect a maximum pressure
recovery of the air prior to arrival at the engine compressor face. The shock
wave development that John describes, especially the final normal shock wave,
accomplishes this. The pronounced effect of an inlet system that fails to
articulate is quite amazing. While I have never had an inlet system fail
during functional check flights in the F-111, a couple of my colleagues have.
In one case, the central air data computer Mach signal failed to reach both
inlets. Their F-111F barely attained Mach 1.7 in Maximum Afterburner. The F
model had the largest engines in the fleet, and could attain Mach 1.1 in
Military power on the deck, and Mach 2.5 in less than Maximum Afterburner at
altitude. They brought the jet back, maintenance repaired the problem, and
they flew it again the next day. They hit Mach 2.5 without breaking a sweet.
I haven't heard only one inlet not articulating, however, I would imagine that
the first clue would be the pilot adding rudder into the "good" engine as the
Mach increased.
The other factors, such as flow smoothing and resistance to angle of attack
excusions, do not require a variable geometry configuration. A well designed
fixed geometry inlet can accomplish these objectives.
Kurt Todoroff
Markets, not mandates and mob rule.
Consent, not compulsion.
Remove "DELETEME" from my address to reply
Old April 10th 04, 04:14 PM
SteveM8597
that
Mach increased.
Kurt Todoroff
Once in a while the variable inlet bellmouth rings on the F-4 at the
engine/inlet duct interface would fail to move at M 2.0+. The rings rotated
about 90 degrees or so as the ramps closed down to dump excess air at high
speed but didn't get that much use. Corrosion would cause the cable and pulley
system to corrode and not move freely.. When that happened the engine was very
stall susceptible. I had one happen when flying a Funcfional Check Flight.
Interesting experoence to compressor stall at M 2.3. Even with the centerline
thrust F-4 the bang and yaw pretty violent.
During early flight testingof the the F-16 with the F-110 engine in 85, we
had a test bird with the large inlet, IIRC, that the pilots called Thumper
because of banging in the inlet due to airflow. The engine was pretty stall
resistant with the electonic control but the pilots said the banging was enough
to bounce their feet off the rudder pedals.Apparently at some speeds and
configurations in this particilar aircraft, the shockwave would draw back into
the inlet. The banging was due to oilcanning of the sheetmetal from the
pressure drop across the shockwave as shown by additional instrumentation and
high speed photography.
Old April 10th 04, 05:16 PM
Boomer
VERY interesting stuff guys thanks :-)
was wondering this: F-15 has nacelles that physically move externally,
whereas F-14 is fixxed externally yet they have somewhat similar performance
in the upper right of the envelope. How does the F-14 deal with reducing ram
drag ? It appears the F-15 can simly move it's nacelles down to restrict air
flow. I know F-14 has shock ramps inside to deal with the shock wave, but
what does it do about ram?
"SteveM8597" wrote in message
have.
both
The F
at
and
sweet.
that
Mach increased.
attack
designed
Kurt Todoroff
rotated
pulley
very
Flight.
centerline
we
stall
enough
into
and
Old April 10th 04, 11:52 PM
John Carrier
"Boomer" wrote in message
performance
ram
air
This is a pretty good graphic of the system.
http://www.anft.net/f-14/f14-detail-airintake.htm
OBTW, the F-14A programming optimized performance at the upper end and
(theoretically) could outaccelerate an F15A above 1.6 or so. Ramp
reprogramming, elimination of the glove vanes, and some additional drag
counts make the F-14B (and moreso the D) slower above 1.6 than the old A
with significantly less thrust. OTOH, the B and D have their ramp
scheduling optimized for real world tactical requirements. They're awesome
in the transonic range. A clean F-14B/D can exceed both its NATOPS and
manufacturer's KIAS placard limits, even if they're barely mach 2 capable
(if that, I've heard 1.9).
R / John
Old April 11th 04, 12:05 AM
Dave Kearton
"John Carrier" wrote in message
news |
awesome
| R / John
How relevant is Mach 2+ performance these days - how relevant was it at all
I can imagine high speed being useful when intercepting the odd Foxbat or
two, but otherwise - how often would you require such high speeds ?
Cheers
Dave Kearton
Old April 11th 04, 03:40 AM
Kurt R. Todoroff
? BRBR
This is the same pedantic question that I've heard for twenty-nine years.
These velocities are a consequence of meeting specific excess power
requirements (P_s). A positive P_s allows an aircraft to accelerate (gain
velocity), sustain G, or climb in altitude, or any of these three. P_s does
not come free. P_s is computed as:
(Thrust - Drag) * Velocity / Weight
A natural consequence of a fighter's design is speed. The design is a result
of tradeoffs. The fact that fighters rarely exercise their supersonic
capabilities is not relevent. By reducing the thrust of the engines to limit
the aircraft speed to M-1.5 or M-1.0, the aircraft's performance is other
realms is sharply limited as well.
Since high speed is a natural consequence of a fighter's design, the USAF and
USN have taken advantage of it.
Kurt Todoroff
Old April 11th 04, 07:20 AM
Boomer
Thanks for the link and Tom stats JC :-)
"Kurt R. Todoroff" wrote in message
all
? BRBR
does
result
limit
and
Kurt Todoroff
ram air pressure governed variable pitch prop Bruce Meacham Home Built 4 April 16th 04 08:42 PM
Descriptive Geometry Manual now available! Wade Meyers Aviation Marketplace 0 February 18th 04 09:59 PM
Descriptive Geometry Manual now available! Wade Meyers Military Aviation 0 February 18th 04 09:58 PM
Question about the Eurofighter's air intakes. Urban Fredriksson Military Aviation 0 January 30th 04 04:18 PM
want variable pitch prop Ray Toews Home Built 5 October 7th 03 09:59 PM
