I plan on installing a tempeture guage inside the cockpit of my
	glider. I think it's a good thing to have that can add to safety. For instance, it's nice to know just how hot it is during those summer days on a short runway. Also, to know if your in potential icing conditions at altitudes. I've hit some bad icing before in the spring, at 15,000 feet that iced over my windshield so bad I couldn't see out even with the windshield heat on (in an aircraft). Most of all, I'm real interested to find out if anyone has installed one and noticed a tempeture change when entering a thermal? Can it be used, in anyway, to help center a thermal? Seek out a thermal?  |
On Tue, 28 Oct 2008 06:26:14 -0700, scottandrewalexander wrote:
	Most of all, I'm real interested to find out if anyone has installed one and noticed a tempeture change when entering a thermal? Its normal to use a sensitive thermistor-based temperature sensor to find thermals when flying Free Flight duration models in a contest. The usual temperature swing when a thermal blows through is about 1 degree Centigrade though it can vary from 0.5 to 2 degrees depending on weather etc. with the measurement made at around 5m. Secondly, you need a fast response, which means a very small thermistor bead (no bigger than 0.8mm diameter and under 0.5 mm is preferable) and it must be a naked bead - common units which enclose the bead in plastic or metal probes are useless because their response lags the actual temperature change by anything up to 30 seconds. I've never made or heard about comparable measurements at flying heights and would be interested to hear if anybody else has measurements above ground level. For the moment lets assume the same temperature range is found at flying height. Can it be used, in anyway, to help center a thermal? Seek out a thermal? You'd need a read-out with a resolution of at least 0.1C to be able to reliably see the shape and position of a thermal so if your read-out isn't that accurate you're on a hiding to nothing: my SDI C4 only reads in whole degrees. Last but not least, its thermistor is buried in a 3mm diameter plastic housing, so while its fine for monitoring the average air temp or spotting icing conditions, its response is far too slow to find thermals: a good vario has a 2-4 sec response, so it follows that the thermistor-based thermal detector must have a similar response rate. -- martin@ | Martin Gregorie gregorie. | Essex, UK org |  |
Its my understanding that the thermal reaches the ambient air temp
	pretty quickly due to nearby air being entrained. Its the water vapor, being less dense than dry air, that makes the parcel of air bouyant and inertia contributes as well. Could be wrong, though. Mike  |
| Thread Tools | |
| Display Modes | |
| Exporting a glider to/import a glider into Germany | Pete Smith[_2_] | Soaring | 1 | August 8th 08 10:33 AM |
| Glider Model - Blaue Maus- 1922 Wasserkuppe Glider | [email protected] | Soaring | 5 | November 20th 06 12:08 AM |
| shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 03:05 PM |
| Gleim Instrument Pilot Audio CD Set AND Gleim Instrument Pilot FAA Test Prep Software - together on Ebay | Cecil E. Chapman | Products | 0 | January 15th 04 12:34 AM |
