Off Airport Landings
Old October 30th 08, 03:21 PM posted to rec.aviation.piloting
Ol Shy & Bashful
Default Off Airport Landings
Have you ever done one? Have you ever looked at the area you were in
while driving down the road and asked if you could land safely there?
Ever tried to walk through a field of cotton, soybeans, tomatoes,
alfalfa, or ???? Do you know if there are furrows or irrigation rows?
How about trying to land in a field of corn? Ever tried to walk thru
one?
OK ...how about landing on a road. What about the road signs, wires,
bridges, poles, or other obstacles?
When was the last time you surveyed an area to see what the conditions
were or how you would make a landing with an engine out away from any
runway or airport?
Hmmmmm ...getting out my old brown colored stick and reaching for the
proverbial pot.....
Now that we are approaching winter weather should we start talking
about the peculiar conditions with wet and freezing conditions? Of
late here we are seeing frost on our wings with the attendant
problems.
Any discussions ... any one?
Ol S&B
Old October 30th 08, 04:07 PM posted to rec.aviation.piloting
Gene Seibel
one?
Grew up on a farm and am well aware of the terrain in many farm
fields. I have made two off airport landings. One in daylight on a
deserted gravel country road. The other was on a very, very dark night
and it's by the grace of God that we walked away. 30 seconds earlier
we'd have been in the trees and a minute earlier we'd have been in a
lake. We made it to a two lane highway where traffic was all going one
direction. Passed under a power line on roll out. No bridges, signs or
trees. Landing light burned out 10 seconds after turning it on the
next time.
Gene Seibel
Gene & Sue's Flying Machine - http://pad39a.com/gene/
Because we fly, we envy no one.
Old October 30th 08, 04:13 PM posted to rec.aviation.piloting
Ross
one?
next time.
Gene Seibel
I have had two - both in winter - both dead stick. One in a wheat field
and it was the smoothest landing I ever did. One in a cut corn field and
the farmer plowed 90* to my landing path. One of the roughest landings.
Nose strut was still good, though.
Regards, Ross
C-172F 180HP
KSWI
Old October 30th 08, 06:03 PM posted to rec.aviation.piloting
Gezellig
Yes.
Yes.
alfalfa, or ????
Yes.
Yes.
one?
Yes Yes
Yes.
runway or airport?
Today.
proverbial pot.....
You can but it never gets below 42 where I am.
Of
problems.
Ol S&B
Can't right now, I got a TO in 30 mins.
Old October 30th 08, 10:41 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
http://www.flsc.org/Xcountry/Kai_Off_Arpt_Ldg.pdf
When your engine quits, you are a glider pilot too.
Geoff
Old October 31st 08, 02:06 AM posted to rec.aviation.piloting
Shirl
one?
runway or airport?
proverbial pot.....
problems.
Ol S&B
Yes. Oil cooler split on start-up, but gauges were normal/green during a
normal run-up and takeoff. Six minutes into the flight (long enough to
get away from the airport!), we had no oil pressure, and about 10
seconds after that, the engine seized. Thank goodness, we were over the
desert and not over buildings. But what looks good/flat at 100 feet,
doesn't look so flat at 50, and even less flat at 20. Coincidentally, I
was with my glider instructor, also a CFI-G and FAA DPE. Would have
rolled out okay if we hadn't hit a berm that launched us again. Slammed
back down, gear broke off. Plane was destroyed, but we thankfully walked
away, albeit shaken up. Just because it's dirt doesn't mean it's flat...
but still a lot better than the alternative. Look at the pavement behind
you when you taxi away (put it on your checklist!)...and have your oil
cooler flushed/pressure tested.
P.S. We had just practice simulated engine failures *2 weeks* prior, and
yes, it definitely helped during the real deal.
Old October 31st 08, 02:12 AM posted to rec.aviation.piloting
Sylvain
In addition to looking for oil leaks, there are other things that you may
want to look for on the pavement behind you when you taxi: like bits and
pieces of hardware. I found that out when flying with a dude who was
checking me out on a cherokee six; the piece of hardware he spotted (and
which I missed I must confess) was one of the three bolts that held the two
halves of one of our main wheels together; could have made for an
interesting landing had he missed it.
I keep looking now :-)
--Sylvain
Old October 31st 08, 02:14 PM posted to rec.aviation.piloting
Sometimes caused by really cold oil that the engine is trying to
shove through the cooler. A few of those episodes, each one swelling
the cooler a bit more, can bust it.
I've had a deadstick to a fallow grain field. I was looking at it
one day when I had my father out for a ride in the old 7AC, thinking
that it would be a good place to set down if I had to, and just then
the crankshaft busted. At 400 feet. Made it over the powerlines OK.
Done landings in stubble fields, on gravel roads, and in a pea-
stubble field, which was easily the smoothest surface of the bunch.
Used to tow gliders off grass. There are numerous farm grass strips
around here. And some of the paved highways are pretty lonely, too.
Dan
Old October 31st 08, 01:01 PM posted to rec.aviation.piloting
Flyingmonk[_1_]
one?
runway or airport?
proverbial pot.....
problems.
Ol S&B
Haven't done it in a plank yet, but plenty in a swingwing.
Monk
Off Airport Landings [email protected] Piloting 32 November 6th 05 01:00 PM
Video surveillance / recording of airport operations (landings, etc)? Fly Guy General Aviation 1 August 5th 05 01:20 AM
Airport Radial/Distance/Fix on Jepp Airport Chart Dave Johnson Instrument Flight Rules 9 May 2nd 04 11:03 PM
Night landings vs. day landings Gerald Sylvester Piloting 15 February 12th 04 06:38 AM
off airport landings Stan Gosnell Rotorcraft 8 September 13th 03 04:49 PM
