ID WWII airfield wreckage?
Old April 17th 04, 05:23 PM
Ryan
Default ID WWII airfield wreckage?
While going through my grandfather's war photo album, I came across a
photo of some German aircraft wreckage.
Only the tail sections are visible, and despite my efforts, I can't
identify them.
http://www.geocities.com/newsgrouppictures/
I would be fascinated to know what planes these are and any information
about when and where they were used.
-Ryan
Old April 17th 04, 07:28 PM
Bob's Your Uncle
"Ryan" wrote in message
-Ryan
Heinkel 177 - Greif and Gotha 242?
Old April 17th 04, 08:04 PM
machf
identify them.
-Ryan
Well, most of the wreckages appear to be Ju 52s... the one closest to the
camera may be a Ju 88.
__________ ____---____ Marco Antonio Checa Funcke
\_________D /-/---_----' Santiago de Surco, Lima, Peru
_H__/_/ http://machf.tripod.com
'-_____|(
remove the "no_me_j." and "sons.of." parts before replying
Old April 18th 04, 09:04 AM
John Keeney
identify them.
The biggest part of them appear to be JU 58's: all that corrugated
sheet metal is a big tip off. I think what may be confusing you is
that the rudders are missing from nearly all the vertical stabilizers;
the one exception near the center of the frame shows the over-all
shape you're looking for.
The left most tail section is something else. The tail's different
(the rudder appears to be that old style that extends a top portion
forward of the hinge line), not corrugated, comparable in size to
the Ju58, kind of slab sided, horizontal tail plane mounted high
on the fuselage; probably another transport or large bomber.
But I haven't a clue which one.
There just isn't enough of that large piece to the far right for me
to guess about what part of a plane it might be.
German planes aren't my strong point.
Ju 58's were transports and used every where by the WWII Germans:
they filled the same roles as the American C-47, just not as well.
Old April 18th 04, 10:13 AM
Guy Alcala
identify them.
Guy
Old April 19th 04, 07:01 AM
John Keeney
"Guy Alcala" wrote in message
identify them.
There are at least eight tail sections visible, part of
that total -in fact the biggest part, six- are very likely
to be Ju 58's and one other is likely a Ju 58.
Old April 18th 04, 11:19 AM
Keith Willshaw
"John Keeney" wrote in message
Funny I thought the aircraft that filled that role was the Ju-52
Keith
Old April 18th 04, 01:22 PM
Bob's Your Uncle
Keith
In Africa, the Gotha Go242 and 244 did that job!
Old April 18th 04, 03:39 PM
Keith Willshaw
"Bob's Your Uncle" wrote in message
Keith
No sir the Go-242 was an assault glider, the 244 was fitted
with 2 engines but was slow and exceptionally vulnerable.
Only 176 were in fact built
The mainstay of the air supply for the DAK was the JU-52
supplemented by the Me-323
Keith
Old April 18th 04, 03:23 PM
Peter Stickney
"Bob's Your Uncle" writes:
Keith
Erm... The Go 242 was a glider. Not much use without a powered
airplane to tow it. The airplane the Germans used was (Wait for it!)
The Ju 52.
The Go 244 was an attempt to build a powered Go 242. It wasn't
successful, being woefully underpowered. Two line units briefly
converted to the Go 244 from Ju 52s in early 1942. Within 6 months,
one (K.Gr.z.b.V 104) had converted to Me 323s, and the other,
(K.Gr.z.b.V. 106) had converted back to Ju 52s. The surviving Ar 244s
were used for a short time at the Parachute Training Schools.
Both the Go 242 and Go 244 were made of smooth plywood, and had
twin tails mounted on booms, rather than the substantial currugated
metal fuselages with large fins (& occasionally rudders) shown in the
photograph,
The squared-off currugated ones are Ju 52s. The more rounded one on
the left is a Ju 88.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 08:05 AM
FA: WWII B-3jacket, B-1 pants, Class A uniform N329DF Military Aviation 1 August 16th 03 04:41 PM
Vitre d'avion de la WWII ? WWII planes panes ? Dessocea Military Aviation 0 August 15th 03 08:07 PM
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In Zeno Aerobatics 0 August 2nd 03 08:31 PM
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In zeno Military Aviation 0 July 14th 03 08:31 PM
