The "darker side" of flying (Night Landings) with ATC COMS - Video
Old November 18th 08, 11:32 PM posted to rec.aviation.ifr
Default The "darker side" of flying (Night Landings) with ATC COMS - Video
Needed to get night current for an IFR flight next week. Since I have
not flown at night for quite some time, figure to give me an
adjustment period as day transitions to night.
Video includes slow flight while waiting for the sun to set, watching
the sunset from 3000 feet and two landings at KJAN.
http://www.youtube.com/watch?v=-STNsb2ZC7A
My next video will have the remainder of my landings back at KMBO.
Old November 19th 08, 11:02 PM posted to rec.aviation.ifr
Default The "darker side" of flying (Night Landings) with ATC COMS -Video
Night currency landings - video
Video is a continuation of my night currency video.
http://www.youtube.com/watch?v=Ayv1Mq3FC9M
This video captures one touch and go, one full stop landing and shut
down. Video includes uncontrolled airport communications.
Looking back at my log book it had been over 1 year (11/01.07) since I
had done any night flying,
Good overall exercise for me landing on runways of different widths.
Old November 20th 08, 01:19 AM posted to rec.aviation.ifr
B A R R Y[_2_]
Cool!
I've been messing with a Flip video, how'd you get the audio?
Barry
Old November 20th 08, 01:22 AM posted to rec.aviation.ifr
B A R R Y[_2_]
Al,
Here's one of mine...
http://www.bburke.com/images/NightArrivalKHFD20.wmv
I'd love to grab audio like you do!
Old November 20th 08, 02:10 AM posted to rec.aviation.ifr
Al,
Link not working above??? I get file not found....
I bought a digital recorder and also a patch cord.
http://aircraftpatchcord.com/ is where I got the patch chord. Total
cost was $80 for both cord and recorder. You do not need an expensive
recorder as I have a very cheap version.
Setup, nothing to it. Literally, plug it, set it (turn it on) and
forget it. Great way to time your flights LOL as I turn the recorder
on once I flip the master switch on and turn the recorder off when I
unplug it. Length of .mp3 file pretty much the time you were PIC of a
plane!
After flying, for my video, I put a prompt in when I turn the camera
on so that I know where to start in the audio. Then it's a matter of
syncing it up to the video. I say camera on and then camera off, and
on the final product, I edit the prompt out.
Stall horn loud enough to hear both through the digital recording and
the camera audio, so landing syncing very easy.
Old November 20th 08, 01:24 PM posted to rec.aviation.ifr
B A R R Y[_2_]
Weird... I sent it to others, and it worked. Sorry about that. Try
hitting it from he http://www.bburke.com/flying/videos.html
Ah-ha! That makes perfect sense! You just add the audio in when
editing the video. Since there's no movement that coincides with the
sound, it would be easy. I could ever record with laptop and sound card.
I can build patch cords, etc... I thought you were recording it
directly to the video. My cheesy camera doesn't have an Audio In jack.
Thanks!
Old November 20th 08, 10:41 PM posted to rec.aviation.ifr
On Nov 20, 7:24*am, B A R R Y wrote:
Weird... * I sent it to others, and it worked. *Sorry about that. *Try
hitting it from he *http://www.bburke.com/flying/videos.html
Worked, plus the benefit of viewing the other videos :-))) Didn't
need much runway for your PVC landing!
Ah-ha! * That makes perfect sense! *You just add the audio in when
editing the video. *Since there's no movement that coincides with the
sound, it would be easy. *I could ever record with laptop and sound card.
Somewhat true on the no movement. You have to be careful if ATC gives
you a heading that you match up the turn with the instruction. In
that case, I get the heading change, prompt myself "camera on for
heading 220", turn the camera on and make the turn. This ensures that
the movement / turn / bank of the cowling is in sync with the
instruction. Or in my no gyro video, that the instruction matched up
with the instrumentation values.
I do adjust the volume downward on my video portion, but you still can
hear me talk, so on low RPM situations, there is a slight "echo" if
you listen carefully enough. Also sounds like my flap making a click
in the indentation can be heard, so when I say flaps, in the video I
listen for that click to sync up with me saying flaps. Other then
these small nuances, it's not that bad in the sync process. Feel free
to email me if you want/need tech details of the video editing
aspect. Got a free programs that will help make it sooo much easier
with the sound clips.
I can build patch cords, etc... * I thought you were recording it
directly to the video. *My cheesy camera doesn't have an Audio In jack.
Cha-ching same situation, no audio in. My camera is just a shirt
pocket size Kodak Easyshare point and shoot camera. Not the full
blown version that really does run circles around mine for video
quality. I just couldn't justify the cost for a full blown video
camera, purchasing the "setup equipment" in the cockpit.
Old November 21st 08, 08:34 PM posted to rec.aviation.ifr
On Nov 21, 6:58*am, B A R R Y wrote:
I have 60 minutes available on the camera, and lots more on a voice
recorder, so I figured I'd just leave it on and splice later. *The
camera is a Flip Mino. *I convinced my wife that she needed to buy one
with _her_ spending money. *;^) *I'm playing with ways to mount it to my
headset, the support rod on the side of the glareshield, the right seat
back, or suctioned to the left side window.
I would have LOVED to have the AWOS audio on the PVC video.
Now you know why I play the ASOS especially for the instrument
approaches :-) The recordings says volumes when ceilings are extra
low.
Dicing and splicing easy enough and easy to edit out the blank spaces
between transmissions. For my videos, I have purposely not edited out
the blank spaces so it's as close to what I experienced as I can make
it. Would not be hard to make it "sound busier" then what it really
is :-))
I tried playing around mounting the camera on top of the visor of my
ball cap. It actually works fine, but if you move your head a lot, it
will be very, very distracting. I was surprised how much I moved my
head whether it be scanning for traffic, reading the approach plate
and such, so I decided on just leaving the camera on top of the
glareshield with a portfolio binder propping the camera so it doesn't
shift.
Sounds like you have a good setup for the various angles with your
camera. Be interested on seeing your outcome!
Old November 21st 08, 08:36 PM posted to rec.aviation.ifr
Meant to say in my other post, if you have two COMS and an external
speaker, for future flights, put COM two on the external speaker.
That is what I did before getting the patch cable and was clear enough
to hear over the din of the engine.
The "darker side" of flying (Night Landings) with ATC COMS - Video [email protected] Piloting 9 November 21st 08 10:44 PM
The "darker side" of flying (Night Landings) with ATC COMS - Video A Lieberma[_2_] Owning 2 November 21st 08 10:43 PM
Leighton Collins "Takeoffs and Landings" Jim Logajan Piloting 6 May 23rd 08 02:41 AM
Ruptured Duck on side of B-17 "Aluminum Overcast" at Lawrence, MA, 18-Sep-07 Tom Hayden Aviation Photos 0 August 25th 07 01:27 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [18/30] - "F22 left side, in burners.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 06:37 AM
