Sea Fury - Takeoff Flap - were they normally used?
Old April 25th 04, 04:44 PM
Howard Leipzig
Default Sea Fury - Takeoff Flap - were they normally used?
I have a scale Radio Control Sea Fury 88" wing span and I wanted to find
out:
Did the Hawker Sea Fury normally use any flaps for a land takeoff?
If so how much?
Does anyone have a copy of the takeoff check list?
Landing check list?
With thanks in advance,
Howard
Old April 25th 04, 05:21 PM
Specialty Press sells reprints of many WWII RAF & RN a/c "Pilot's
Notes", basically a flight manual, including the Sea Fury Mks 10 & 11.
It has all that info. I have the SeaFury one as well as several others,
about $20, IIRC. In answer to your question, mine says "Flaps" "Up
(airfield)" , "Max. Lift (catapult)" & "Take-off (carrier)". I would
assume "(carrier)" woud also equate to a short-field take-off setting
for an airfield as well.
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 10:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 06:01 AM
TAS vs. flap reflex angle ELIPPSE Home Built 3 January 13th 05 06:00 AM
FA: M18B Dromader Flap & Aileron BFC Aviation Marketplace 0 September 24th 04 04:29 PM
