Tungsten Disulfide burnishing
Old November 25th 08, 02:16 AM posted to rec.aviation.homebuilt
Default Tungsten Disulfide burnishing
With regard to engine assembly, I've received several queries that
generally went like this:
I need help in understanding how to burnish the coating on. I first
tried the dremmel but the stuff slung off, Then I went to the sponge
but it did not appear to be working , I am now attempting a coating
with the scotchbrite side. How did you do it?
Begin with a surface that is perfectly free of lubrication. There
might even be a slight haze of rust but that's okay; it will be
removed as the TDX is applied.
Start with your largest parts first, such as your cylinder barrels. I
found a tendency to use TOO MUCH of this stuff. I began with a
conical pile of powder about 1/8" (3mm) high. I used a 'distressed'
toothbrush to apply the powder, working from both ends of the barrel.
( 'Distressed' meaning the toothbrush was not new; the bristles were
spread out; not the sort of thing you'd want for brushing teeth. ) I
didn't apply much pressure. With the barrel on the edge of the work
bench and myself comfortably seated, I worked the powder into the
surface with a left-right motion for about half the depth of the bore
then turned the barrel end for end, applied another pile of powder and
repeated the process.
The barrel was then rotated 180 degrees and the procedure was
repeated. By the time I finished the fourth surface it was obvious
that the toothbrush, which was a 'fine-toothed' or soft-bristled type,
was wholly impregnated with the powder.
This procedure uses more TDX than is needed, as you will discover in
the next step. Unfortunately, I haven't found a more economical
method of applying the powder.
I made up a pad of 0000 steel wool and commenced burnishing the barrel
by holding the pad with my fingers whilst wearing a Nitrile glove on
that hand. I rotated the barrel several times as needed, always
working from the same end. When I achieved a surface having a uniform
appearance I flipped the barrel end for end and repeated the same
procedure working from the lower end.
By the time I finished the first barrel the toothbrush and the
burnishing pad were impregnated with the powder.
I repeated the procedure on the other three barrels, using slightly
less TDX than on the first. Indeed, as the work progressed I was able
to recover some TDX by tapping the toothbrush against the barrel.
When all four barrels were done I stored the toothbrush, burnishing
pad and rubber glove in a plastic bag. The barrel(s) then received a
few drops of 30W motor oil which was spread using a pad made from a
piece of paper toweling. A new glove was used for this. The pad
appeared to pick-up a considerable quantity of TDX in that it turned
black. After the second or third barrel there was no need to add any
oil, the pad being fully impregnated. The oily pad and the oily
rubber glove were stored in a plastic bag.
This procedure takes 20 to 30 minutes per barrel.
Generally, this same procedure was used for all other steel parts.
Cast iron parts, such as the camshaft and cam followers, required
slightly more powder per unit of surface area. The cam-followers
were held in the hand and rotated against the impregnated pad of steel-
wool. The upper machined portion of the distributor's driven-gear
received a similar treatment, in that the distributor's driven-gear
was held in one hand whilst being rotated against the steel-wool pad.
The ends of the push-rods were rotated against a paper pad charged
with about one cylinder's-worth of TDX.
The cam gears were simply brushed. No effort was made to burnish
them. No TDX was applied to the bronze scroll-gear but was applied to
the cast-iron driven-gear as well as the shims.
When doing the crankshaft, degreasing was done to each journal
individually using lacquer thinner. After the work was done a small
nylon-bristle bore-brush was used to clean the oiling channels to rid
them of any residue from the steel-wool pad. The same cleaning was
done for the modified rocker arms, using pipe-cleaners rather than a
bristled brush.
When doing the camshaft and crankshaft I tried using a 'shoe-shine'
motion and a paper towel, folded to a suitable width and backed-up
with duct tape. The TDX was applied to the shaft and distributed with
the toothbrush before being 'shined.' This method seemed to work
pretty well but the paper wore out quickly .
CYLINDER HEADS
The cylinder heads were done at a different time than assembly of the
lower end, and preparation of the cylinder barrels. Some of the
procedures differed slightly but I gained the impression from Leonard
that the idea was to apply, and to burnish into, the powder into a
bare, unlubricated surface. Toward that end, I burnished the shims by
rubbing them against a piece of fine-gauge steel-wool impregnated with
TDX, whereas I did the warpy washers by hand.
The valve stems were burnished by 'pumping' them back & forth through
a steel-wool pad impregnated with TDX. TDX was applied to the
degreased guides using a nylon bristle brush.
No TDX was applied to the swivel-foot adjustment screws. These parts
had been soaked in oil for several days and I didn't think I could
remove all of the oil. Instead, TDX was applied to the tip of the
valve stem.
During my first experiments with TDX, using 1-cylinder lawn mower
engines, I tried using applicators made of 1/4" wooden dowels, sawn
to accept cloth or steel wool pads. This was chucked into a 1/4"
variable-speed drill-motor. Other experiments used a variable-speed
Dremel tool, cotton pads and wire brushes. Inspection of the
resulting surface at about 7x showed better results were obtained when
the TDX was applied by hand. 'Better' in this case included economy
of application, in that using powered tools tended to waste a lot of
TDX, as compared to applying it by hand.
Finally, I should repeat that I've only applied TDX and the various
coatings to ONE full-scale engine, a 1600 assembled from salvaged
parts and configured for vehicular use. The parts were 'to spec' but
often on the high side, especially with regard to the bearings.
My original intention was to run this engine to death on the test
stand, with periodic tear-downs to document wear. Unfortunately, the
high cost of gasoline forced me to discontinue the running of this
engine after it accumulated about 80hours. At that time I tore down
the right-hand head. Unfortunately, there was nothing to report.
There was no evidence of any wear at all.
-R.S.Hoover
Old November 25th 08, 03:52 AM posted to rec.aviation.homebuilt
To All:
'TDX' should read 'WSX.'
My recent medical problems has spawned a number of memory glitches,
such as the above.
-R.S.Hoover
Old November 25th 08, 11:01 AM posted to rec.aviation.homebuilt
Morgans[_2_]
To All:
What does that stand for?
Old November 26th 08, 12:58 AM posted to rec.aviation.homebuilt
Bob is that Tungsten?, or should it be Molybdenum Disulphide ??
W = Wolframite = Tungsten
(Moly is M or Mo)
Go to the site, read the specs. Burnishing Wolfram Disulfide into the
surface converts it into a virtually friction-free metal, allowing you
to assemble your engines to tighter tolerances. When combined with
some of the ceramic-based coatings that allow better management of
your waste heat, you can build a more durable, more efficient engine.
But YOU will have to build it -- it costs the earth to have the
coatings applied.
-R.S.Hoover
Old November 25th 08, 11:33 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Mon, 24 Nov 2008 19:52:42 -0800 (PST), "
To All:
such as the above.
-R.S.Hoover
If it is I blame the mauve pills :-)
xxx
ol' Snake unda the verandah.
Old November 25th 08, 03:53 PM posted to rec.aviation.homebuilt
jerry wass
To All:
such as the above.
-R.S.Hoover
xxx
W is the chemical symbol for Tungsten-(Wolframite)--1st found in Germany
S is sulfer
Molybdenum would be Mo
Old November 25th 08, 05:33 PM posted to rec.aviation.homebuilt
I believe he did in fact mean Tungsten. See page 4 of this link:
http://www.indykote.com/PDF-files/In...uly%202004.pdf
As a side note back in the 60's my father sold Honda motorcycles - and
- an oil additive that included MDS. We did not do strict scientific
experiments but from observation of a fleet of several hundred units
there was a very good correlation between the use of the MDS and
increased fuel mileage, longevity, and decreased wear. I tried a
similar product several years ago but unfortunately I did not get the
same results. One explanation may be that the old Hondas did not have
oil filters and the particles in the newer product were simply
filtered out.
Maybe for VW use one could simply add the WSX after the first oil
change along with a cored oil filter - if one is using a
filter ......... as they should. It "worked" on 60's vintage Hondas.
Leon McAtee
To All:
such as the above.
-R.S.Hoover
Old November 26th 08, 11:31 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Tue, 25 Nov 2008 09:33:45 -0800 (PST), "
filtered out.
at one stage the local motor cycle oils dried up as businesses went to
the wall so I used castrol GTX which has molybdenium disulphide in it.
after about a thousand km my clutch would slip and nothing I did could
stop it. until I used straight oil with no moly disulphide, whereupon
the clutch would stop slipping. the additives work.
tungsten ... interesting.
Stealth Pilot
Old November 26th 08, 01:25 PM posted to rec.aviation.homebuilt
On Nov 26, 3:31*am, Stealth Pilot
That's a roger.
'Way back when... late 60's or early 70's... DOD's POL czar issued a
notice to add Molybdenum Disulfide to the tranny & differentials of
ALL rolling & tracked stock. This was extremely unusual since these
people are ultra conservative with regard to additives. Their Notice
was backed up by the usual bum-fodder. This was soon followed by a
similar notice from BuAir to do the same thing a (ie, add MoS) to the
GPU's & line tractors. The stuff came in a little olive-drab can
about the size of a fruit juice can. The Moly was in a suspension of
90W gear lube and you had to scrape the can to be sure of getting it
all out. We put it in our trannys, differentials, winch gear-boxes
and engines. Some guys even put in GPU's and line tractors :-)
The handiest applicator was a squeeze-tube of the stuff, sold by
FLAPS. You could order it from J.C.Whitney if you couldn't steal it
from your uncle Sam.
Moly lube for CV joints is one of those 'secret weapons' used by
professional engine assemblers, especially with regard to the cam &
tappets. I think I showed a tube of it in my blog article about
chemicals needed when assembling an engine.
Don't stop with your engine. If you've got any tools in your shop
(lathe, mill, etc.) adding Moly Lube to any gear train virtually shuts
down wear. You can actually HEAR the thing running quieter. Ditto
for gunsmithing, although you've got to be careful about using too
much. Use a match-stick or toothpick to add just a dot of moly lube
to friction points, especially in the locks of muzzle loaders.
Moly is one of those things that works so well -- and has been around
for so long -- that you ASSUME everyone is aware of it. But you still
run in to those 'instant' experts showing kids how to assemble an
engine who never mention the stuff.
-R.S.Hoover
PS -- DOD = Department of Defense. POL = Petroleum, Oil &
Lubricants. (DoD has a POL lab at Ft. Knox (I think). Among other
things, they test lubricants purchased by DoD.) CV = Constant
Velocity, as in the CV joints on most modern-day trannys.
Old November 26th 08, 05:50 PM posted to rec.aviation.homebuilt
Anthony W
Stealth Pilot
Interesting. I've been using Castrol GTX in my cars and bikes but I
don't think the stuff in the USA has the molybdenium disulfide in it.
All the moly oils I'm aware of are black or close to it. Anyway I'll
buy another bottle and check the label.
Tony
For sale, Cable - DB9 to Tungsten T PDA Fred[_4_] Soaring 0 April 30th 08 05:34 PM
