Survival Rifle
Old November 26th 08, 11:59 PM posted to rec.aviation.homebuilt
Default Survival Rifle
Those of you familiar with my Blog have probably read the several
articles therein about survival. And yes, I've poked a bit of fun at
those who think survival can be measured by the size of your knife.
But an on-going thread, bounced around amongst a few of use keeps
coming back to the little survival rifle/shotgun (called a 'drilling'
in gunsmith-speak) the Air Force included in their comprehensive
survival pack. As best I can recall this was a .22 Hornet rifle / .
410 shotgun that folded up. Ammunition was carried in the stock,
which was all aluminum.
The purpose of such a weapon was not defense but a means of feeding
yourself.
There are civilian versions of such over & under weapons but they are
heavy and tend to be expensive. But last night I stumbled upon what
may be a suitable substitute: A black-powder pistol. (!??)
A cap & ball pistol, typically a replica (the real thing, in good
condition, is worth thousands of dollars) is inexpensive and not very
heavy. It's also not very accurate :-) ...but hear me out before
condemning the idea.
With black-powder you pour a measured amount of powder into one of the
six chambers then insert a wad of some sort, atop which you place a
round ball, a cone shaped bullet OR A MEASURED AMOUNT OF BIRDSHOT.
Another wad is installed atop the bullet and the charge is compressed
using the lever built-in to the underside of the barrel. A percussion
cap is then installed on the nipple and you go on to the next chamber.
There are a couple of features not generally known to those who do NOT
regularly fire black-powder weapons... especially cap & ball ...that
makes this idea worthy of thought. One is that when we do away with
the cartridge case -- the brass part of the 'bullet' -- the weight &
cube of our ammunition. Fifty rounds for a black-powder weapon weighs
but a fraction of 50 rounds for a regular pistol. And since the ammo
is not made-up it does not have a prescribed shape. This allows you
to store the bullets, powder and caps in whatever space is most
convenient. Another factor is that you'll probably find shot to be
more useful than ball... yet you'll still want to keep one or two
chambers charged with ball. This presents no problem. The other four
chambers may be charged with shot, fired, then charged again, leaving
the chambers charged with ball (or with a conical bullet) undisturbed,
giving you one or two 'insurance' shots to protect yourself from the
ravages of an enraged porcupine or ptarmigan.
Firing shotgun pellets through a rifled bore does neither the bore nor
the pellets any good but given the purpose of this weapon the
traditional arguments against this kind of use have no basis.
Just a thot. Outside the box.
-R.S.Hoover
Old November 27th 08, 02:13 AM posted to rec.aviation.homebuilt
Dana M. Hague[_2_]
On Wed, 26 Nov 2008 15:59:28 -0800 (PST), "
yourself....last night I stumbled upon what
There are some pretty significant disadvantages as well. Reloading
takes time, bad weather can be a problem (the old expression "keep
your powder dry" isn't just an expression), and the knockdown/stopping
power is considerably less than a modern weapon. Then there's the
risk of chain fires if you don't slob grease over the loads.
If I'm in a survival situation, I want a gun that I can reload in a
driving rain, and KNOW that it will fire.
There are other handguns that can fire shot shells. Shot shells are
available in various pistol caliber sizes, and there are revolvers and
derringers that chamber both .45 Colt and .410 shotgun shells.
I still hold to a .22 as probably the best survival rifle. Not much
stopping power for large game (though the world record black bear was
taken with a .22!), but it's great for the small game that's more
likely to keep you fed, and _lots_ of ammo doesn't weigh much.
-Dana
Change is inevitable, except from a vending machine.
Old November 27th 08, 02:51 AM posted to rec.aviation.homebuilt
Anthony W
-Dana
Additional barrels in various calibers and shotgun gages can be bought
for NEF single shot rifles. These rifles are light and way more
accurate than the under $200 new price tag would suggest. Having
another barrel fitted (in most calibers) is under a hundred bucks.
The one caveat is no rim-fire calibers on a center-fire frames. I have
one in .223 Rem, and I'm planning to get a .22 Hornet and a .45 Colt
barrels for it. I could shoot .410 shot shells in the .45 Colt barrel
and the shot cup would keep the rifling from chewing up the shot.
This rifle with the 2 barrels and 50 rounds of ammo for each would
easily pack away behind the seat of your plane if you're flying out in
an off the grid area. Or perhaps just the .45 Colt barrel but then
you'd have to rely on .410 shotgun rounds to take squirrel sized game if
you are to stay fed until help finds you.
WWII German Luftwaffe pilots had drilling rifle/shotguns. These usually
had 2 shotgun barrels and a rifle barrel either under or over the
shotgun barrels and centered between the two. Drilling is the German
word for triple so they always had 3 barrels. The US pilots had a an
over under .22 hornet over a .410 gage shotgun. A couple companies
reproduce these but I don't think they're worth the money. Savage has
made over under rifle/shotgun combos for many years but again I think
they sell for more than they're worth.
Tony
Old November 27th 08, 03:31 AM posted to rec.aviation.homebuilt
bildan
I still hold to a .22 as probably the best survival rifle. *Not much
-Dana
for NEF single shot rifles. *These rifles are light and way more
accurate than the under $200 new price tag would suggest. *Having
The one caveat is no rim-fire calibers on a center-fire frames. *I have
barrels for it. *I could shoot .410 shot shells in the .45 Colt barrel
an off the grid area. *Or perhaps just the .45 Colt barrel but then
WWII German Luftwaffe pilots had drilling rifle/shotguns. *These usually
shotgun barrels and centered between the two. *Drilling is the German
word for triple so they always had 3 barrels. *The US pilots had a an
over under .22 hornet over a .410 gage shotgun. *A couple companies
reproduce these but I don't think they're worth the money. *Savage has
Tony
Once while still young and stupid, I came into the possession of a
single action .22 revolver that was very old and rusty. When I
cleaned it up, I saw there was no rifling in the barrel. The rifling
may have just rusted away or I polished it away while cleaning it up
or it was never there in the first place - whatever.
Well, what to do with a smoothbore .22 but fire birdshot rounds with
it? I found at about 10 feet it had about a 12" pattern - not bad for
a 8" barrel. It would drive the tiny birdshot pellets about an 1/8"
into pine boards at that distance. About the only thing it was good
for was shooting desert sparrows and such. (Remember, I confessed to
young and stupid.)
I worked with the pistol until I could reliably fast-draw, cock and
fire the single action while dropping to a gunfighter stance. (At
least I sensibly kept the hammer down on an empty cylinder while in
its holster)
I had a fairly good eye and could down a flushed sparrow with better
than 50/50 odds. This got me the reputation of "El Pistolero" with
school chums who were never told it was loaded with birdshot. (Many
years later it was used to rid hangars of pigeons without blowing
holes in the roof - or in parked airplanes with ricochets.)
Survival gun? No way. This thing would have been useless for that.
Old November 27th 08, 04:54 AM posted to rec.aviation.homebuilt
Monk
-Dana
Tony
I was just in Dick's Sporting goods the other day and they are having
a special on a youth break action single shot .22 with an additional .
410 or 20ga. barrel for only $89.
I'm getting one for my little daughter for Christmas.
Monk
Old November 27th 08, 05:42 AM posted to rec.aviation.homebuilt
Anthony W
Monk
That's a killer deal. It's too bad there isn't a Dick's Sporting goods
here in the Portland, Or area. With a .22 rim fire and a 20 gage you
could hunt all sized game you would run across when stuck out in the
middle of nowhere.
Tony
Old November 27th 08, 02:16 PM posted to rec.aviation.homebuilt
Dana M. Hague[_2_]
On Thu, 27 Nov 2008 02:51:30 GMT, Anthony W
accurate than the under $200 new price tag would suggest...
I'll second that; I bought a NEF 20 gauge with a slug barrel for my
daughter when she was 14. It's beautifully finished, the action is
very solid, and it's a tack driver out to 100 yards with sabot slugs.
Not what I'd pick for a survival gun, but then again it might not be
such a bad choice.
I also have one of the FMJ 2 barrel .45LC/.410 derringers. It's a
piece of junk in a way, but it does what it's supposed to do,
reliably, and the under $100 price can't be beat. I bought it mainly
for backpacking. It can also shoot .410 slugs as well as the ,45's,
but though I tried it on the one occasion I found a box of .410 slugs
in a store (why do they even make such a thing?) I don't know offhand
which would be better ballisticly.
The AR-7 breakdown .22 is very popular in Alaska, where I understand
(perhaps somebody can confirm?) by law you must carry a firearm in
your aircraft. People that think the law is silly go for the cheapest
solution, and the AR-7 is cheap. The Marlin Papoose, though, is
similar but a _much_ higher quality gun. I use mine for squirrel
hunting on occasion. It breaks down in a similar manner and although
it doesn't store inside the stock, its stock isn't so big and clunky
as the AR-7; the Papoose comes with a nice little case. Like the
AR-7, it floats _IF_ it's in the case and IF you don't throw away the
styrofoam insert that comes with it.
-Dana
America is at that awkward stage. It's too late to work within the system,
but too early to shoot the *******s.
Old November 27th 08, 02:54 PM posted to rec.aviation.homebuilt
Dan[_12_]
such a bad choice.
-Dana
AR-7 will float on its own whether assembled or not. For us lefties
the stock can be a handful while shooting.
Dan, U.S. Air Force, retired
Old November 27th 08, 09:44 PM posted to rec.aviation.homebuilt
Morgans[_2_]
What makes a difference, left vs. right? Is the stock not symmetrical?
Old November 30th 08, 02:28 AM posted to rec.aviation.homebuilt
your aircraft.
A quick web search turned up this site:
http://www.equipped.com/ak_cnda.htm
Seems at one time it was required to carry a firearm - but no longer.
Also I won't be flying up there any time between October 15 and April
1. I haven't enough room to carry the required items................
Leon McAtee
Predator w/Sniper Rifle 2 Dav1936531 Military Aviation 7 May 22nd 04 09:25 PM
Predator w/ Sniper Rifle Dav1936531 Military Aviation 31 May 17th 04 10:00 PM
Minesweeping by rifle fire. JDupre5762 Naval Aviation 7 December 29th 03 01:13 AM
Hitting airliner with rifle round? [was: PK of Igla vs. airliner] B2431 Military Aviation 7 August 20th 03 11:29 PM
