Seaplane rating
Old November 28th 08, 05:49 AM posted to rec.aviation.piloting
Dallasâ„¢
Default Seaplane rating
Wouldn't a pilot flying a seaplane with only a ASEL showing in the FAA
Registry be in violation?
Dallas
Old November 28th 08, 08:03 AM posted to rec.aviation.piloting
Depends on the certification of the seaplane. If it's experimental, he
doesn't need the rating to fly solo.
Old November 28th 08, 10:33 PM posted to rec.aviation.piloting
BT
explain that one further please? what does experimental have to do with it?
In the USA
BT
"Ron Wanttaja" wrote in message
Old November 28th 08, 10:56 PM posted to rec.aviation.piloting
Robert Moore
with it? In the USA
FAR 61.31
(k) Exceptions.
(1) This section does not require a category and class rating for aircraft
not type-certificated as airplanes, rotorcraft, gliders, lighter-than-air
aircraft, powered-lifts, powered parachutes, or weight-shift-control
aircraft.
(2) The rating limitations of this section do not apply to—
(i) An applicant when taking a practical test given by an examiner;
(ii) The holder of a student pilot certificate;
(iii) The holder of a pilot certificate when operating an aircraft under
the authority of—
(A) A provisional type certificate; or
(B) An experimental certificate, unless the operation involves carrying a
passenger;
Bob Moore
Old November 28th 08, 11:09 PM posted to rec.aviation.piloting
BT
Thanx Bob... that's a new wrinkle I had not seen..
BT
"Robert Moore" wrote in message
5.250...
with it? In the USA
FAR 61.31
(k) Exceptions.
aircraft.
(2) The rating limitations of this section do not apply to-
the authority of-
passenger;
Bob Moore
Old November 28th 08, 11:34 PM posted to rec.aviation.piloting
Morgans[_2_]
"BT" wrote in message
Although, there are ways the FAA can make it difficult for you.
At a EAA flyin, a FAA inspector guy told us that although you were not
required to have a seaplane rating for an experimental seaplane, if he was
doing the signing off the inspection before the initial test period and knew
the person going to fly it was not seaplane rated, he would likely make the
restrictions something like "only to fly on the last Tuesday in the month
after a full moon at full tide and only if the full tide maximum occurs at
2:00 PM."
You get the idea. He wanted to make sure a person flying a brand new
homebuilt was rated for the aircraft.
Old November 29th 08, 09:34 AM posted to rec.aviation.piloting
Dave S
BUT... if you are carrying passengers, the exception doesnt hold, and
you have to have the cat/class for the plane.. (restating what was
mentioned initially..)
BT
5.250...
with it? In the USA
FAR 61.31
(k) Exceptions.
aircraft.
the authority of-
passenger;
Bob Moore
Old November 28th 08, 11:52 PM posted to rec.aviation.piloting
Dallasâ„¢
passenger;
(C) Owner of aircraft is married to the Governor of the State.
Dallas
Old December 2nd 08, 05:27 PM posted to rec.aviation.piloting
Gig 601Xl Builder
Default Another Question Seaplane rating
Robert Moore wrote:
with it? In the USA
FAR 61.31
(k) Exceptions.
aircraft.
the authority of—
passenger;
Bob Moore
Let's say a person holds a Private A-SEL and Rotorcraft-Helicopter but
has chosen to NOT get a medical and flies LSA class fixed wing aircraft.
Can that person fly and Ex-HB Helicopter without a medical?
Old December 2nd 08, 05:53 PM posted to rec.aviation.piloting
Robert Moore
aircraft. Can that person fly and Ex-HB Helicopter without a medical?
NOPE! But the regs do permit a Private A-SEL pilot to fly it without
having a Rotorcraft-Helicopter rating. That's what the reg says, however
I understand that to deal with this loop-hole, that the FAA individual
who "signs-off" the experimental helicopter usually writes into the
operating limitations that the pilot shall posess an appropriate rating.
Bob Moore
Seaplane Base 1 - Leaving the Seaplane Base-2.jpg (1/1) john smith[_2_] Aviation Photos 2 August 2nd 07 08:37 AM
Moosehead seaplane fly-in Cub Driver Piloting 4 August 2nd 05 01:28 PM
Seaplane Rating Add-On and Seaplane Rental Peter Bauer Piloting 10 May 29th 05 11:53 AM
Seaplane Gliders Burt Compton Soaring 0 September 24th 04 01:45 PM
rotorcraft commercial rating or better rating advice Rick Cook Rotorcraft 0 October 13th 03 04:49 PM
