(USA) FAA airport database in Google Earth (KML) files
Old November 28th 08, 03:48 AM posted to rec.aviation.soaring
Tuno
Default (USA) FAA airport database in Google Earth (KML) files
http://www.justsoar.com/public/nasr_apt/
These kml files provide an easy way to browse airports in Google Earth
(current motivation is to examine privately owned strips for
landability -- yer welcome, 66!).
Each file covers an FAA region as follows:
CODE REGION NAME
AAL ALASKA
ACE CENTRAL
AEA EASTERN
AGL GREAT LAKES
AIN INTERNATIONAL
ANE NEW ENGLAND
ANM NORTHWEST MOUNTAIN
ASO SOUTHERN
ASW SOUTHWEST
AWP WESTERN-PACIFIC
Each file is subdivided into public and private airports.
Some notes to keep in mind while browsing:
- Only facilitytype = AIRPORT and GLIDERPORT are included in the
conversion. Lots of heliports and ultralight strips were dropped on
the floor.
- Private airports are plotted with green runways; public with blue.
Closed airports (public or private) are plotted with red runways.
- The NASR database has one RWY record for each runway at each
airport. However, most private airports (and a number of public ones)
do not have endpoint (base and reciprocal) geo locations in their
runway records; in this case, my conversation software assumes that
the given location for the airport is the center of the runway(s).
This is what you see when the plotted runway(s) are offset from the
Google Earth image (and multiple runways appear as an X).
- For the airports with complete RWY records, most of the data are
very good, with runway plots very closely matching the image in Google
Earth.
- There are still lots of errors in the FAA database. It has active
airports that haven't existed in years (see COOPER RANCH in Arizona --
it is just a hillside now). Some of the locations are off by a mile or
two (see SPENCER NOLF, the only airport in the database with 8
runways).
Enjoy
~ted/2NO
Old November 28th 08, 04:54 PM posted to rec.aviation.soaring
bildan
CODE * * * * * REGION NAME
AAL * * * * * *ALASKA
ACE * * * * * *CENTRAL
AEA * * * * * *EASTERN
AGL * * * * * *GREAT LAKES
AIN * * * * * *INTERNATIONAL
ANE * * * * * *NEW ENGLAND
ANM * * * * * *NORTHWEST MOUNTAIN
ASO * * * * * *SOUTHERN
ASW * * * * * *SOUTHWEST
AWP * * * * * *WESTERN-PACIFIC
the floor.
Earth.
runways).
Enjoy
~ted/2NO
Very cool!
Now, we need people to go to these strips and photograph them from the
ground and post the photos on Google Earth with notes.
Old November 30th 08, 12:45 AM posted to rec.aviation.soaring
Eric Greenwell
That would be great. and it wouldn't even have to be a ground visit to
be useful. Just a pilotflying over a strip and looking down can get the
information you need, if he posts it on Google Earth.
The next step would be a "checkbox" in Justsoar, directing it to include
the comments for all the strips when you downloaded a database, so you
could see them inflight, when it really mattered. The comments would
have to be dated, so the pilot could decide how much he wants to trust them.
Old November 28th 08, 04:57 PM posted to rec.aviation.soaring
Andy[_1_]
Which file includes Arizona? I tried ASW first, then ASO. My
computer is far too slow to try them all. It also seems I don't
support clamped polygons.
thnaks
Andy
Old November 28th 08, 05:08 PM posted to rec.aviation.soaring
Andy[_1_]
Which file includes Arizona? *I tried ASW first, then ASO. *My
computer is far too slow to try them all. *It also seems I don't
thnaks
Andy
My next guess was AWP but that produces a parse error at line 1127
column 103.
Andy
Old November 28th 08, 05:30 PM posted to rec.aviation.soaring
Tuno
Andy, what version of GE are you using?
Regardless, I've removed the clampToGround altitude mode since that
should be the default for polygons in all versions, and refreshed the
files. Let me know if you have any more trouble.
~tuno
Old November 28th 08, 06:06 PM posted to rec.aviation.soaring
Andy[_1_]
~tuno
The refreshed AWP file does not give me the parse error and displays
ok. The parse error was unique to that file and did not appear in the
pre-refresh ASW or ASO files. GE version is 4.2.0181.2634 beta. It
does not tell me an update is available and that is what usually
prompts me to do it. It may be that my computer dos not support the
newer version. I'll check later.
Andy
Old November 28th 08, 05:10 PM posted to rec.aviation.soaring
Tuno
Andy,
Arizona is in the AWP (Western-Pacific) file. You just needed to try
one more!
If you GE doesn't support clamped polygons you should probably upgrade
your version. Mine is 4.7.3xxxx. (I haven't yet found a runway that
wasn't clamped to the ground.)
2NO
Old November 28th 08, 05:00 PM posted to rec.aviation.soaring
kirk.stant
Thanks Tuno!
Now we just have to convince Google Earth that we need the whole world
in up-to-date 1m resolution!
(Check a recent AvWeek for a Frech proposal to do this, with an update
rate of monthly or so - commercially available! That'll **** off the
security freaks!).
Kirk
66
Old November 28th 08, 05:18 PM posted to rec.aviation.soaring
Tuno
I've had a report from one user whose computer changed the file name
to use .xml extension instead of .kml. If you have trouble, check that
your pooter didn't do the same.
Also I've placed a copy of the NASR's schema file for the airport
database in the web site he
http://www.justsoar.com/public/nasr_...pec/apt_rf.txt
You can browse the schema file and if you see any fields in there you
want to see in the .kml data (e.g. added to the popup description),
let me know. (The descriptions currently contain airport owner and
manager contact info and comm frequencies, when provided.)
-ted/2NO
What on (Google) Earth... ?? GM Soaring 9 March 28th 08 05:54 AM
Google Earth Frank Whiteley Soaring 3 November 16th 07 01:36 AM
Google Earth fun Al Denelsbeck Aviation Photos 4 January 11th 07 05:31 PM
GPS Visualizer now supports Google Earth & airport codes Adam Schneider Piloting 6 November 29th 05 10:25 PM
GPS Visualizer now supports Google Earth & airport codes Adam Schneider Soaring 6 November 29th 05 10:25 PM
