Stall Characteristics
Old December 4th 08, 02:45 PM posted to rec.aviation.homebuilt
w3n-a
Default Stall Characteristics
http://w3n-a.blogspot.com/2008/12/st...teristics.html
Because of engineering design variations, the stall characteristics
for all airplanes cannot be specifically described; however, the
similarities found in small general aviation training-type airplanes
are noteworthy enough to be considered. It will be noted that the
power-on and power-off stall warning indications will be different.
The power-off stall will have less noticeable clues (buffeting,
shaking) than the power-on stall. In the power-off stall, the
predominant clue can be the elevator control position (full up-
elevator against the stops) and a high descent rate. When performing
the power-on stall, the buffeting will likely be the predominant clue
that provides a positive indication of the stall. For the purpose of
airplane certification, the stall warning may be furnished either
through the inherent aerodynamic qualities of the airplane, or by a
stall warning device that will give a clear distinguishable indication
of the stall. Most airplanes are equipped with a stall warning
device.
Q: C-152 spin characteristics gatt[_2_] Piloting 27 January 29th 08 10:22 PM
ASW 20 SPIN CHARACTERISTICS Ventus B Soaring 79 July 21st 04 07:46 AM
R/C Airplane Flight Characteristics Ralph the Red Piloting 8 December 3rd 03 11:41 AM
Sonerai II Flying Characteristics JR Home Built 4 September 16th 03 10:08 AM
F105 ACM Characteristics Dudley Henriques Military Aviation 4 September 15th 03 03:19 PM
