http://w3n-a.blogspot.com/2008/12/secondary-stall.html
This stall is called a secondary stall since it may occur after a recovery from a preceding stall. It is caused by attempting to hasten the completion of a stall recovery before the airplane has regained sufficient flying speed. When this stall occurs, the back-elevator pressure should again be released just as in a normal stall recovery. When sufficient airspeed has been regained, the airplane can then be returned to straight-and-level flight. This stall usually occurs when the pilot uses abrupt control input to return to straight-and-level flight after a stall or spin recovery. It also occurs when the pilot fails to reduce the angle of attack sufficiently during stall recovery by not lowering pitch attitude sufficiently, or by attempting to break the stall by using power only. http://w3n-a.blogspot.com/2008/12/secondary-stall.html |
w3n-a wrote:
[ Elided ] Poster's messages are intended to generate web traffic for personal gain. |
Jim Logajan wrote: w3n-a wrote: [ Elided ] Poster's messages are intended to generate web traffic for personal gain. Killfiles were for his sort of ilk invented. |
"w3n-a" wrote in message
... http://w3n-a.blogspot.com/2008/12/secondary-stall.html Report the spammer at http://help.blogger.com/?page=contact&skipLogin=true |
Secondary Stall | w3n-a | Owning | 12 | December 10th 08 07:13 PM |
Secondary Stall | w3n-a | General Aviation | 10 | December 10th 08 07:10 PM |
Secondary Stall | w3n-a | Piloting | 18 | December 10th 08 07:10 PM |
Secondary Stall | w3n-a | Products | 10 | December 10th 08 07:10 PM |
Secondary Stall | w3n-a | Home Built | 3 | December 10th 08 12:36 PM |
