Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Secondary Stall
Old December 7th 08, 02:00 AM posted to aus.aviation,rec.aviation.aerobatics,rec.aviation.homebuilt,rec.aviation.ifr,rec.aviation.marketplace
w3n-a
Default Secondary Stall
http://w3n-a.blogspot.com/2008/12/secondary-stall.html
This stall is called a secondary stall since it may occur after a
recovery from a preceding stall. It is caused by attempting to hasten
the completion of a stall recovery before the airplane has regained
sufficient flying speed. When this stall occurs, the back-elevator
pressure should again be released just as in a normal stall recovery.
When sufficient airspeed has been regained, the airplane can then be
returned to straight-and-level flight.
This stall usually occurs when the pilot uses abrupt control input to
return to straight-and-level flight after a stall or spin recovery. It
also occurs when the pilot fails to reduce the angle of attack
sufficiently during stall recovery by not lowering pitch attitude
sufficiently, or by attempting to break the stall by using power
only.
Old December 7th 08, 08:32 PM posted to aus.aviation,rec.aviation.aerobatics,rec.aviation.homebuilt,rec.aviation.ifr,rec.aviation.marketplace
Jim Logajan
w3n-a wrote:
[ Elided ]
Poster's messages are intended to generate web traffic for personal gain.
Old December 7th 08, 09:21 PM posted to aus.aviation,rec.aviation.aerobatics,rec.aviation.homebuilt,rec.aviation.ifr,rec.aviation.marketplace
Steve Hix
Jim Logajan wrote:
w3n-a wrote:
[ Elided ]
Killfiles were for his sort of ilk invented.
Old December 10th 08, 12:36 PM posted to aus.aviation,rec.aviation.aerobatics,rec.aviation.homebuilt,rec.aviation.ifr,rec.aviation.marketplace
Beauciphus
"w3n-a" wrote in message
Report the spammer at
http://help.blogger.com/?page=contact&skipLogin=true
Secondary Stall w3n-a Owning 12 December 10th 08 07:13 PM
Secondary Stall w3n-a General Aviation 10 December 10th 08 07:10 PM
Secondary Stall w3n-a Piloting 18 December 10th 08 07:10 PM
Secondary Stall w3n-a Naval Aviation 8 December 10th 08 07:10 PM
Secondary Stall w3n-a Home Built 3 December 10th 08 12:36 PM
