lx 7007 PC communication
Old December 22nd 08, 04:00 AM posted to rec.aviation.soaring
Rejean Dallaire
Default lx 7007 PC communication
I'm not able to establish communication with my lx7007 pro igc from my
computer, a MacPro G5 running window XP trought bootcamp.
The computer see the usb to serial adaptor but the lx as well as the
computer shown NO RESPONSE ????
Thanks
Old December 22nd 08, 04:54 PM posted to rec.aviation.soaring
Tuno
Rejean,
I assume you are trying to run the LXe software on your G5?
I suggest using the Control Panel to find out what serial port your
USB/Serial adapter is creating (e.g. COMM5, COMM6, etc). Next, when
you start LXe, there should be a menu that lets you specify which COMM
port.
Have you connected this LX7007 to a PC before, or is this your first
time? (Are you following the LX7007 manual's instructions for using
the TRANSFER | PC PORT menu?)
-ted
Old December 22nd 08, 05:54 PM posted to rec.aviation.soaring
Tuno
All three of the USB-Serial adapters I've tried worked well with the
laptop and desktops I tried them with, connecting to an LX5000 (with
Windows 98) and LX7007 (with XP).
The key is to have the adapter manufacturer's Windows driver loaded
for adapter -- Windows will sometimes say that the (new) device is
ready to use, even before installing the driver. I have been bitten by
this before.
2NO
Bendix King KY 97A TSO VHF Communication Transceiver NEW-USER Home Built 0 February 28th 08 01:40 AM
Communication Specialist Inc. TR720 radio Heino & Deanne Weisberg Home Built 4 September 14th 05 10:32 PM
Ordinary FM radio to listen to air communication. Lukasz W Piloting 8 July 7th 05 03:05 AM
Lost Radio Communication Procedure [email protected] Soaring 9 March 2nd 05 04:35 PM
Air to Ground Communication Scott Home Built 4 August 19th 03 03:39 PM
