OT- For the pilots
Old December 24th 08, 09:30 AM posted to rec.motorcycles,alt.motorcycle.sportbike,rec.aviation.piloting
Gezellig
Default OT- For the pilots
On Mon, 22 Dec 2008 13:21:32 -0800 (PST), BryanUT wrote:
I guess some pilots are like stuntas.
Dead stick take off and landing:
http://www.youtube.com/watch?v=z985xdXW-3w
It is my understanding that stall speeds are measured at altitude (for
purposes of characterizing the plane), so in ground effect it will be a
bit
lower.
Also, you'll probably find that the stall speeds at 20 degrees flaps and
40
degrees flaps are very close, if different at all.
Cessna varied its 172 models over the years. Some had a max flaps of
40,
some 30. I think they went to the 30 and a larger engine to prevent
some of
the go-around accidents they'd been having. With the 40-degree
flaps--which
are something like a brick wall attacked to the back of the wings--the
airplane wouldn't climb at max gross weight. If a pilot attempted a
go-around and forgot to reduce the flap setting (or if there was an
electrical failure), there could be trouble.
With max flaps 30 and a slightly beefier engine, it would climb even if
pilot forgot to adjust the flaps.
It has been a while since I've flown, but go around procedure is (I
think,
from memory) full power, carb heat off, then immediate reduction to
flaps
20. Flaps 10 and flaps 0 come as the airspeed builds.
A 172 with the 40-degree flaps is impressive. If you go to idle, it
will
have a really steep glideslope. But from a safety point of view, there
may
have been issues. I think the modern ones have a max flap setting of
30.
All this is from memory. Could be wrong.
The Lizard
Nice, a little on the WTF side but ice.
Old December 24th 08, 09:39 AM posted to rec.motorcycles,alt.motorcycle.sportbike,rec.aviation.piloting
The Older Gentleman
FFS, get a decent newsreader for Christmas.
Season's greetings.
BMW K1100LT Ducati 750SS Yamaha XTZ660 Tenere Honda CB400F CB125RS SH50
If you don't know what you're doing, don't do it. Workshop manual?
Buy one instead of asking where the free PDFs are
chateau dot murray at idnet dot com
Tow Pilots and Ride Pilots - NV [email protected] Soaring 0 March 12th 08 01:56 AM
Looking for private pilots (as safety pilots) within 100nm of Cincinnati Alex P. Piloting 4 October 4th 07 08:20 PM
Pilots Helping Pilots Henry and Debbie McFarland Piloting 3 May 11th 07 12:20 AM
About Good Pilots and Bad Pilots Dudley Henriques Piloting 96 February 23rd 06 01:19 AM
Is it time to arm crop duster pilots as well as airline pilots? Larry Dighera Piloting 12 April 6th 04 08:47 PM
