Weld over brazing
Old January 5th 09, 12:37 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Weld over brazing
This is not aircraft related.
I did some brazing on a tank and then later decided it would have been
easier to have welded.
I read somewhere that one should not attempt to weld over brazing.
I assume becase the brazing material melts at a lower temp than the
base metal, that welding over a braze would cause the brazing material
to boil away, spattering filler material.
Is that analysis correct?
I assume the recovery is to remelt the brazing filler and wire-brush
it off???? - Mike
Old January 5th 09, 03:39 PM posted to rec.aviation.homebuilt
it off???? - Mike
I've never had much luck with that method. I tried it back in my
bicycle building days and gave up trying to
"salvage" a brazed joint. I may be way off in the actual physics of
the matter..... it was my observation that at welding temperatures the
brass would alloy with the base metal and while I might be able to
make a nice looking weld - they were without exception very brittle
and failed.
Now if I run across a brazed joint that needs repair, if I can't
repair using brass, I either cut away ALL the brazed zone and weld or
junk the part.
Leon McAtee
Old January 5th 09, 05:17 PM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
In article
it off???? - Mike
and failed.
junk the part.
Leon McAtee
Never form a puddle in the base metal when brazing! THe braze will mix
with the base metal and form a poor alloy.
Remove _'s from email address to talk to me.
how do I weld aircraft tubing [email protected] Aviation Marketplace 1 May 10th 06 08:39 AM
LEARN HOW TO WELD plumbcrazy Home Built 1 January 21st 06 06:28 AM
Can't see to weld! X@%$^&!!!! Home Built 6 April 18th 05 06:32 PM
Need recomendations for buying a welding /brazing torch... Wright1902Glider Home Built 9 September 29th 04 03:31 PM
Removing JB Weld? Richard Lamb Home Built 34 July 22nd 04 03:27 AM
