EW Logger
Old January 9th 09, 04:57 PM posted to rec.aviation.soaring
Default EW Logger
Hi,
I have a question regarding the ew logger: the place it has it
listed up for sale differentiates between the engine version and a
pure glider version. Mine will be used mostly in the glider, but I'd
like have the ability to use it in a motorized glider as well, for
vacations, training etc. C302A has the same option when purchased.
Does anyone have experience with any unwanted motorized recording when
being in a pure glider and vice-versa?
GK
Old January 9th 09, 05:21 PM posted to rec.aviation.soaring
Andy[_1_]
Default EW Logger
I have, several times, had to ask OLC to adjust my scoring because the
flight was limited by evidence of engine run. I fly an ASW-28 with a
Cambridge 302. I have no engine.
I think Cambridge has a fix to change the characteristics of the 302
engine noise detection but I do not have that.
Andy
Old January 9th 09, 05:23 PM posted to rec.aviation.soaring
Default EW Logger
All new EW Loggers are engine noise enabled with ED card.
Tom Knauff
Knauff & Grove Soaring Supplies
Darryl Ramm
Default EW Logger
On Jan 9, 8:57*am, wrote:
Hi,
* I have a question regarding the ew logger: the place it has it
GK
I don't see why you are worried. I would be surprised if there is an
issue with the ENL recording, sometimes you might see noise spikes if
you have the recorder by an open canopy vent or similar. However if
you are flying a pure glider I don't see how it becomes a real
problem. If it's a badge or national flight the badge processing folks
should grock it's a pure glider. Have the OO write them a nice note if
you are worried about this. I don't know what OLC does, but this
should be a rare problem if at all and OLC support seems very
responsive to fixing issues, so submit the flight and if there is a
problem let them know. I'd hope that the logic that is already built
into OLC that knows to require ENL recording for a motorglider already
knows to ignore ENL excursions for pure gliders (but I'm not sure).
I was not aware the Cambridge 302A (the 302 variant with no vario) has
an option for ENL, I believe all Cambridge 300 series computers/
loggers have ENL recording. The Cambridge 302-MG variant is intended
for motorgliders and has an external speaker for the vario/STF audio.
This allows you to hear the vario over the engine but is unrelated to
ENL per se (although it may reduce pickup of the audio vario, but the
basic 302 seems pretty good at that already). All versions of the
Cambridge 302 have ENL (engine noise level) recording AFAIK.
Darryl
Old January 9th 09, 05:28 PM posted to rec.aviation.soaring
Default EW Logger
an option for ENL,
- Sorry, I misspelled the name of the instrument. I meant the vario/
flight recorder 302 from Cambridge.
Gregg
Old January 9th 09, 05:45 PM posted to rec.aviation.soaring
Andy[_1_]
Default EW Logger
Early deliveries of the 302 did not include ENL as it had not been
fully developed or approved. Some customers, including myself, had
ENL retrofitted when it became available. The ENL mod required
elimination of the internal speaker and forced the use of an external
speaker. At that time the ENL retrofit was no cost since Cambridge
had marketed the 302 as having ENL capability.
When ENL became available Cambridge then marketed 2 versions of the
302, one with ENL, and one without. ENL was an additional cost
option.
Perhaps the design has changed since then and ENL is now available in
conjunction with an internal speaker.
Andy
Old January 9th 09, 07:54 PM posted to rec.aviation.soaring
Darryl Ramm
Default EW Logger
fully developed or approved. *Some customers, including myself, had
ENL retrofitted when it became available. *The ENL mod required
speaker. *At that time the ENL retrofit was no cost since Cambridge
302, one with ENL, and one without. *ENL was an additional cost
option.
Andy
Andy
Thanks for the background. My (non-MG version) 302 from ~3 years ago
had ENL recording. IGC files claim ENL in the I record (extended data)
and as data in the B records. Now wether it spent most of it's time
recording it's own internal vario speaker and was kind of usless for
any real ENL recording is another point. I'm basing my entire
experience that plain 302's, at least in the last few years, have ENL
on that one transponder. Is this right?
If all 302s now have ENL then I read the Cambridge 302 approval
document as kind of ambiguious since it talks about motorglider
approval for the 302 "with ENL option" but if all 302 now do record
ENL do we assume they would be usable in principle for all badges and
records in motorgliders as per the approval document. Or does it
really mean the approval is only for the MG version with an external
speaker? Seems the approval doc could do with a some clarification if
the later is the case. (or am I missing something? Marc?).
Darryl
Old January 9th 09, 08:26 PM posted to rec.aviation.soaring
Andy[_1_]
Default EW Logger
The Cambridge web site lists 4 different 302 models. One distinction
is the units (kts or m/s) used. The other distinction is whether ENL
is included. ENL is still listed as an extra cost option. I see no
reference to a motor glider version (as being different from a unit
with ENL)
Andy
Old January 9th 09, 09:04 PM posted to rec.aviation.soaring
Darryl Ramm
Default EW Logger
is included. *ENL is still listed as an extra cost option. *I see no
with ENL)
Andy
Andy
I just went and grabbed a few IGC files from people I know who have
Cambridge 302's in their gliders and I assume they are the non
motorglider versions. While they show "ENL" in the I record they
record zeros in the B record ENL field. I'm starting to think maybe I
had an earlier version, or somehow it got mixed up with an MG
version. Paul's post helps explain why there may be confusion about
this.
BTW many of the resellers of the C302 seem to call the motor glider/
ENL version the 302E-MG not 302E-ENL. (E for english/knots in this
case).
Thanks
Darryl
Old January 9th 09, 08:45 PM posted to rec.aviation.soaring
Paul Remde
Default EW Logger
Hi,
It is my understanding that older versions of the 302 that were made before
the ENL approval, can and do record engine noise level. After the approval
was received, they started shipping 2 versions. The non-ENL version does
not record engine noise level. The ENL version has an external speaker and
does record ENL.
The 302A is available in only one version. It is always ENL enabled.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Darryl Ramm" wrote in message
option.
Andy
Andy
Darryl
Looking for a Logger [email protected] Soaring 0 August 3rd 06 05:47 PM
Ted, your LX logger......... [email protected] Soaring 6 June 26th 06 04:21 PM
Logger Ralf S. Soaring 3 February 21st 04 04:49 AM
Which Logger? tango4 Soaring 15 October 5th 03 01:12 AM
USB-logger koppeling Gerbert Soaring 0 July 25th 03 05:02 AM
