Didn't know that....
Old January 18th 09, 09:49 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.disasters.aviation,rec.arts.poems
Bertie the Bunyip[_28_]
Default Didn't know that....
wrote in :
On Sat, 17 Jan 2009 15:54:23 -0500, "Scott M. Kozel"
"Scott M. Kozel" wrote:
what the ditching button does ... it may just send
signals to the cabin crew to prepare for ditching. Or it may be to
shut off all electrical power immediately before entering the
water.
What does the DITCHING pb do? PHB 10.5.4
The DITCHING pb on the pressurization panel, when selected ON,
allows the pilot to close all exterior openings below the flotation
line. This will enhance flotation of the aircraft in case of
ditching. System sends a close signal to:
• Outflow valve (if not in manual control)
• Emergency ram air inlet
• Avionics ventilation inlet and extraction valves
• Pack flow control valves
• Forward cargo isolation outlet valve (if installed)
Is this also "According to CNN"?
Nope. Found it somewhere else on the internet.
Sounds like the news media is clueless as usual about aviation
matters...
So, the above is completely nonsens? The button doesn't exist?
Those inlets can't be closed for ditching?
Actually they can in most arplanes. The 'bus has one that will do the
whole lot in one go, though. Some old Brit airplanes had the same thing.
you know,in case "Gerry snuck up on us over la Manch after a jolly good
thrashing of Dresden"
Bertie
Bertie
Old January 19th 09, 10:55 PM posted to rec.aviation.piloting,alt.disasters.aviation
Maxwell[_2_]
wrote in :
She wasn't there either...
in any case she's talking ****. It was a low priority in any case.
Bertie
Like you had a clue.
Old January 21st 09, 06:03 PM posted to rec.aviation.piloting,alt.disasters.aviation,alt.usenet.kooks
"Maxwell" #$$9#@%%%.^^^ wrote in news:ex7dl.165906$2w3.143091
@newsfe19.iad:
wrote in :
Bertie
Snort!
Bertie
Old January 20th 09, 08:12 AM posted to rec.aviation.piloting,alt.disasters.aviation
George
On Jan 18, 5:49*pm, Bertie the Bunyip wrote:
"It happened so fast, the pilots never had time to throw the
aircraft's "ditch switch," which seals off vents and holes in the
fuselage to make it more seaworthy. "
in any case she's talking sh**. It was a low priority in any case.
Bertie
If she was quoting what the Capt. testified to "we didn't throw the
ditch switch" (or similar) how would this be "talking sh**?
Why is the ditch switch a low priority? Is it operable after the plane
has hit water & is (temporarily) floating?
Old January 20th 09, 02:17 PM posted to rec.aviation.piloting,alt.disasters.aviation
Bertie
Low priority compared to flying the plane, deadstick, in a congested
urban environment.
Or would you rather he spend time looking for a button on the panel?
Geez people, if you don't fly the plane or if you allow yourself to
become distracted over minutae you will die. Don't you get it?
"Examination of the wreckage of ill fated flight 1549 along with
playback from the CVR showed the air crew to have been unduly
concerned with the 'ditch switch'". Would that make everyone
happier? Perhaps with the stall warning sounding in the background
along with the final 'oh ****' from pilot?
How about this, while attempting to steer around a sudden obstruction/
incident on the highway why don't you call 911?
This kind of faulty thinking is why people shouldn't be allowed to
have distractions, aka radios, cellphones or talking pax in their
automobiles.
