Komet Trailer gas struts
Old January 20th 09, 10:44 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
Default Komet Trailer gas struts
I have a 1983 Komet Standard glass top trailer. The gas strut(s) just went
kaput!
Anyone out there know the specifications? I'd be very appreciative of the
info.
TIA
Hartley Falbaum
Old January 21st 09, 05:25 AM posted to rec.aviation.soaring
ZZ
kaput!
info.
TIA
HL
I replaced both of my Komet trailer struts about 2 years ago and after
seeing your post, I looked for the info. I have misfiled some of the
contact info for the US supplier but I do have his name and 3 email
addresses for you to try. This supplier was very helpful and lives(d) in
New York. His name is Harold Ennulat. Here are the email addresses I
have for him. (1) hennulat at connecttime dot net. I think this is the
latest so try this first but here are two others: (2) hennulat at cox
dot net (3) hennulat at cox dot net dot ny.
Regarding the specifications: the struts come in 2 strengths...1300
Newtons and 1600 Newtons, depending on the weight of the top of the
trailer. For my ASW20BL the 1600 Newton was recommended, due to the
extra tips I suppose. Harold can advise you on this matter.
The labels on my new struts stated,,,Hahn Gasfedern Gmbh. Waldstrasse
43 73773 Aichwald Telephone 07 11/93 67 05-0. Herst Dat 0601 Art Nr.
217880 1600N.
They arrive fully extended. But when the trailer is fully opened, the
struts are not fully extended.Therefore to install the new ones, you
have to use a strong rope or chain to suspend the top from ??...I used a
beam in my hanger. Remove both of the old ones and then open the top
further beyond its normal height so as to accommodate the longer length
of the new struts.
I hope this helps.
Paul
ZZ
Old January 21st 09, 02:13 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
Thanks Paul--
Helps a lot.
Hartley Falbaum
"ZZ" wrote in message
went kaput!
info.
TIA
HL
New York. His name is Harold Ennulat. Here are the email addresses I have
for him. (1) hennulat at connecttime dot net. I think this is the latest
so try this first but here are two others: (2) hennulat at cox dot net (3)
trailer. For my ASW20BL the 1600 Newton was recommended, due to the extra
The labels on my new struts stated,,,Hahn Gasfedern Gmbh. Waldstrasse 43
73773 Aichwald Telephone 07 11/93 67 05-0. Herst Dat 0601 Art Nr. 217880
1600N.
struts are not fully extended.Therefore to install the new ones, you have
to use a strong rope or chain to suspend the top from ??...I used a beam
in my hanger. Remove both of the old ones and then open the top further
beyond its normal height so as to accommodate the longer length of the new
struts.
I hope this helps.
Paul
ZZ
Old January 21st 09, 03:03 PM posted to rec.aviation.soaring
DRN
of the new struts.
You can support the trailer top with a couple 2x4's firmly
clamped; no need for overhead hoist if that's not readily
available. In either case, BE CAREFUL !
Same applies for Cobra trailers (thanks for the tip Alfred).
Hope that helps,
Best Regards, Dave
Old January 21st 09, 04:15 PM posted to rec.aviation.soaring
bildan
of the new struts.
Hope that helps,
Best Regards, Dave
If you can get access to a hydropress, you can partially compress the
struts and safety wire them in that position. That means you don't
have to raise the trailer top as far. Yes, be very careful.
Old January 22nd 09, 02:00 AM posted to rec.aviation.soaring
TonyV[_2_]
I got the replacement struts from Harold Ennulat for my Komet III. Had a
helper or 2 lift the top to the correct position so that the bolt holes
lined up, bolt the gas struts to the trailer, and you're done. It was a
no brainer.
Tony V.
Old January 22nd 09, 02:39 AM posted to rec.aviation.soaring
HL Falbaum[_2_]
Thanks All
Have ordered from Harold.
Hartley Falbaum
"TonyV" wrote in message
lined up, bolt the gas struts to the trailer, and you're done. It was a no
brainer.
Tony V.
Old January 24th 09, 12:48 AM posted to rec.aviation.soaring
Uncle Fuzzy
On Jan 21, 5:39*pm, "HL Falbaum" wrote:
Thanks All
Hartley Falbaum"TonyV" wrote in message
struts and safety wire them in that position. *That means you don't
have to raise the trailer top as far. *Yes, be very careful.
brainer.
Tony V.- Hide quoted text -
- Show quoted text -
One of mine is getting slightly weak. I suspect the end is near.
Would you mind posting how much they cost?
Old January 24th 09, 02:34 AM posted to rec.aviation.soaring
TonyV[_2_]
US$125 each. Expensive, but you will be really annoyed if a strut fails
as you are pulling the glider out of the trailer.
Tony V. LS6-b
Old January 24th 09, 03:23 AM posted to rec.aviation.soaring
HL Falbaum[_2_]
US$125 each. Expensive, but you will be really annoyed if a strut fails as
Tony V. LS6-b
Entec (H. Ennulat)quoted $130 + shipping.
McMaster-Carr (source of everthing you ever need at a decent price) is over
$100 but no guarantee on exact fit!
Much less than the price of, say, a new canopy!
Hartley Falbaum
USA Mid Georgia Soaring LS-4 "RC"
Old Komet Trailer thermalrider Soaring 7 October 11th 08 05:13 PM
Cobra trailer lift struts for clamshell top [email protected] Soaring 4 March 4th 08 12:55 PM
Komet Trailer Gas Springs P. Corbett Soaring 4 March 12th 07 12:30 AM
Gas Struts for Clamshell Trailer [email protected] Soaring 1 April 26th 05 03:49 AM
Komet trailer strut John Shelton Soaring 5 November 15th 03 06:04 PM
