The 2009 Club Class Waiver
Old January 21st 09, 02:15 PM posted to rec.aviation.soaring
Sam Giltner[_1_]
Default The 2009 Club Class Waiver
The 2009 Club Class waiver:
A separate Club Class will be allowed in Regional Contests by waiver in
2009. The Club Class is a handicapped class similar to the Sports Class,
but with two differences:
1) Gliders allowed to compete in the Club Class are restricted to US
Team Club Class Team gliders (www.ssa.org Sailplane RacingUS
TeamsSelectionList of Club Class Team Eligible Gliders).
2) Normal Sports Class Regionals rules apply, except that the AST task
is allowed (this is not allowed in the normal Sports Class).
Pilot entry requirements, fees, PRL ranking earned, medallions earned,
are all the same as the normal Sports Regionals. US Sports Class handicaps
are used. The inclusion of a Club Class should be published before the
preferential entry cutoff. The distinction between the Club Class and the
Sports Class should be made clear. The contest sanction application should
treat the contest as a normal Sports Class Regionals. There is a box on the
sanction application form regarding whether a waiver is requested. Answer
"yes" and as a description write "2009 club class waiver".
Ken Sorenson SSA Contest Committee Chairman
Old January 21st 09, 06:18 PM posted to rec.aviation.soaring
Pat Russell
I would be very careful about calling this the "Club Class."
The International Club Class uses a different list of gliders and
different handicaps. It also uses "relative" (not absolute) handicaps
to adjust the speeds.
Perhaps this should be called the "US Club Class" to avoid confusion.
Old January 22nd 09, 01:06 AM posted to rec.aviation.soaring
different handicaps. *It also uses "relative" (not absolute) handicaps
Dear Pat,
Please expound on the distiction between IGC's use of "relative"
handicaps and US Sports Class use of "absolute" handicaps.
Thanks.
Old January 22nd 09, 03:20 AM posted to rec.aviation.soaring
Pat Russell
In the IGC rules, the factor applied to your speed or distance is the
ratio of your handicap to the handicap of the best glider at the
contest. In the US Sports Class, the factor is the handicap itself.
The difference causes the boundary between points for finishers and
non-finishers to be shifted. The amount of shift depends on which
gliders show up for the contest (in the IGC case).
-Pat
Old January 22nd 09, 06:00 AM posted to rec.aviation.soaring
Howard Banks[_2_]
To change this a bit, has anybody else noticed that the results of the poll
of pilots by the contest committee on this subject were heavily against
changing the sports class and introducing a club class variant?
Does this committee -- or the rules part of it -- take no notice of the
results of these polls, or what?
-Pat
Old January 22nd 09, 11:11 AM posted to rec.aviation.soaring
AK
On Jan 22, 1:00*am, Howard Banks
changing the sports class and introducing a club class variant? *
contest. *In the US Sports Class, the factor is the handicap itself.
non-finishers to be shifted. *The amount of shift depends on which
gliders show up for the contest *(in the IGC case).
-Pat
Yes, but how many pilots voted against who never fly in Sports class.
If we had Sports class only pilots voting on this subject the results
would probably be different.
Let's have a contest and we will see how many pilots will show up.
Old January 23rd 09, 01:50 PM posted to rec.aviation.soaring
-Pat- Hide quoted text -
- Show quoted text -
The RC did pay attention to the poll. I also listened to a small, but
very vocal and dedicated
group led by 5U that think we should give Club a chance to be tried
and see what develops. There
are some real concerns aboutr how this might affect Sports. See the RC
meeting minutes for a view of those.
That said, the RC determined that it is worthwhile to give this a try,
by waiver, and see how it goes. If we see a bunch of new blood, as
some claim we will, it could be good. If all it does is cut the heart
out of Sports, that will be not good- obviously. It will not be likely
to become a full blown class withouit substantial contributions to
participation.
We will watch and see how it goes, then poll and determine next steps.
Please note that the RC does listen to the poll, but it is not the
only input.
Let's give it a chance.
FWIW - UH will be flying a Club Class glider in Elmira. Call me a
skeptical supporter.
UH
RC Chair
Old January 22nd 09, 03:17 PM posted to rec.aviation.soaring
Pat,
When you say "best" glider at the contest , do you mean the glider
that wins the day/contest, or the glider entry having the most weighty
handicap (newer glider having the best performance capability)?
Old January 22nd 09, 04:09 PM posted to rec.aviation.soaring
Pat,
The IGC handicaps are used in an inverse way to the US handicaps,
i.e. the higher the handicap, the faster the plane. The time around
course is multiplied by the handicap before determining speed, rather
than the distance. The handicaps are all "normalized" so that the
slowest plane gets no modification. E.g., if everyone show up in
an LS3, Mini-Nimbus, Mosquito, or ASW-24 (all with the same 1.07
handicap) then everyone is scored directly on speed around course
(no modifications for handicap). If one more person shows up with
a standard Libelle (with a handicap of 0.98) then the Libelle gets
scored with straight speed and everyone else gets their time on
course increased by 1.07/0.98 = 9.18%.
I could be wrong about the exact details, since Strepla (which is
used by scoring in other countries) is not open source, unlike
WinScore.
Old January 22nd 09, 12:31 AM posted to rec.aviation.soaring
AK
On Jan 21, 9:15*am, Sam Giltner wrote:
* The 2009 Club Class waiver:
* A separate Club Class will be allowed in Regional Contests by waiver in
2009. *The Club Class is a handicapped class similar to the Sports Class,
but with two differences: * *
*1) *Gliders allowed to compete in the Club Class are restricted to US
Team Club Class Team gliders (www.ssa.org*Sailplane RacingUS
TeamsSelectionList of Club Class Team Eligible Gliders). *
*2) *Normal Sports Class Regionals rules apply, except that the AST task
*Pilot entry requirements, fees, PRL ranking earned, medallions earned,
"yes" and as a description write "2009 club class waiver". *
This is a great news. Thank you!
Club class/Sports class Sam Giltner[_1_] Soaring 7 September 28th 08 12:17 AM
Club Class vs. Sports Class noel.wade Soaring 28 September 25th 08 02:52 AM
SPORTS CLASS/CLUB CLASS 5 ugly Soaring 0 July 2nd 06 11:14 PM
Does USA need a Club Class? MC Soaring 42 April 7th 05 08:07 PM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
